POV-Ray : Newsgroups : povray.binaries.animations : Orrery WIP Server Time
21 Apr 2026 10:31:49 EDT (-0400)
  Orrery WIP (Message 1 to 7 of 7)
Subject: Orrery WIP
Date: 4 Mar 2026 16:45:00
Message: <web.69a8a5a654ac36608db55336e0accf30@news.povray.org>
This is a project I started over 20 years ago by modeling an orrery.  Then had
to figure out a scene to put it in.  This is what I finally came up with.  Turn
looping on in your player.  I would get stuck on it, or real life interrupted,
put aside for a few years then repeat.  I'm not very happy with the clouds the
camera flies through, not enough turbulence.  There is also some flickering I
haven't been able to get rid of.  The camera has a couple of abrupt moves I need
to smooth out.  I do plan to add more objects to the scene.  Any comments or
suggestions would be welcome.
Subject: Re: Orrery WIP
Date: 5 Mar 2026 09:10:00
Message: <web.69a98ea8cba6101ef625f77c25979125@news.povray.org>
And you're still at it!  Good work.
It's been a long time since I've seen one of these classic animations.
>Then had
Clouds are notoriously difficult.
I didn't really notice anything, so it must be a very small problem.
> to smooth out.
When you're about to make a sharp turn, slow down the camera dramatically.
Look into "smoothing functions" to get the sort of thing you want.
I like the island a LOT.
The house, the working lighthouse (make the light MUCH brighter), the ceiling
fan, the periodic table, the stencil on the desk....
The orrery sun could be a bit brighter/yellower.
I like the checkered bed.  Perhaps a silvery pillow would be a nice "easter egg"
nod to the RSOCP.  It's always fun to sneak some classic POV-Ray / computer
graphics models, or someone else's POV-Ray model/effect into a scene.
If you hit any more stumbling blocks, don't be afraid to ask for ideas or
solutions.  Set your goal on the finish line!
- BE
Date: 5 Mar 2026 17:55:00
Message: <web.69aa0869cba6101e8db55336e0accf30@news.povray.org>
> >Then had
> > to smooth out.
> - BE
Thank you for the suggestions.  I made a few changes and reposted a new
animation.  The flickering is much more noticeable at higher resolutions, I
rendered the animation at 1280x720 then reduced it to 640x360 to get the size
down for posting.  The planet maps came from a NASA web site, I picked a new sun
that is brighter and yellower.  It does look better.  The checkered bed was a
nod to the RSOCP, but the pillow reflects the creme colored walls not the bed
and it almost looks translucent not reflective.  At the time I created the
lighthouse I didn't know the color rgb values could be greater than 1.0.  I
increased the value and it looks much better.  I wrote a program to generate the
island,  started with a pyramid and recursively divided the faces into smaller
triangles and translating the vertices a random amount up or down and then
created a mesh2 object.  I then populated the island with 24000 trees and 32000
bushes that were created by Arbaro 2.0.  Now I need to work on the camera
transitions.
Download 'island640.mp4.dat' (3548 KB)
Date: 5 Mar 2026 21:15:00
Message: <web.69aa3855cba6101e1463fe62d568493a@news.povray.org>
Very nice. I did an orrery some time ago:
<https://www.youtube.com/watch?v=GyqQolOK_qI>
I remember one of the first scenes I animated was a lighthouse (using Polyray)
way back when :-)
m@b
Date: 5 Mar 2026 22:25:00
Message: <web.69aa489dcba6101e8db55336e0accf30@news.povray.org>
> way back when :-)
> m@b
Very nice.  I particularly like the way you morphed the planets into the orrery.
Impressive.
Date: 8 Mar 2026 22:50:00
Message: <web.69ae34aacba6101e1463fe62d568493a@news.povray.org>
> > way back when :-)
> > m@b
> Impressive.
Date: 17 Mar 2026 17:20:00
Message: <web.69b9bceacba6101e8db55336e0accf30@news.povray.org>
> > >Then had
> > > to smooth out.
> > - BE
> transitions.
In trying to reduce the flicker, I rendered at 3840x2160 then scaled it down to
640x360.  It didn't eliminate all the flickering but did reduce it a lot.  That
cut the size down from 42MB to a more reasonable 3.4MB.  I was also able to
smooth the transition when the camera entered earth orbit.  Still not completely
happy with it, but I think its looking better.
Download 'island640.mp4.dat' (3421 KB)
