POV-Ray : Newsgroups : povray.binaries.animations : Testing bump_map and ii_offset. Server Time
10 Jun 2026 11:14:24 EDT (-0400)
  Testing bump_map and ii_offset. (Message 1 to 1 of 1)
Subject: Testing bump_map and ii_offset.
Date: 15 Feb 2025 12:20:52
Message: <67b0ccf4@news.povray.org>
Attached is a derivative of one of my recent testing animations for the
bump_map{} updates.
The set up is simple. It relies on one of two long undocumented features
shipped with POV-Ray in 'offset' (called 'ii_offset' in the yuqk fork).
With it one can start an image outside of the usual <0,0> to <1,1>
square image area variously mapped onto surfaces - and with 'ii_offset'
slowly move the image through the unit square based upon the frame_number.
The essential bit of code is:
     #declare Nrml00 = normal {
         bump_map {
             "hmmI.png" gamma 1.0
             ii_interpolate   2
             ii_map_type      1
             ii_once
             #if     (frame_number>0 & frame_number<=150)
                 ii_offset <-1.1+(2.2/300)*frame_number,0>
             #elseif (frame_number>150 & frame_number<=300)
                 ii_offset <0,0>
             #else
                 ii_offset <-1.1+(2.2/300)*(frame_number-150),0>
     union {
         sphere { 0, 1
             pigment { rgb 1 }
             normal { Nrml00 bump_size +127 rotate +60*y}
         sphere {
             <1,1,0>/sqrt(2), 0.02
             pigment {rgb <1,0,0> }
             rotate +60*y
         #if (frame_number>150 & frame_number<=300)
             rotate <0,-(frame_number-150)/150*360,0>
And when rendering add +kff450 to the command line.
Bill P.
Aside: The other long undocumented feature is 'repeat <2d vector>' or
'ii_repeat' in the yuqk fork. With 'ii_repeat' one can both scale and
repeat images within the 2D unit image space, but it's not used here.
Download 'ii_offset.mp4.dat' (885 KB)
