POV-Ray : Newsgroups : povray.binaries.animations : help debug my 1.1 mechsim anim Server Time
29 Sep 2024 18:14:30 EDT (-0400)
  help debug my 1.1 mechsim anim (Message 1 to 6 of 6)
Subject: help debug my 1.1 mechsim anim
Date: 18 Oct 2004 21:30:38
Message: <41746e3e@news.povray.org>
using 1.1
I was trying to get it to bounce of a slanted plane, but it comes to rest on
a non-existent plane.
Download 'blocksu01.pov.txt' (3 KB) Download 'blocksu0101.mpg' (228 KB)
Subject: Re: help debug my 1.1 mechsim anim
Date: 18 Oct 2004 23:17:40
Message: <cv8UUGA6cIdBFwWN@econym.demon.co.uk>
Wasn't it Greg M. Johnson who wrote:
>using 1.1
You've rigged your camera in such a way that the z plane is horizontal,
so your "#declare fn_Env = function { z }" creates a ground plane which
you include in your environment block (so that the objects bounce off
it) but you never render it.
Mike Williams
Gentleman of Leisure
Date: 19 Oct 2004 07:24:42
Message: <4174f97a$1@news.povray.org>
okay cool, thanks for the info.
How would one simply add a sphere?
"Mike Williams" <nos### [at] econymdemoncouk> wrote in message
news:cv8### [at] econymdemoncouk...
> >using 1.1
on
> Mike Williams
Date: 19 Oct 2004 10:18:55
Message: <xmmP2AATwRdBFwDM@econym.demon.co.uk>
I believe that in 1.1 you can use any object as the environment, so that
presumably allows you to something like this:
#declare Obj_Env = union {
  object {plane2}
  sphere {0,1}
environment {
  object Obj_Env
  stiffness 240000
  damping 35000
  friction 0.2, 1.001
Or you can combine two functions, which will also work with versions
that only work with particular types of object.
#declare fn_Env = function { min( (z+x) , f_sphere(x,y,z,1) ) }
environment {
  function { fn_Env(x, y, z) }
  stiffness 240000
  damping 35000
  friction 0.2, 1.001
[If you use both an object and a function, it ignores the object.]
Mike Williams
Date: 20 Oct 2004 12:45:00
Message: <web.41769534fda580d440d56c170@news.povray.org>
Mike, I cannot get it to work.  Consider this code:
// Persistence Of Vision Ray Tracer Scene Description File
// File: @(#)blocks.pov
// Description: mechanics simulation sample scene [without iso-defined
objects]
// Features demonstrated: mechsim
// Creation Date: $ 14 Oct 2002, 16:55:14 $
// Last modified: $ 12 Jul 2004, 22:36:49 $
// Author: Christoph Hormann
// major modifications by Greg M. Johnson
// @@ Demonstrating groups and mass-face-collisions.
// Render instructions:
// First render as still with:
// -w320 -h240
// Then as animation with:
// -w320 -h240 +a0.3 -j +kff70
#version unofficial megapov 1.1;
#include "mechsim.inc"
#declare Trans1 =
  transform {
    translate -1.5*<0.7, 0.7, 0>
    rotate -40*z
    translate 1.8*x
    translate 0.5*z
#declare Trans2 =
  transform {
    rotate 25*z
    translate -2.1*x
    translate 0.5*z
#declare Trans3 =
  transform {
    translate -<4*0.55, 0.55, 0>
    translate 2.9*z
#declare Envy=union{
        sphere{0,2 pigment {rgb 0.5} finish {reflection 0.3} translate -2*z}
        sphere{x*4,1 pigment {rgb 0.5} finish {reflection 0.3} rotate 0*z
translate -2*z}
        sphere{x*4,1 pigment {rgb 0.5} finish {reflection 0.3} rotate 60*z
translate -2*z}
        sphere{x*4,1 pigment {rgb 0.5} finish {reflection 0.3} rotate 120*z
translate -2*z}
        sphere{x*4,1 pigment {rgb 0.5} finish {reflection 0.3} rotate 180*z
translate -2*z}
        sphere{x*4,1 pigment {rgb 0.5} finish {reflection 0.3} rotate 240*z
translate -2*z}
        sphere{x*4,1 pigment {rgb 0.5} finish {reflection 0.3} rotate 300*z
translate -2*z}
        plane{z,-3 pigment {rgb 1 }  finish { ambient 0.05 diffuse 0.45 }}
object{Envy}
global_settings {
