POV-Ray : Newsgroups : povray.binaries.animations : ODE simualtion test render Server Time
8 Jul 2024 06:51:47 EDT (-0400)
  ODE simualtion test render (Message 2 to 11 of 11)
<<< Previous 1 Messages Goto Initial 10 Messages
Subject: Re: ODE simualtion test render
Date: 6 Apr 2006 18:40:01
Message: <web.4435983b9fd94bc6a8399d8d0@news.povray.org>
first test as well
Download 'test1a.mpg' (530 KB)
Date: 8 Apr 2006 03:10:01
Message: <web.443760c79fd94bc6a8399d8d0@news.povray.org>
First muscle test.
I'm using this muscle algorithm:
http://www.ai.mit.edu/projects/humanoid-robotics-group/cog/hardware.html
Download 'test2d.mpg' (654 KB)
Date: 9 Apr 2006 14:35:01
Message: <web.443952ae9fd94bc6a8399d8d0@news.povray.org>
W.I.P.
Download 'test3d_small.mpg' (698 KB)
Date: 9 Apr 2006 14:42:29
Message: <44395595$1@news.povray.org>
"Jaap" <jws### [at] yahoocom> wrote in message
news:web.443952ae9fd94bc6a8399d8d0@news.povray.org...
> W.I.P.
Ouch! The pain!
It looks very interesting. :)
Rune
http://runevision.com
Date: 9 Apr 2006 17:36:41
Message: <44397e69$1@news.povray.org>
Jaap wrote:
> W.I.P.
Try a little less beer next time.
    By the time you can afford to buy your
    own candy, you can't afford to eat it.
Date: 10 Apr 2006 10:15:00
Message: <web.443a68049fd94bc61493879e0@news.povray.org>
Darren New <dne### [at] sanrrcom> wrote:
> Jaap wrote:
> > W.I.P.
>    Darren New / San Diego, CA, USA (PST)
Jaap, very good . How can I use the Ode library with Povray OR visual basic.
is there a sample code?
Regards
Hasan
Date: 10 Apr 2006 13:35:00
Message: <web.443a96ff9fd94bc6a8399d8d0@news.povray.org>
ODE is an (open source) software library. It looks like it should work with
Visual basic:
http://www.google.com/search?q=ode+"open+dynamic+engine"+"visual+basic"
I use a simple C program to run the simulation and save the transformation
matrix to a text file:
http://jwstolk.xs4all.nl/wisse/main.c (work in progress, but have a look)
then use the matrix transformation to position and rotate the objects in a
povray file:
http://jwstolk.xs4all.nl/wisse/test2.pov
some swapping withing the transformation matrix is needed, because ODE and
povray use different coordinate systems.
(and finally ffmpeg to turn the rendered frames into an mpg)
Jaap.
Date: 10 Apr 2006 16:47:31
Message: <443ac463$1@news.povray.org>
> Ouch! The pain!
LMAO!
Yeah, it does actually...
Date: 12 Apr 2006 14:40:01
Message: <web.443d49129fd94bc627f6db350@news.povray.org>
I had played around with ODE and POVRay too... take a look at some results:
http://www.basso.inf.br/phi/
This is an old version, the new one will be much better... ;)
Daniel
Date: 12 Apr 2006 18:55:00
Message: <web.443d841e9fd94bc6a8399d8d0@news.povray.org>
> Daniel
very nice !
for everyone following this thread, Update:
I got all the joint to work properly now. I changed the ball and socket
joint to a universal joint, and added a separate joint for the rotation,
because there where some problems with controlling 3 axes joints. This time
I actually had to add a horizontal component to the gravity to make it fall
over. :-)
Please use "save as" for the mpg. You will want to look at it a second time
(I'm hosting my site form a 200 Mhz laptop using my home internet
connection)
http://jwstolk.xs4all.nl/wisse/test4.mpg  (1:2 slow-motion)
http://jwstolk.xs4all.nl/wisse/main4.c    (C source file)
http://jwstolk.xs4all.nl/wisse/test4.pov  (povray source file)
Jaap.
