POV-Ray : Newsgroups : povray.binaries.animations : Impossible triangle, animated Server Time
18 May 2024 14:40:34 EDT (-0400)
  Impossible triangle, animated (Message 11 to 11 of 11)
Subject: Re: Impossible triangle, animated
Date: 17 Jun 2013 14:31:33
Message: <op.wyt5qsl9ufxv4h@xena>
On Mon, 17 Jun 2013 15:08:30 +0200, Christian Froeschlin <chr### [at] chrfrde>
wrote:
> Nekar Xenos wrote:
>> That is exactly what I was asking. Not for it to be an impossible
>> object, but rather an assertion that the impossible object is not
>> impossible, it is 4d. My question is where can I find a formula to
>> prove/disprove this?
> That was not quite what I meant. I was pointing out that the
> question is not well-defined because the "impossible" object is
> not necessarily any sort of geometric object (not even a mathematical
> abstraction in n-dimensional space). It is just a conflict in your
> brain because it locally misinterprets the 3d structure of the image
> and can't get to a consistent model.
> Of course you can define a 4d object that looks like the impossible
> object in 2d projection, but so you can in 3d (it's the possible object
> Eriban is actually building). Who can say it is or is not the object
> that you (fail to) imagine when you encounter the illusion.
> Of course, there exist objects in 4d space that have 3 or less
> dimensions and still cannot be embedded in 3d space. A famous example
> is the Klein Bottle. But I think this is a different matter.
I'm not very good at explaining myself :)
My idea is that when one looks at a Penrose triangle what is perceived may
actually be a 4D object with straight edges.
-Nekar Xenos-