  max_trace_level 10
  assumed_gamma 1
  mechsim {
    gravity <0, 0, -9.81>
    method 2
    bounding 3
    environment {
      //function { fn_Env(x, y, z) }
      object Envy
      stiffness 240000
      damping 35000
      friction 0.2, 1.001
    collision {
      2, 2
      stiffness 180000
      damping 30000 //5000
      friction 0.2, 1.001
    #if (clock_on)
      step_count 300 //500
      time_step (1/30)/300 //500
      topology {
 load_file "blocks1.dat"
 save_file "blocks1.dat"
    #else
      step_count 0
      topology {
        #declare Stiff=24000;
        #declare Damp=3000;
        //#declare Stiff=52000;
        //#declare Damp=2500;
        group {
   MechSim_Generate_Grid_Std(<0, 0, 0>, 0.1, 22000, Stiff, Damp, true, <0.7,
0.7, 0.7>, <4, 4, 4>, Trans1, 3)
        group {
0.7, 0.7>, <4, 4, 4>, Trans2, 3)
        group {
<0.55, 0.55, 0.55>, <9, 3, 3>, Trans3, 3)
//MechSim_Show_All_Objects(-1, true, false, "")
MechSim_Show_Grid(0, 4,4,4, true, false, 0, "")
MechSim_Show_Grid(108, 4,4,4, true, false, 0, "")
MechSim_Show_Grid(216, 9, 3, 3, true, false, 0, "")
  location    <15, -10, 3.5>*1.4
  direction   y
  sky         z
  up          z
  right       (4/3)*x
  look_at     <0, 0, 0.>
  angle       30
light_source {
  <3.2, -0.3, 1.8>*100000
  color rgb <1.6, 1.5, 1.0>
sky_sphere {
    gradient z
    color_map {
      [0.00 rgb <0.8,0.9,1.0>]
      [0.10 rgb <0.6,0.7,1.0>]
      [0.25 rgb <0.2,0.3,0.8>]
//---------end of SDL
Date: 20 Oct 2004 14:38:18
Message: <99dTBBA9BrdBFwCo@econym.demon.co.uk>
Did you notice the warning that object environments are not recommended
with higher order integration methods?
I'd suggest either using integration method 1, or using a function
environment.
Here's your scene with method 2 and a function environment. I've chosen
to RENDER the equivalent object and just use the function for the
mechsim environment calculation, because the isosurface renders slowly.
If you're not comfortable with writing your own functions, then
consider getting hold of isocsg.
// Description: mechanics simulation sample scene [with iso-defined objects]
// -w320 -h240
#declare Trans1 =
  transform {
    rotate -40*z
    translate 1.8*x
    translate 0.5*z
#declare Trans2 =
  transform {
    rotate 25*z
    translate -2.1*x
    translate 0.5*z
#declare Trans3 =
  transform {
    translate 2.9*z
#include "functions.inc"
#declare F_plane=function{z+3}
#declare fn_Env=function {min (
   F_plane(x,y,z),
   #declare N=0;
   #while (N<6)
     f_sphere(x-4*cos(N*pi/3),y-4*sin(N*pi/3),z+2,1),
     #declare N=N+1;
   f_sphere(x,y,z+2,2)
translate -2*z}
translate -2*z}
translate -2*z}
translate -2*z}
translate -2*z}
translate -2*z}
// Use this for rendering because it's faster
object{Envy}
// Use this if you want to check that fn_Env actually matches the "Envy" object
//isosurface {function {fn_Env(x,y,z)}
//  contained_by {box{ <-20,-20,-4><20,20,3>}}
//  pigment {rgb 0.5}
global_settings {
  max_trace_level 10
  assumed_gamma 1
  mechsim {
    method 2
    bounding 3
    environment {
      // use this for simulating because object environments
      // may not work if the method is not 1
      //object Envy
      stiffness 240000
      damping 35000
      friction 0.2, 1.001
    collision {
      2, 2
      stiffness 180000
      friction 0.2, 1.001
    #if (clock_on)
      topology {
    #else
      step_count 0
      topology {
        #declare Damp=3000;
        group {
        group {
        group {
  direction   y
  sky         z
  up          z
  right       (4/3)*x
  look_at     <0, 0, 0.>
  angle       30
light_source {
sky_sphere {
    gradient z
    color_map {
