POV-Ray : Newsgroups : povray.binaries.animations : object rotations in 2 axes vs. 3 Server Time
18 Dec 2025 01:03:18 EST (-0500)
  object rotations in 2 axes vs. 3 (Message 7 to 16 of 46)
<<< Previous 6 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: object rotations in 2 axes vs. 3
Date: 3 Oct 2018 07:25:00
Message: <web.5bb4a61e307ceb10a47873e10@news.povray.org>
dick balaska <dic### [at] buckosoftcom> wrote:
> My caboose landing is a 2 axis rotation.
Yes, I noticed that ;-) In fact, it was while working on my own animated demo
that I first viewed your animation-- so I paid particular attention to that
caboose, ha.
Date: 3 Oct 2018 07:40:00
Message: <web.5bb4aa69307ceb10a47873e10@news.povray.org>
> On 3-10-2018 12:48, Bald Eagle wrote:
> > The distinction between 2 and 3-axis is artificial.
> > Perhaps you're just "adding" or "fiddling" too much - adding a jitter where
> > there ought to be a flow.
> Yes, that is an important, if not fundamental, point.
In my mind's eye, I see that this could indeed be the case-- that the third
rotation is kind of 'mixing with' (and messing with) the other two... because
the initial two are already enough to orient the object. Kind of like a
'redundant force' that ends up being split up between the initial two rotations,
in a weird way. (BTW, I'm still pondering the 'Euler angle' discussion from a
recent thread, and how it relates to this stuff.)
Date: 3 Oct 2018 07:43:30
Message: <5bb4ab62$1@news.povray.org>
For this application, I disagree.  For a static image, yes, there is no
difference. But for an animation, hmm, how do you say in English...
There are two increments vs. three increments.  Take my caboose,
3 axises would be 1) it's laying on it's side (x), 2) it's standing on
it's end (z), 3) it is rotating around the y.
You can choose any one final vector using 2 axii, but to animate the
three rotations simultaneously requires all 3.
dik
Rendered 1024 of 921600 pixels (0%)
Date: 3 Oct 2018 08:20:00
Message: <web.5bb4b276307ceb10a47873e10@news.povray.org>
> difference. But for an animation, hmm...
Yet the visual result of using all three definitely looks...odd.
Going back to first principles: An object starts out as being static (that is,
no ROTATIONS at all.) Then a force has to impinge on it to start it rotating-- a
'point' force for simplicity's sake. That force has a direction vector, and acts
on the object in 3 (de-composed) vector directions, toward the center of mass.
The magnitudes of those three vectors depend on where the force was applied on
the surface (relative to the object's center of mass) and the angle of contact
with the surface. If I understand the concept of 'Euler angles' correctly, those
three force vectors can be 'simplified/combined' into just two resulting
rotations.
That's about the limit of my understanding so far ;-)
Date: 3 Oct 2018 11:50:06
Message: <5bb4e52e@news.povray.org>
Le 03/10/2018 à 02:34, Kenneth a écrit :
> To take a break from my other POV-ray chores, I made a simple animated demo of
> what an object looks like when it rotates (in POV-ray), as if free-falling under
> gravity-- but discounting wind resistance or any other extra force. Its a
> comparison between applying the rotations in two axes vs. three. I made the
> animation my own purposes (to easily refer to later), but it might be of
> interest to others as well.
> There's an obvious difference in the visual appearence of the objects. My own
> preference is for the 'two-rotation' scheme; it just looks more 'natural' (or
> more 'expected'?) Using all three rotation axes imparts an 'extra' force to the
> object-- kind of like wind resistance (which is also interesting, of course, but
> otherwise kind of strange.) The 3-axis scheme *might* also depend on the order
> of how those rotations are applied, to look 'more correct'-- not just straight
> <x,y,z>, in other words.
> Long ago, I originally thought that a free-falling object needed all three
> rotations to look natural. The idea seemed logical-- but the visual result
> didn't bear that out (to my eyes, anyway.) I guess I could do a thorough
> analysis of the applied 'vector forces' that cause an object to rotate in the
> first place -- but that's a lot of work  ;-)  For now, I'm curious as to which
> scheme you prefer, from a purely visual standpoint.
It's not the size which matters, it is how you use it.
From Euler's angles to describe a rotation, 2 angles are enough until
you want to adjust the rotation around the pole, then you need a third
angle. Any move made of 4 or more rotations can be simplified to just 3
Euler's angles, so 3 rotations is what is at most needed for any
positioning. Yet it is like saying that solving the Rubik's cube only
need at worst 17 (or 19 ?) moves, but some algorithms might generates a
hundred steps.
(and all the rotations can be composed in a single transformation, but
the equation is a bit complex)
composing rotations might not be what seems natural, especially when
they are done along fixed axes. Euler's angles have moving axis: the
first rotation is from the base(x, on z), but the second is from the
updated vector (on updated x), and so is the third (on updated z) which
in part compensate for the first one.
Natural moves usually try to conserve energy and have no acceleration.
In such setting, it is unlikely to see the axis of the last rotation be
moved by the change in the second angle: the gyroscopic effect (and our
expectation about it) would oppose to such change.
To summarize:
you need 3 angles (in Euler's system) to describes any orientation, but
natural fall would only change two angles during animation and such
change would be with a null second derivative for each unless you have
friction or engine in play.
On a table, with Inception totem:
The third angle is the proper rotation of the Inception totem, whereas
the second angle is the oscillation of the axis of the spinning top, the
speed of the oscillation being driven by the speed of the first angle.
The second angle is constant, for natural expectation of no friction.
Date: 3 Oct 2018 11:58:28
Message: <5bb4e724@news.povray.org>
> rotations.
Well here is my tuppence worth.
I think that it is the ratio of the rotations that makes 3 axes look
odd. in this animation the X axis rotates 3 times for one rotation of
the Z axis and the Y axis rotates twice.
(I am wedded to cyclic animations)
Regards
Download '0001-0599.mp4.mpg' (1679 KB)
Date: 3 Oct 2018 12:03:47
Message: <5bb4e863$1@news.povray.org>
BTW the die are meshes made in blender and rendered in Pov.
Regards
Date: 3 Oct 2018 12:15:50
Message: <5bb4eb36$1@news.povray.org>
Brain is taking a break. :(
The LH dice is rotating on 2 Axis, X&Y the RH one in all three.
Regards
Date: 3 Oct 2018 14:10:19
Message: <5bb5060b$1@news.povray.org>
Check out
https://en.wikipedia.org/wiki/Euler_angles
The trick is to rotate around the same axis twice. E.g.
rotate z
rotate x
rotate z
Date: 3 Oct 2018 14:48:52
Message: <5bb50f14$1@news.povray.org>
> My caboose landing is a 2 axis rotation. I'm not sure why I didn't even
> try 3, that would have made sense.
> Your 3 axis, it looks like sometimes it changes direction while falling.
Is this due "gimbal lock?"
Just me echoing what I've read, but I think you have to go to use
Quauterions to avoid certain angle ambiguities.
was exposed to gimble lock on seeing a recent posting of yours. I've not
gotten to testing the thought or reviewing your code though - and
probably won't for a long while yet. Still occupied with solvers and
related numerical methods.
Bill P.
