POV-Ray : Newsgroups : povray.binaries.animations : Re: Explosive Gel (~614 kbu) Server Time
10 Apr 2026 17:50:44 EDT (-0400)
  Re: Explosive Gel (~614 kbu) (Message 1 to 5 of 5)
Subject: Re: Explosive Gel (~614 kbu)
Date: 17 Oct 2001 17:04:16
Message: <dasrst8gmr83ih71i6upak3cb177hk0263@4ax.com>
On Wed, 17 Oct 2001 00:17:15 -0400, "Redbeard \(MDJohnson\)"
<red### [at] wvadelphianet> wrote:
>Here's what happens when you use nitroglycerin gels to experiment with :-)
>Actually, just got a parameter wrong in my simulation.
Yeah, I also got some of these while working on my project :)
Peter Popov ICQ : 15002700
Date: 17 Oct 2001 19:01:48
Message: <3bce0ddc@news.povray.org>
"Peter Popov" <pet### [at] vipbg> wrote in message
news:dasrst8gmr83ih71i6upak3cb177hk0263@4ax.com...
Peter,
    I was just wondering when we will get to see the results of your work
being available for POV-Ray. I'm eager to get animating.... ;-)
All the best,
Andy Cocker
Date: 21 Oct 2001 08:02:58
Message: <nkb5ttoptllpg6dkkbp20q7si75npati08@4ax.com>
On Wed, 17 Oct 2001 23:59:36 +0100, "Andy Cocker"
I still have a lot of things to fix.
First of all, I am using regular hexahedron finite elements (cubes :))
and this makes meshing, well, a bit tricky. I want to use irregular
tetrahedrons but I have trouble developing a meshing algorithm.
Also, it turns out that forward Euler integration is very unstable. I
have to read into central differences, Adams and Runge-Kutta
integration methods and choose the one that fits best (fast enough,
and understandable by me).
I have yet to test the collision routine that I made up as it only
looks theoretically correct.
I guess the point-could shape representation that I am using now is
not very suitable for raytracing so I'll have to do some reading into
NURBS and DNURBS and/or try to dig my way though POV's mesh code, in
which case I will have to go through OpenGL and X programming, which
is a nightmare in its own right.
All this requires a lot of time to read, and access to materials which
are, for the moment, beyond my reach. I have a list of about 40 ASME
or SIGGRAPH publications I want to get my hands on. and that list
doesn't even cover the aforementioned items.
I am thinking of publishing the code. I have a CVS server running at
home but I have to talk my brother into changing the paranoid firewall
settings he's put up. Plus, the code is a mess I'm ashamed of :(
To answer your question briefly -- sadly, it won't be soon.
Date: 21 Oct 2001 11:02:58
Message: <3bd2e3a2@news.povray.org>
news:nkb5ttoptllpg6dkkbp20q7si75npati08@4ax.com...
I'm sorry to hear that. Thanks for your reply.
All the best,
Andy Cocker
Date: 21 Oct 2001 13:04:36
Message: <3bd30024@news.povray.org>
Hmmm... I have some ideas for rendering this... My simulation uses a grid of
points that I'm giong to convert into irregular tatrahedrons.  I've got some
mesh ideas and some solid modeling ideas (which I would prefer - since it can be
used for CSG)  When I get them worked out I'll post an anim and the code for the
render part.
Michael
