POV-Ray : Newsgroups : povray.binaries.images : Funky Granules : Re: Funky Granules Server Time: 23 May 2018 01:25:53 GMT
  Re: Funky Granules
Date: 15 Apr 2006 07:54:33
Awhile ago, I made a macro similar to this one, but it was based on a
function.  It was more similar to an isosurface that approximated it
with cubes.
I wonder what kind of result I could get if I used a blob with spheres...
-DJ
Loki wrote:
> Haven't tested it with meshes but I don't expect it would work in all cases
> as it requires the use of an inside(obj,vect) test.  I think the POV docs
> state that meshes can have an inside if they form a closed shape and you
> specify the inside_vector, but I rarely use meshes where I can get away
> with SDL, CSG or macros so haven't tried it out.
> It basically works by sampling points within the bounding box of an object
> with a user-set resolution, testing whether each point is inside the
> object, and creating a union of cubes for the inside points.  The same
> method can be used with a merge instead of a union if you want to create a
> well-behaved transparent version of the same.  Render times are OK, as it's
> just a collection of simple primitives, but for high resolution sampling the
> parse time (and probably memory usage) can skyrocket.
> As I mentioned the method is a but clunky and can no doubt be improved, but
> it achieved what I wanted it to so I'm not going to pursue it any further.
> Here's the SDL, since it sounds like a couple of people are interested:
> #macro GRANULE(GrObj,Res,Text)
>   #local MinExt = 0;
>   #local MaxExt = 0;
>   Extents(GrObj,MinExt,MaxExt)
>   #local MinCxLim = Res*floor((MinExt.x)/Res);
>   #local MinCyLim = Res*floor((MinExt.y)/Res);
>   #local MinCzLim = Res*floor((MinExt.z)/Res);
>   #local MaxCxLim = Res*ceil((MaxExt.x)/Res);
>   #local MaxCyLim = Res*ceil((MaxExt.y)/Res);
>   #local MaxCzLim = Res*ceil((MaxExt.z)/Res);
>   #local Cz = MinCxLim;
>   union {
>   #while ( Cz < MaxCzLim )
>     #local Cy = MinCxLim;
>     #while ( Cy < MaxCyLim )
>       #local Cx = MinCxLim;
>       #while ( Cx < MaxCxLim )
>         #if ( inside(GrObj,<Cx+(Res/2),Cy+(Res/2),Cz+(Res/2)>) )
>         object {
>           box {
>             <Cx,Cy,Cz>-(Res/100),<Cx,Cy,Cz>+(Res*1.01)
>         #end
>         #local Cx = Cx + Res;
>       #end
>       #local Cy = Cy + Res;
>     #end
>     #local Cz = Cz + Res;
>   #end
>     texture {
>       Text
> #end
> Call it by using
> GRANULE(Object,Resolution,Texture)
> where Object and Texture are previously declared, and Resolution is a float
> indicating the size of each cube.
> L
Copyright 2003-2008 Persistence of Vision Raytracer Pty. Ltd.
