POV-Ray : Newsgroups : povray.binaries.animations : Pannellum Server Time
25 Apr 2024 07:45:32 EDT (-0400)
  Pannellum (Message 11 to 20 of 23)
<<< Previous 10 Messages Goto Latest 10 Messages Next 3 Messages >>>
Subject: Re: Pannellum
Date: 4 Apr 2017 09:25:36
Message: <58e39ed0$1@news.povray.org>
Am 03.04.2017 um 21:47 schrieb omniverse:
> What is really strange about it, to me, is how one of the nearby artifacts
> (after moving scene around) appears to have a 90 degree angle going on.
> The square shapes form a sort of floor and wall, if thinking of it as partially
> covering tiles without seams where they meet.
> Hopefully you can see or find that too.
My guess is that the 360 degree image format is using a cube model, and
what you see is the edge of that box.
Date: 4 Apr 2017 09:27:55
Message: <58e39f5b$1@news.povray.org>
Am 04.04.2017 um 11:59 schrieb Kenneth:
> Mike Horvath <mik### [at] gmailcom> wrote:
>> Here are my global settings. Radiosity is disabled.
>> global_settings
>>  charset utf8
> [snip]
> Although I haven't seen your animation yet, the   charset utf  entry caught my
> eye. Wasn't there another recent post about artefacts due to that? I think it
> was in the post about the "Dokken" logo not rendering correctly.
"charset utf8" can't give you genuine render artifacts. It can only give
you wrong character shapes in a `text` object.
Date: 4 Apr 2017 22:17:03
Message: <58e4539f$1@news.povray.org>
Yes, it uses 6 images to form a cube map. The artifacts are distributed
randomly across each of the 6 images.
Mike
Date: 4 Apr 2017 22:21:18
Message: <58e4549e$1@news.povray.org>
On 4/2/2017 9:08 PM, Mike Horvath wrote:
> On 4/2/2017 8:52 PM, Mike Horvath wrote:
>> I updated my spaceship scene and rendered new frames to be used with
>> Pannellum panorama viewer.
>> http://isometricland.net/panorama/pannellum.htm?config=pano-gh-scene-spinner.json
>> I still was not able to turn the interior atmosphere due to render
>> times. Even on the 16-core MS Azure server I am using for my renders
>> this month, things were taking too long.
>> Enjoy.
>> Mike
> Forgot to mention there are strange square shaped artifacts in the blue
> end caps of the scene. They exist in the source images as well. I don't
> know what causes them.
> Mike
Forgot to say I think the artifacts are the same size as the "render
blocks" (or whatever they're called) when rendering any scene. Sort of
like the mosaic preview.
Mike
Date: 6 Apr 2017 18:15:44
Message: <58e6be10$1@news.povray.org>
> Enjoy.
> Mike
I rendered a higher resolution version of the scene.
It includes some but not all of the fixes I have been working on over
the last few days. I will probably do another render sometime soon,
though not at the same high resolution because it takes so long.
Mike
Date: 6 Apr 2017 18:35:27
Message: <58e6c2af$1@news.povray.org>
>> Enjoy.
>> Mike
Okay I'll bite. How long did it take?
It is really good.
What's puzzling me is what looks like a shadow along the three arms of
the support.
Regards
Date: 6 Apr 2017 20:05:12
Message: <58e6d7b8@news.povray.org>
It took 2-3 days on a rented Microsoft Azure server. On my home PC it
would have taken 7-10 days I think. That's without the atmospheric media
I wanted to use in the scene, or the radiosity.
> It is really good.
Thanks! I have been working on it since ~2010 I think. Maybe earlier.
> the support.
I don't know either.
Mike
Date: 6 Apr 2017 20:34:21
Message: <58e6de8d$1@news.povray.org>
Ah! that's not CPU ticks I hear. It is the sound of cents draining out
of your pocket. ;)
It was worth it. :)
>> It is really good.
I remember the early posts and versions. Then you went quiet.
>> the support.
The strange thing is it looks familiar. I used a similar shape for a
flywheel, years ago.
Regards
Date: 6 Apr 2017 22:51:04
Message: <58e6fe98$1@news.povray.org>
> of your pocket. ;)
> It was worth it. :)
Well, I am using the free trial period/balance you get when you create
an account. You get $200 which you can spend in 30 days. I have almost
used all $200.
Google offers $300 that you can spend in 12 months, as well as a
discount if you use Linux instead of Windows. I will be doing that next.
>>> It is really good.
I put it aside as render times were getting too long using just my home
PC. I am impatient.
>>> the support.
The "caps" on each end of the habitat are actually a little concave,
too, like a dish. Maybe that is influencing the render?
Mike
Date: 7 Apr 2017 06:09:50
Message: <58e7656e$1@news.povray.org>
>> of your pocket. ;)
>> It was worth it. :)
> used all $200.
It is certainly cheaper and tidier than buying hardware.
>>>> It is really good.
> PC. I am impatient.
I've lost count of the projects I've abandoned for that reason.
>>>> the support.
I've had a look at some of my old files and think I must be remembering
one of your original posts that puzzled me. (At least my long term
memory is still working. ;) )
Regards
