POV-Ray : Newsgroups : povray.binaries.animations : Looking at font file content as mp4 Server Time
16 Sep 2025 10:36:03 EDT (-0400)
  Looking at font file content as mp4 (Message 1 to 10 of 10)
Subject: Looking at font file content as mp4
Date: 8 Mar 2025 21:26:42
Message: <67ccfc62@news.povray.org>
Partly due running down a bug in the text{} object; partly to test
yuqk's bool_object{} pattern with multiple objects (10 text{} objects
here); I've created animations of some mono font files.
With each font I rendered an animation at 50 characters per frame for
the entire Basic Multilingual Plane (BMP) of 2^16 possible characters. I
kept only those frames showing at least one supported character glyph
and I created an mp4 with those frame images at 1 per second.
The thought is maybe this is a good way to review what characters are
supported in a particular font alongside how POV-Ray is handling those
characters.
Attached is an animation of the hack-r font. It's a popular linux / unix
programmer's mono font.
Bill P.
Download 'hackrfont.mp4.dat' (1668 KB)
Subject: Re: Looking at font file content as mp4
Date: 9 Mar 2025 05:30:00
Message: <web.67cd5e736c6ae2bec342f2ec6cde94f1@news.povray.org>
hi,
> characters.
fwiw, agree.  I do like the "presentation".
ideally you'd post a scene file / ini combo too, where one only needs to change
the name of the font.  (tia :-))
regards, jr.
Date: 9 Mar 2025 09:45:00
Message: <web.67cd9b576c6ae2be1f9dae3025979125@news.povray.org>
Is there a significance to various parts of that plane?
Can you represent it like an RGB space so you can see the (valid) character
density?  Maybe a pie chart?  Histogram?
Esp if you wanted to compare several font charts in the same render.
- BW
Date: 9 Mar 2025 14:25:35
Message: <67cddd1f$1@news.povray.org>
My slightly cleaned up 'working files / code' attached. Unsure yet how
I'll include this code in the yuqk distribution.
Thinking aloud. There is in the posted 'Hack-Regular' and the
'LiberationMono-Regular' a few character collapses of width not seen
with 'UbuntuMono-R'. Also some character stand ins which differ between
fonts - and it isn't clear to me why of these get used as they do.
The Ubuntu font is the only one which includes the 65533 character for
code points beyond the BMP. It's interesting to me too how the fonts
differ in the one-off characters they support.
Anyhow...
Bill P.
Download 'boolobjplay.pov.txt' (7 KB) Download 'determinecharacterwandh.inc.txt' (2 KB) Download 'reducefontframes.txt' (3 KB)
Date: 9 Mar 2025 14:41:46
Message: <67cde0ea$1@news.povray.org>
https://en.wikipedia.org/wiki/Plane_(Unicode)
Yes, I expect other representations are possible. Ive not given it any
detailed thought.
Many work and play with fonts. There are tools available which offer
other ways to query and present information about a font files. In years
past I've used a few of them - but other than ttfdump, my memory is
failing me at the moment. :-)
Aside: I have on my list to make a go at creating polygon{} font-derived
character objects somewhat automatically using the ttfdump output given
yuqk's new potential pattern support for the polygon{} object, but we'll
see.
Bill P.
Date: 9 Mar 2025 23:40:23
Message: <67ce5f27$1@news.povray.org>
> characters.
> Bill P.
I once did something similar. The difference was that I had 256
characters per frame and the character number was not clearly displayed.
The columns where the hexadecimal unit, the line was the second digit,
and the frame number for the third+ digit.
Date: 10 Mar 2025 02:55:00
Message: <web.67ce8ba56c6ae2bec342f2ec6cde94f1@news.povray.org>
hi,
> Anyhow...
_thank_you_.  (tonight, I guess :-))
> ...other ways to query and present information about a font files.
in SDL.  the 'tabulated' macro comes with a shell script to view the first four
"pages" of glyphs, but would be easy "to monkey" to output an arbitrary set.
(fwiw)
regards, jr.
Date: 10 Mar 2025 10:05:00
Message: <web.67cef0e46c6ae2bec342f2ec6cde94f1@news.povray.org>
hi,
ran into trouble straightaway (sorry).  tried with a couple of different fonts
and keep getting a (the same) negative character width ?  (see attached)  I can
access the first 4 pages/1024 glyphs in the font ('streetsign.ttf') ok using a
different scene.  using yuqk a5c25dda.
regards, jr.
Download 'strlen_problem.png' (9 KB)
Preview of image 'strlen_problem.png'
Date: 11 Mar 2025 06:16:07
Message: <67d00d67$1@news.povray.org>
Ah, guessing you didn't run as an animation? (The +kff1311 at the top of
the boolObjPlay.pov file)
Me offering an excuse. :-) The scene should run frame 1 without using an
animation setting. Change the line:
#local I = (frame_number-1)*CharsPerPage;
to
#local I = max(0,frame_number-1)*CharsPerPage;
Bill P.
Aside: The 'frame_number' is set to zero, if not running an animation -
or if you try to render only the first frame with '+kfi1 +kff1' (+kfi2
+kff2 works as does rendering any single frame >2)(*).
(*) Yep. The '+kfi1 +kff1' flags not working for frame 1 is quirky. On
my list to look at it some day. I'm afraid to just change behavior
without thinking more about why things might be set up as they are...
Aside 2: Be forewarned. I did the character image comparisons with SDL
so the entire animation takes many hours for typically sparse BMP font
implementations.
Date: 11 Mar 2025 14:40:00
Message: <web.67d083166c6ae2bec342f2ec6cde94f1@news.povray.org>
hi,
> > ran into trouble straightaway (sorry).  ...
ok, got it, thanks.
regards, jr.
