POV-Ray : Newsgroups : povray.binaries.animations : Roller Coaster WIP 6 (MPEG1 Link: 4.7 MB) Server Time
29 Sep 2024 10:14:58 EDT (-0400)
  Roller Coaster WIP 6 (MPEG1 Link: 4.7 MB) (Message 1 to 10 of 16)
Subject: Roller Coaster WIP 6 (MPEG1 Link: 4.7 MB)
Date: 1 May 2006 14:31:18
Message: <445653f6$1@news.povray.org>
http://www.sohcahtoa.net/videos/amazinggrace.m1v
This roller coaster is called Amazing Grace.  It was designed by RiscIt,
one of the admins of CoasterSims.com.  The actual track looks FAR better
in No Limits, because he uses terrain and 3DS objects, both of which I
have not implemented yet.  Also, the lack of supports kind of takes a
bit away from the feel of the ride.
That said, this represents the fact that I've fixed my banking problem
in that corkscrews and loops work (See my post on p.general), though
loops with little lateral movement will show a glitch, which shows
itself in one of the loops in this ride.
I need to change the method of interpolation though...through the
corkscrews, the ride kind of wobbles because the interpolation is
linear.  I know that No Limits uses some sort of bezier interpolation,
but I'm not sure how exactly to implement it for banking.  I might
settle for 3rd order b-spline interpolation.  While it may end up being
very smooth, it won't be as accurate to the original track.
-DJ
Subject: Re: Roller Coaster WIP 6 (MPEG1 Link: 4.7 MB)
Date: 1 May 2006 16:57:39
Message: <44567643@news.povray.org>
Simply amazing... There's something to be said for framerates, and
having a constant one :)  My computer is, unfortunately, old enough that
the coaster sims struggle a lot.  I also like the shadows.  Overall, it
gave me a much more favorable impression than RCT does.  Good job!
...Chambers
Date: 1 May 2006 18:39:06
Message: <44568e0a$1@news.povray.org>
> ...Chambers
Currently re-rendering it using 600 fps...the plan is to turn it into 60
fps with 10-sample motion blur.  Its gonna look SMOOOOOOOOTH.
Meanwhile, I'll be working on getting supports going.
-DJ
Date: 1 May 2006 23:16:41
Message: <4456cf19$1@news.povray.org>
> -DJ
I've cancelled this render.  Its going to take too long.  I'd rather
save that kind of render for when I get terrain and supports done, that
way it looks perfect.
-DJ
Date: 2 May 2006 08:17:05
Message: <44574dc1$1@news.povray.org>
If you require any rendering done I have a lot of CPU time I could
spare.  Also I get to see how you are working things ;)
Let me know.
Dave.
DJ Wiza wrote:
>> 60 fps with 10-sample motion blur.  Its gonna look SMOOOOOOOOTH.
>> -DJ
> -DJ
Date: 2 May 2006 08:30:00
Message: <web.44574ff0da50bd70e62e73ff0@news.povray.org>
Man! This track is insane! 8-O
If anybody will ever build this please let me know :D
I'm glad you could fix the corkscrew problem and i hope you'll get this loop
thingy fixed as well!
Would it be a problem to provide another Divx version of that one like you
did the last times? it just looks much better that way.
If you need a few extra frames to be rendered (or webspace for divx versions
;)) i could help you with that as well. Just let me know.
Waiting for more to come!
Regards Roman
Date: 2 May 2006 09:00:00
Message: <web.445757a7da50bd706c4803960@news.povray.org>
> -DJ
Got any barf bags?  That was kind of fun.
As a note, you have a kink in your track, ascending the loop at about the
38sec mark.
-tgq
Date: 2 May 2006 14:36:20
Message: <4457a6a4$1@news.povray.org>
>>-DJ
> 38sec mark.
> -tgq
I know about the kink, that's why I noted above that vertical loops with
very little lateral movement will show a glitch.
The problem is with vertical track.  If a track is exactly 90 degrees
down, how do you know which way is up?  To make an up vector, I use
VPerp_To_Plane to find a vector that is perpendicular to a plane defined
by a vector that points "foward" along the track and the vector y.  This
creates a vector pointing right.  I then use vaxis_rotate to rotate that
by the amount of banking defined by the track.
Of course, this creates the problem that as track gets closer and closer
to going 90 degrees either straight up or down, you get rounding errors
that result in those kinks.
The author of No Limits found a way around it by allowing the user to
specify that a banking angle is "relative" to the previous control
points banking.  Not sure how I could implement that though.  I might
have to do a lot of reworking.
-DJ
Date: 2 May 2006 14:38:47
Message: <4457a737@news.povray.org>
> Let me know.
> Dave.
Test renders are quick.  Because I'm using spheres/cylinders rather than
sphere_sweeps, it only takes about 6 seconds per frame, and most of my
test renders are just single frames to make sure something is being
calculated correctly.
-DJ
Date: 2 May 2006 15:42:22
Message: <4457b61e@news.povray.org>
I've once written a small script to create a mesh-tube running along a
spline, and ran into similiar problems. What was suggested to me then by
Rune and someone else who's name I've forgotten (sorry) to update the
up-vector successively, instead of independantly for each frame (in my case,
for every ring of the tube, in your case, it's the frames).
I start with the initial direction I'm heading to, and an initial up vector.
On the next frame, use the old up-vector, and double vcross it with the new
direction to get the new up-vector.
  #local Up = vnormalize(vcross(vcross(New_Direction,Last_Up),
New_Direction));
Since the new direction and the old up-vector aren't perpendicular, you'll
create a new up-vector that is aligned along the plane defined by the old
up-vector and new-direction... Quite simple, once you think it through.
Additionally, since this only affects corkscrew or other loopings, you could
create a parsing step that'll just do that when it's needed. Needs a little
more though, but would be worthwhile in case you plan on distributing the
render and making the animation independant of former frames.
Tim
aka "Tim Nikias"
