POV-Ray : Newsgroups : povray.binaries.images : Ruined : Re: Ruined Server Time
29 Nov 2026 19:45:08 EST (-0500)
  Re: Ruined
Date: 24 Jun 2007 22:12:08
Message: <467f2478@news.povray.org>
Bill Pragnell wrote:
> If you're using an isosurface or other pigment function-based perturbation,
> you should be able to use the same pattern to provide texturing - limit
> your grime textures to the same regions of the colour map as are used for
> the erosion.
Agreed.  Pretty much the standard approach.
>The other thing you could try is using the un-weathered base
> object to define an object pattern - only areas inside the object could
> then be textured, i.e. just the weathered sections. I don't know if these
> are practical for your purposes...
I have had some success with this approach also, basically I think I
jittered the object pattern through several minor scale changes.  I used
that approach on this chalice image.  In the test shot the green shows
where the grime colour would fall.
Download 'img.0132.sm.jpg' (106 KB) Download 'img.0210.jpg' (40 KB)
Preview of image 'img.0132.sm.jpg'
Preview of image 'img.0210.jpg'
