POV-Ray : Newsgroups : povray.binaries.animations : CIE xyY / D65 gamut Server Time
10 Jun 2026 15:39:32 EDT (-0400)
  CIE xyY / D65 gamut (Message 11 to 17 of 17)
Subject: Re: CIE xyY / D65 gamut
Date: 10 Dec 2016 19:24:55
Message: <584c9cd7@news.povray.org>
Am 11.12.2016 um 01:12 schrieb clipka:
> Am 11.12.2016 um 00:09 schrieb Mike Horvath:
>> On 11/29/2016 10:56 PM, clipka wrote:
>>> Gamut of all theoretically possible surface colours, under D65 (noon
>>> daylight) illumination, in CIE 1931 xyY space.
>> How did you generate the meshes?
> "It's complicated."
Oh, and of course for the sake of parsing performance I used `#write` to
generate the mesh as a POV-Ray include file, safeguarding the code using
`#if (file_exists(...))`, and then used `#include` to load it.
Date: 18 Mar 2017 22:11:15
Message: <58cde8c3$1@news.povray.org>
Did you use radiosity or emission? I am trying to render the same shape
but in my scene the shadows are not well defined.
Mike
Date: 19 Mar 2017 17:58:27
Message: <58ceff03$1@news.povray.org>
Am 19.03.2017 um 03:11 schrieb Mike Horvath:
Radiosity, most surely. I can't stand the look of scenes that don't use it.
I did need some twiddling of the radiosity settings to make it look good
though. I guess I did specify a rather low "maximum_reuse" setting.
Date: 20 Mar 2017 08:21:24
Message: <58cfc944$1@news.povray.org>
Am 20.03.2017 um 02:21 schrieb Mike Horvath:
> Here's my version, thanks to clipka and Bruce Lindbloom.
That looks about right now.
You seem to have a gap between the shape and the "black pane" though,
which is particularly noticeable in the yellow and green regions.
I'd therefore recommend investing a bit of extra work to make the shape
extend to the black point -- or, more precisely, the locus of
infinitesimally dark spectral colours.
Date: 20 Mar 2017 09:52:13
Message: <58cfde8d@news.povray.org>
I'm not sure what to do with black. It's degenerate in xyY space, isn't
it? I get divide-by-zero errors when converting from XYZ.
Mike
Date: 20 Mar 2017 11:48:44
Message: <58cff9dc@news.povray.org>
Am 20.03.2017 um 14:52 schrieb Mike Horvath:
That's why you need to go for infinitesimally dark colours instead: Set
all wavelengths to zero, except for a single wavelength which you set to
a darn small power like, say, 1e-3.
Date: 20 Mar 2017 15:42:39
Message: <58d030af$1@news.povray.org>
I ended up just replacing that bottom row with the standard 2D xy
chromaticity diagram, but colored black.
Thanks for catching the issue! I would not have noticed it myself.
Mike
