POV-Ray : Newsgroups : povray.binaries.animations : walking (not dancing). suggestions wanted Server Time
12 Jun 2026 23:20:10 EDT (-0400)
  walking (not dancing). suggestions wanted (Message 1 to 10 of 14)
Subject: walking (not dancing). suggestions wanted
Date: 5 Jun 2004 03:13:25
Message: <40c17295@news.povray.org>
Okay, well with little over a month to go to the deadline for the current IRTC
round, I have managed to get a character that walks. Wow! uh... yeah... I've not
been able to spend as much time povving as I'd like to, but I still think I can
get this into some kind of nice animation for the competition deadline.
Anyway, that's not the point of this post. I'm also planning on developing this
into some kind of comprehensive pov-based character animation system, primarily
for my own use but if it's good then I'll gladly share it!
So, what I'd like is suggestions on where to go from here. At present the
character is animated using positions of base points (hands, feet, and waist),
which are currently following a collection of sine curves. I'm thinking the
things to look at immediately are:
1/ using splines to animate the control points
2/ adding joints to those stretchy limbs
3/ getting him to do something more interesting, like dancing maybe!
I'd really appreciate your suggestions on what else could be improved, what
things look good and what doesn't, and just generally any ideas you folks have
for where I should take this.
Thanks in advance,
Tek
www.evilsuperbrain.com
Download 'step000.m1v.mpg' (294 KB)
Subject: Re: walking (not dancing). suggestions wanted
Date: 9 Jun 2004 01:32:45
Message: <40c6a0fd$1@news.povray.org>
Clearly everyone's too busy working on their own entries... oh well I won once,
what more can I expect?
Nah I'm just kidding I know this group doesn't get a lot of traffic. But
seriously, any and all suggestions for my character animation attempt would be
much appreciated, as you can see it has a long way to go...
Tek
"Tek" <tek### [at] evilsuperbraincom> wrote in message news:40c17295@news.povray.org...
not
can
this
primarily
> Thanks in advance,
> Tek
Date: 9 Jun 2004 04:28:18
Message: <2gidc0tukh81srso46qd0ci5retsvsuto6@4ax.com>
On Tue, 8 Jun 2004 22:32:52 -0700, "Tek" <tek### [at] evilsuperbraincom>
wrote:
> But seriously, any and all suggestions for my character animation attempt would be
Opps! Really meant to reply. I don't know how you got such
naturalistic movement from a stiff legged model. It looks good. To me,
it seems obvious that you need to add joints and feet. But you
mentioned that already So there is little I can add. (Maybe that's why
I did not post before) I will wait with interest for further
developments. Perhaps we can watch him grow up just as we have watched
Greg's Blobman take its first tottering steps to dancing the night
away. Staying out late and worrying its good parents :-}
Regards
Date: 9 Jun 2004 23:23:08
Message: <40c7d41c$1@news.povray.org>
This is how I have mine set up:
1. individual transformations for "thich", "forearm", "head", "toe tip",
etc.
2. The transformations take one from the "default pose" to whatever is
indicated by other criteria, such as a macro for hand position which then
drives an IK calc, etc.
3.  Then the body is constructed. Each element, whether a single sphere in a
blob construction or a bicibuc patch element, gets built this way:
      Construction_in_default_position    texture{Forearmtexture}
transform{Forearmtransform}.
Date: 10 Jun 2004 03:14:55
Message: <40c80a6f@news.povray.org>
So do you mean that you have a heirarchy of transforms, so if you change the arm
transform the hand moves, or are the transforms independant but calculated by
your IK to make sure the parts meet up?
Conventional animation systems have a bone hierarchy, but I'm curious as to
whether it might be worth trying something different. My system at the moment is
too simple to need transforms, it just uses independently positioned joints,
hence the stretchy limbs. A little IK will be the next stage, so I need to start
thinking about hierarchies or whatever...
Tek
"Greg M. Johnson" <gregj;-)565### [at] aolcom> wrote in message
news:40c7d41c$1@news.povray.org...
> etc.
