POV-Ray : Newsgroups : povray.binaries.images : Escher impossible shapes : Re: Escher impossible shapes Server Time
6 Mar 2026 19:48:56 EST (-0500)
Date: 16 Aug 2006 19:05:37
Message: <44e3a4c1@news.povray.org>
Robert Goss wrote:
> I made up a simple macro which turns a network of points into a
> Escher style impossible shape. The effect is not perfect but in some
> cases very nice.
> I thought I would share the resulting images and see if any one had
> any suggestions for improvements to them.
I hate to be the one to criticize, but some of the overlaps in your image
are "flawed", at least in the sense that they cannot be explained by
traditional "impossible figures logic". I've attached an image that shows
two places where are bar is cut by another bar in a way that does not make
sense. The cut bars stop abruptly here, even though the "cutting car" is
obviously not in front of it (as the illusion should make it seem like) as
there is a third bar in between the two other bars. (Perhaps this is what
you refer to when you say that the effect is not perfect.) Not only is the
cut "illogic"; it also weakens the illusion, since it's far more obvious
that it is just a part of the front bars that are cut away.
The "flaw" can easily be corrected by either making the bars smaller or
showing the figure from an angle that is not problematic. This is also an
argument that animated rotating figures cannot be done without braking the
illusion in the same way that it is broken in this image.
Other than that, very nice image.
Rune
http://runevision.com
Download 'network4_2_overlaps.jpg' (15 KB)
Preview of image 'network4_2_overlaps.jpg'
