POV-Ray : Newsgroups : povray.binaries.animations : A camera-effect Server Time
14 Nov 2025 18:57:49 EST (-0500)
  A camera-effect (Message 1 to 3 of 3)
Subject: A camera-effect
Date: 2 Jan 2007 00:35:01
Message: <web.4599eeccae2b7a2d13dd34b50@news.povray.org>
For animations, a simple but IMO nice camera-effect.
First "Cut & paste" the following files into the files:
   "scene0.pov" and "scene0.ini"
Of course without the limiters;-)  .Than render with the command:
   povray scene0.ini
the images for the animation. I'm using the .ppm-format, because on
LINUX/UNIX etc. the .ppm-format is  the most supported format for
making animations. But if you wish the default image-format, delete
the "P"-character after the switch: +F in the .ini-file.
After all images are rendered, create the video, with an encoder of
your  choice. If your are using the "ffmpeg"-encoder (LINUX) you can
create the video with this command:
ffmpeg  -bf 2 -an -g 300 -b 10000000 -i ./scene%4d.ppm scene0.mpg
and see what happens.  :-)
And all wich can't render the scene, can found the result in the
attachment.
--[File: scene0.pov]-------------------------------
background{MediumBlue}
box{-1,1 pigment{White}}
light_source{-5,2}
camera{location<0,0,-5>
 normal{quilted 1 rotate z*360*clock}
--[End of: scene0.pov]------------------------------
---[File: scene0.ini]--------------------------
Quality=9
Antialias=on
Antialias_Threshold=0.2
Antialias_Depth=7
Input_File_Name="scene0.pov"
Initial_Frame=1
Final_Frame=120
Subset_Start_Frame=1
Subset_End_Frame=30
Initial_Clock=0
Final_Clock=1
Cyclic_Animation=on
Pause_when_Done=off
-D
+FP
-W640
-H480
---[End of: scene0.ini]------------------
Download 'scene0.mpg' (62 KB)
Subject: Re: A camera-effect
Date: 2 Jan 2007 15:47:48
Message: <459ac4f4@news.povray.org>
All I see is a blue background with some white squares...
...Chambers
Date: 3 Jan 2007 06:45:00
Message: <web.459b964796dec762cc569a010@news.povray.org>
> ...Chambers
Did you read the SDL-script, I had posted ?
If you did not understand this few lines, insert
the following line into the camera-object of one
of your own scenes
  normal{quilted 1}