Date: 10 Jun 2004 04:27:04
Message: <40c81b58@news.povray.org>
Well, I realise this perhaps doesn't answer your question, but here's the
animation code:
#declare walkPhase = clock;
someGuy(
 //waist
 <1-cos(2*(walkPhase+.5)*pi),cos(4*walkPhase*pi),0>*<.02,.02,0>,
 //lwrist
<1+cos(4*(walkPhase+.5)*pi),1-cos(4*(walkPhase+.5)*pi),-sin(2*(walkPhase+.5)*pi)
>*<.05,.1,.2>+<.15,-.25,0>,
 //rwrist
<-1-cos(4*walkPhase*pi),1-cos(4*walkPhase*pi),-sin(2*walkPhase*pi)>*<.05,.1,.2>+
<-.15,-.25,0>,
 //lfoot
<1+sin(2*walkPhase*pi),1-cos(2*walkPhase*pi),-sin(2*walkPhase*pi)>*<.05,.1,.2>+<
.05,-1,0>,
 //rfoot
<-1-sin(2*(walkPhase+.5)*pi),1-cos(2*(walkPhase+.5)*pi),-sin(2*(walkPhase+.5)*pi
)>*<.02,.1,.2>+<-.05,-1,0>
Then I just position blocks between those points. Not exactly a general purpose
solution, but sine curves can give pretty natural movement if you don't mind
controlling animation using such an ugly mass of numbers. I definitely think
splines would be an improvement, though I rather like the mathemeatical
simplicity of this aproach.
And I still haven't found time to do any more animation!... maybe I should just
tweak this walk a bit, then clone the guy a load of times and make a marching
army? That's sort of dancing. ish. (apologies in advance if I bring down the
tone of the competition with such a lazy entry!).
Tek
"Stephen McAvoy" <mca### [at] aolcom> wrote in message
news:2gidc0tukh81srso46qd0ci5retsvsuto6@4ax.com...
would be
> Regards
>         Stephen
Date: 10 Jun 2004 05:37:49
Message: <ksagc0homkhdeb0hqvophbb9ld3lajlkb1@4ax.com>
On Thu, 10 Jun 2004 01:27:14 -0700, "Tek" <tek### [at] evilsuperbraincom>
>animation code:
You couldn't answer much more fully. Thanks I'll take some time to
analyse the wibbles and wobbles.
I think the mass of numbers approach would be quite limiting. You
would have to re-formulate for every new type of motion. Would you
not? IMO, IK is the way to go. Using splines for the end points
> then clone the guy a load of times and make a marching army
Hey! I thought I was being original doing that. :-}
I've finished my scene just trying to find a good POV. That's Point of
View not a new version :-}
Regards
Date: 10 Jun 2004 12:26:11
Message: <40c88ba3$1@news.povray.org>
There is a transformation hierarchy,  where if you were to change the elbow
rotation, the fingertips would move accordingly .  But I've also got an
optional IK system set up where one could chose an absolute point in space
for the position of the wrist.
news:40c80a6f@news.povray.org...
the arm
by
to
moment is
joints,
start
> Tek
> > etc.
then
in a
Date: 10 Jun 2004 21:50:00
Message: <web.40c90f4d70c2b1b43a5fb9ba0@news.povray.org>
Tek, consider:
http://news.povray.org/povray.binaries.scene-files/thread/%3C3bd4d693%40news.povray.org%3E/?ttop=193121&toff=350
(apologies for the hideous URL syntax)
But it's the basic concepts for my MIME Man system.  I've been thinking
about "releasing" something close to the latest version, but actually I
think what I shared a few years ago would get you over your immediate next
hump.
Happy tracing.
Greg M. Johnson
Date: 11 Jun 2004 01:33:05
Message: <40c94411$1@news.povray.org>
well IK could be used with this mass of numbers... but you're right that it's
way to restrictive. But it has tought me a lot about the subtleties of the
movement. e.g. he actually moves slightly from side to side as he walks, to
shift his weight onto either foot. It's hardly noticeable from this angle, but
it makes a huge difference to how natural the movement looks.
Good for you! I'm close to giving up on this round, I just won't have time. I
was at my "day" job 'til 10pm tonight, and this weekend I'm moving house! If I'm
lucky I might get maybe 20 hours more on this before the deadline :(
Still, I won't give up on the character animation system, I can use that in any
animation.
Tek
news:ksagc0homkhdeb0hqvophbb9ld3lajlkb1@4ax.com...
> >animation code:
purpose
> Regards
>         Stephen
