On 12/10/2016 07:50 AM, Mike Horvath wrote:
> On 12/9/2016 12:55 PM, William F Pokorny wrote:
>> On 12/08/2016 09:36 PM, Mike Horvath wrote:
>>> If I rotate the camera 90 degrees around the x axis, the isosurface
>>> disappears.
>>> Mike
>> Is there any chance the camera is ending up inside the contained_by
>> shape for the isosurface?
>> Bill P.
> I don't think so. My camera is 17 units away from the origin, and the
> contained_by area is only 1 unit wide.
> (These values then get scaled by 200000.)
> Mike
OK - it was a shot in the dark. I've not followed your color space
function() development.
A suggesting is trying the isosurface coded in your scene at a rotations
around where it is breaking up, at a low resolution, no aa+, area light,
etc., as
isosurface {
not used by reference (github #114 (#113 is related)), so you get some
idea what the max gradient really is and how it is changing.
Bill P.
Am 11.12.2016 um 15:09 schrieb William F Pokorny:
> etc., as
> isosurface {
Thanks for bringing this report and analysis up again; I had wondered
recently why my own toying-around with Mike's isosurfaces didn't prompt
any max gradient warnings, but didn't take the time to investigate.
I've just published a new version that supersedes the offending
mechanism with something smarter, and should again report the max
gradient as expected, for each and every isosurface actually rendered,
yet aggregating the results for any clones.
https://github.com/POV-Ray/povray/releases/tag/v3.7.1-alpha.8913469
>>>> disappears.
>>>> Mike
>>> Bill P.
>> Mike
> etc., as
> isosurface {
> Bill P.
I don't understand. What are you saying?
Mike
Am 12.12.2016 um 00:51 schrieb Mike Horvath:
>> etc., as
>> isosurface {
>> Bill P.
He's suggesting that rather than
#declare Whatever = isosurface {...}
object { Whatever }
you should use (at least temporarily)
isosurface {...}
as this will allow POV-Ray to give you a warning if it thinks your
max_gradient is a poor choice (whether unnecessarily high or too low).
Alternatively, use the brand-new development release I posted about a
couple of minutes ago, which should be able to do the same stunt without
any changes to your scene file.
>>> etc., as
>>> isosurface {
>>> Bill P.
> object { Whatever }
> isosurface {...}
"Shutdown Warning: The maximum gradient found was 32.504, but
max_gradient of the isosurface was set to 100.000. Adjust max_gradient
to get a faster rendering of the isosurface."
According to this, max_gradient setting is not the problem, right?
Mike
> disappears.
> Mike
I'm not sure why, but increasing the contained_by box fixed the problem.
I used:
contained_by
box {-1,1}
instead of:
contained_by
box {0,1}
Mike
Am 12.12.2016 um 03:11 schrieb Mike Horvath:
Right.
Am 12.12.2016 um 04:09 schrieb Mike Horvath:
>> disappears.
>> Mike
> I used:
> contained_by
> box {-1,1}
> instead of:
> contained_by
> box {0,1}
Maybe your functions have numeric instabilities near x=0, y=0 or z=0;
choosing a bounding box that does not coincide with these values would
drastically reduce the chance of the isosurface alhorithm hitting those
locations exactly, and it might now just skip over that ditch.
>> etc., as
>> isosurface {
This update will be very useful to me. Thanks much! :-)
Bill P.
