POV-Ray : Newsgroups : povray.binaries.animations : elastic cube 2 (1.1 MB) Server Time
30 Sep 2024 16:16:46 EDT (-0400)
  elastic cube 2 (1.1 MB) (Message 1 to 5 of 5)
Subject: elastic cube 2 (1.1 MB)
Date: 18 May 2002 21:56:01
Message: <Xns90A628087F7C2gergelyvamoraviaitco@204.213.191.226>
Sorry about the size, I'm too lazy to create a smaller one.
No new features, just stiffer springs and some initial velocity to make
Tim happy. Also, the extension is mpg now to make the browsers happy.
http://www.progressive.hu/gero/egybeek.mpg
Cristoph: here's a pic to show the spring arrangement. All of the
cylinders are springs starting from the yellow (corner) node. Maybe it's
understandable now, if it isn't, I give up. :) So the green springs are
twice the length as others, connecting every second node. I dunno if
that's any good, I just read about it somewhere, and I liked the idea.
Do you think I should also connect the yellow with the cyan colored one?
http://www.progressive.hu/gero/springs.jpg
BTW, I think I've come up with a solution for damping. Take two
consecutive timesteps, and measure how much the distance of two connected
nodes changes. This way you get the relative speed of these two nodes,
which you can use to calculate the damping of the spring connecting them.
This should work I guess.
Cheers,
Gergely
Subject: Re: elastic cube 2 (1.1 MB)
Date: 19 May 2002 05:03:08
Message: <3CE76A2E.B877878E@gmx.de>
Hey, that looks really cool!
You should consider if you can implement some sort
of code to check if the cube is moving very slowly,
and then just stop it. It jiggles and wiggles a bit
in those last seconds...
Can you place two of those cubes into one
animation, bouncing and repelling each other?
That would be neat.
Haven't got the time to download the second
animation right now, but I'll do that later...
And I am happy... ;)
> Cheers,
> Gergely
Tim Nikias
Email: Tim### [at] gmxde
Date: 19 May 2002 05:11:26
Message: <3ce76c3e$1@news.povray.org>
I think gravity is to weak
PGP Public Key
Date: 19 May 2002 19:20:14
Message: <3ce8332e$1@news.povray.org>
Use Runge-Kutta and you'll get rid of all the noisy movements. But I like
the gello-like movements! Could you make us a watery pudding thingy?
Apache
http://geitenkaas.dns2go.com/experiments/
apa### [at] yahoocom
Date: 23 May 2002 11:21:50
Message: <3CED090D.A33FB984@gmx.de>
Sorry for the late reply, i have been away for the last few days.  I
understand your system now, the purpose of the green springs is to create
bending elasticity (they are only compressed, not expanded).  I have not
tried this technique so far, but it could be useful (although linear
elasticity would probably not be very good in this case).
This is about what i tried (i'm storing the speed of each mass so
calculating the relative speed is no problem). But math is not that
simple, especially not whan working with functions.
Last updated 05 May. 2002 _____./\/^>_*_<^\/\.______
