I hope someone can help me here. I'm trying to render an animation
using megapov version 0.7 which I have to use because it uses R
Suzuki's isosurface density file patch .
The problem is that I have a very large data file being loaded using
#declare Ly =
function{
"data_3D_1", <1> library "i_dat3d","data.dat", <100,100,100,0>
Now this takes  a while to load and it is done in each frame so the
animation i want to do will take a long time. All I am doing in the
animation is assigning a pigment based on this function to a plane but
translated by the value of the clock variable.
I've tried adding
Persistant_animation=yes
to the ini file and using labels but it seems the labels cannot be
applied to functions or pigments.
can anyone suggest how I could load the function just once at the
beginning of the animation and use it in each frame ?
Thanks in advance.
Rob Richards
With an unpatched version of POV it will be outright impossible.
Quite right.
I hope this is something that can be addressed in POV 4 - persistent variables
and persistent objects/textures/functions that do not have to be reparsed, but
official POV cannot do this.
-Reactor
We may actually see this in the 3.7 already. The .29 beta source already
contains some code aimed at this, although I'm currently not aware whether the
functionality is already activated in the official beta binaries.
