POV-Ray : Newsgroups : povray.binaries.animations : Re: First animation Server Time
22 Apr 2026 12:57:53 EDT (-0400)
  Re: First animation (Message 7 to 16 of 16)
<<< Previous 6 Messages Goto Initial 10 Messages
Subject: Re: First animation
Date: 14 Sep 2003 14:27:09
Message: <3f64b2fd@news.povray.org>
A reasonable solution would be to make several
stills from various points of view WITH radiosity,
and then try to reproduce that with different
amounts of spotlights, fading light, with/without
shadows, etc. A recent animation, "Runtime" used
the same approach, and several other animation
do it to, because of inconsistencies of radiosity
or global illumination with changing scenery.
Tim
Tim Nikias v2.0
Email: no_lights (@) digitaltwilight.de
> > There were workarounds for this
> I haven't heard of a workaround. Let us know if you find any, please. For
> most animations, I'd stay away from radiosity.
> Regards,
> Hugo
Version: 6.0.515 / Virus Database: 313 - Release Date: 01.09.2003
Date: 14 Sep 2003 14:30:09
Message: <3f64b3b1@news.povray.org>
None wrote:
> I don't have that codec either.  I find it funny all of these codecs now
> that call themselves ISO MPEG-4 compliant... what's the point if none of
> them work together or without special software/codecs?  I mean if you need
> special software/codecs to view/encode it, who cares if it's compliant or
> not?
Of course there is many codecs... We have divx*, xvid, mpeg4*...
For next animations for public release i will use the old good MPEG 1
encoding (files are little more heavy but compatibility is here).
Denis Bodor (aka Lefinnois)
Date: 14 Sep 2003 15:05:34
Message: <ane9mv8u2e9cc6ijgcmcmrdk7eofcjtjdh@4ax.com>
On Sun, 14 Sep 2003 20:07:44 +0200, "Hugo Asm" <hua### [at] post3teledk> wrote:
I remember one with generating radiosity file for one frame and reusing it for
others frames. Other was to use specific radiosity settings (detailed?
simplified?) I do not remember details, sorry. Perhaps memory mistaken me, but
I still have feeling there were a few workarounds presented. I'd stay away
from radiosity, myself, too.
ABX
Date: 14 Sep 2003 16:50:14
Message: <3f64d486@news.povray.org>
Hi everybody!
Can anybody explain to me *why* this happens?
Thanks,
Florian
//=================[web: http://www.torfbold.com]==================\\
#local a=-5;#while(a<5)sphere{<sin(a*pi)*5a*10pow(a,5)*.01>sin(a*a*a*
.1)+1pigment{rgb 9*z}}#local a=a+.01;#end camera{look_at-y*10location
<8,-3,-8>*10}// [www.povray.org]     [www.imp.org]     [www.irtc.org]
Date: 14 Sep 2003 17:55:36
Message: <3f64e3d8@news.povray.org>
The process used to shoot the samples for radiosity
is very much defined by the scenery. It actually
influences the calculations where new samples are
computed. I'm also not sure about the drop-out
of samples when enough are present in a near
vicinity. So, when the scene changes, the samples
get spread differently, even if its just miniscule
movement of one object.
The algorithm for this relies on sort-of spherical
samples. In my oppinion, its something close
to photon mapping, but thats just the interpretation
of samples being stored somewhere in the scene.
Their computation is very different from photon
lightmapping.
Tim
Tim Nikias v2.0
> Hi everybody!
> Thanks,
> Florian
Date: 14 Sep 2003 18:39:00
Message: <3f64ee04@news.povray.org>
"None" <Non### [at] onca> wrote in message
> Denis Bodor <lef### [at] lefinnoisnet> wrote in
> news:3f649350$1@news.povray.org:
> > It is xvid (coded with transcode and tested with mplayer)
> not?
I agree with what you are saying but without new stuff coming through you
would never get improvement or new compression features.
I personally think Xvid is one of the best codecs currently being produced
and has a very good file size to quality ratio.
It would be nice to see this become the standard and instead of the "good
old" mpeg 1 + 2 codecs.
Dave
For those that are interested the site is http://www.xvid.org
Date: 15 Sep 2003 08:17:41
Message: <3f65ade5$1@news.povray.org>
Hi Tim!
I understand what you are saying, but shouldn't it be possible (in
theory) to prevent this by using very high radiosity settings?
Thanks for your answer,
Florian
Date: 15 Sep 2003 20:53:06
Message: <3f665ef2$1@news.povray.org>
The codec problem is partly caused by Microsofts refusal to support by
default codecs which are rivals to its own Windows Media Video format. It's
a shame the Nimo codec pack isn't available for operating systems other than
Windows - if it were, it would be so much easier to keep up to date.
-Chris
Date: 16 Sep 2003 15:56:45
Message: <Xns93F8DF0D51B35raf256com@204.213.191.226>
tor### [at] torfboldcom news:3f65ade5$1@news.povray.org
yes, I did some tests with animating radiosity with diferrent settings.
For scenes like this problems shpuld dissapear with count=300 error=0.25
Date: 17 Sep 2003 08:57:30
Message: <3f685a3a@news.povray.org>
It may reduce the flickering in some images to the extent where it's
nolonger visible. But it's still there.
Hugo
