The process used to shoot the samples for radiosity
is very much defined by the scenery. It actually
influences the calculations where new samples are
computed. I'm also not sure about the drop-out
of samples when enough are present in a near
vicinity. So, when the scene changes, the samples
get spread differently, even if its just miniscule
movement of one object.
The algorithm for this relies on sort-of spherical
samples. In my oppinion, its something close
to photon mapping, but thats just the interpretation
of samples being stored somewhere in the scene.
Their computation is very different from photon
lightmapping.
Tim
Tim Nikias v2.0
Email: no_lights (@) digitaltwilight.de
> Hi everybody!
> Can anybody explain to me *why* this happens?
> Thanks,
> Florian
> //=================[web: http://www.torfbold.com]==================\\
> #local a=-5;#while(a<5)sphere{<sin(a*pi)*5a*10pow(a,5)*.01>sin(a*a*a*
> .1)+1pigment{rgb 9*z}}#local a=a+.01;#end camera{look_at-y*10location
> <8,-3,-8>*10}// [www.povray.org] [www.imp.org] [www.irtc.org]
Version: 6.0.515 / Virus Database: 313 - Release Date: 01.09.2003
"None" <Non### [at] on ca> wrote in message
news:Xns### [at] 204 213 191 226...
> Denis Bodor <lef### [at] lefinnois net> wrote in
> news:3f649350$1@news.povray.org:
> > It is xvid (coded with transcode and tested with mplayer)
> I don't have that codec either. I find it funny all of these codecs now
> that call themselves ISO MPEG-4 compliant... what's the point if none of
> them work together or without special software/codecs? I mean if you need
> special software/codecs to view/encode it, who cares if it's compliant or
> not?
I agree with what you are saying but without new stuff coming through you
would never get improvement or new compression features.
I personally think Xvid is one of the best codecs currently being produced
and has a very good file size to quality ratio.
It would be nice to see this become the standard and instead of the "good
old" mpeg 1 + 2 codecs.
Dave
For those that are interested the site is http://www.xvid.org
Hi Tim!
I understand what you are saying, but shouldn't it be possible (in
theory) to prevent this by using very high radiosity settings?
Thanks for your answer,
Florian
The codec problem is partly caused by Microsofts refusal to support by
default codecs which are rivals to its own Windows Media Video format. It's
a shame the Nimo codec pack isn't available for operating systems other than
Windows - if it were, it would be so much easier to keep up to date.
-Chris
tor### [at] torfbold com news:3f65ade5$1@news.povray.org
yes, I did some tests with animating radiosity with diferrent settings.
For scenes like this problems shpuld dissapear with count=300 error=0.25
It may reduce the flickering in some images to the extent where it's
nolonger visible. But it's still there.
Hugo
