POV-Ray : Newsgroups : povray.binaries.animations : Creating tunnels... (MPGs, 2x126 kb) Server Time
2 Jul 2026 20:31:27 EDT (-0400)
  Creating tunnels... (MPGs, 2x126 kb) (Message 6 to 15 of 15)
<<< Previous 5 Messages Goto Initial 10 Messages
Subject: Re: Creating tunnels... (MPGs, 2x126 kb)
Date: 11 Feb 2004 10:44:16
Message: <402a4dd0$1@news.povray.org>
Tim Nikias v2.0 wrote:
> Just kidding, though it is kinda weird how someone
> presents a nice thing he's just finished, and then
> one or another points out how someone else already
> did that, and how he made it better than what
> you've just created. I still like my algorithm,
> but it's kinda pointless now, I guess. :-(
The leaning experience was not pointless. Every time you make up some
algorithm on your own your programming skills improve a bit. That is not
the case if you just use someone else's algorithm from the beginning. :)
Rune
rune|vision:  http://runevision.com **updated Jan 29**
POV-Ray Ring: http://webring.povray.co.uk
Date: 11 Feb 2004 10:45:17
Message: <402a4e0d$1@news.povray.org>
> With the technique you mentioned, and have to do
> some inbetween calculations to get the desired
> angles, like projecting the forward vector onto
> a plane with the sky-vector, thus getting vectors
> with which I can calculate the "internal" spin to
> get the up-vectors lined up...
I'm not sure I understand. Why do you need any sky-vector in the first
place? Why do you need to know anything about the spin of the tunnel?
> It's my perspective on things that stands in my
> way of finding efficient solutions for problems
> like these. Don't play around with vectors,
> matrix-transformations and angles enough, I guess...
Playing around with those have often proven to be very handy for me...
Rune
Date: 11 Feb 2004 11:23:48
Message: <402a5714@news.povray.org>
> Don't be sad. Look at it this way: if you haven't done
> it yourself, you are often not able to understand the
> solution of someone else. So keep posting your own
> solutions.
I'm not sad. I still think I can be pretty proud of myself, cause I do find
some sort of solution on my own most of the time, may they be pretty
unspectacular and round-about. And posting here keeps the newsgroups alive
and provides insight into techniques for others (even if the algorithm is
overly complicated, it might be useful for something else).
Tim
"Tim Nikias v2.0"
Email: tim.nikias (@) nolights.de
Date: 11 Feb 2004 11:24:57
Message: <402a5759$1@news.povray.org>
Right. In this case, I guess my problem is more with the vector-arithmetic
than the programming, but I'll tackle that sooner or later as well.
Tim
"Tim Nikias v2.0"
Date: 11 Feb 2004 11:26:37
Message: <402a57bd$1@news.povray.org>
Here's some crude and simple code to explain the basic idea. The
algorithm is simpler than I remembered. Just use the VPerp_Adjust()
macro to make the last up-vector perpendicular to the current
forward-vector and then use that as the current up-vector... The code
here just aligns boxes and does not create a tunnel out of a mesh, but
the basic idea is the same.
#include "transforms.inc"
#include "math.inc"
camera {location <-2,1,-3> look_at 0}
light_source {<-1,2,-3>*1000, color 1}
background {rgb 1}
#declare Spline = spline {
   cubic_spline
   -2, -x,
   -1, -x,
    0, -y,
    1, -z,
    2, y,
    3, z,
    4, x,
    5, x+y,
    6, y+z,
    7, y+z
#declare C = 0;
#declare Samples = 50;
#declare Range = 5;
#declare LastY = y;
#while (C<=Samples)
   #declare Val = C/Samples*Range;
   #declare P = Spline(Val);
   #declare Z = vnormalize(Spline(Val+0.001)-Spline(Val-0.001));
   #declare Y = VPerp_Adjust(LastY,Z);
   #declare X = vcross(Y,Z);
   #declare T = Matrix_Trans(X,Y,Z,P)
   #declare LastY = Y;
   superellipsoid {<0.2,0.2> scale 0.1 transform {T} pigment {rgb 1}}
   #declare C = C+1;
Rune
Date: 11 Feb 2004 11:27:04
Message: <402a57d8@news.povray.org>
You somehow have to put the two forward- and up-vectors into relation. I
thought that maybe projecting both forward vectors onto a plane, get the
angle, rotate the vectors and then calculate new angles for the up-vector
might be a way to go. You've probably got something faster up your sleeve,
the way you phrase it...
Tim
"Tim Nikias v2.0"
Date: 11 Feb 2004 13:55:16
Message: <402a7a94$1@news.povray.org>
Hm. I can see that it works, but I don't understand why and how. I can't
visualize what that VPerp_Adjust actually does, and why it works for
generating a proper new matrix for the new box. Care to elaborate and
enlighten me? :-)
Tim
"Tim Nikias v2.0"
Date: 11 Feb 2004 17:52:00
Message: <402ab210$1@news.povray.org>
>> but the basic idea is the same.
> can't visualize what that VPerp_Adjust actually does
From the doc:
VPerp_Adjust(V1, Axis). Find a vector perpendicular to Axis and in the
plane of V1 and Axis. In other words, the new vector is a version of V1
adjusted to be perpendicular to Axis.
So the new Y vector is the same as the previous Y vector, except that it
is adjusted to be perpendicular with the new Z vector. Since the
previous and the new Y vectors are as close to each other as possible,
there is no twisting.
The Y and Z vectors are now perpendicular, and from those we can get the
X vector using the vcross-function. Now we have the local X, Y and Z
vector for the box as well as its origin P, and then we can create its
transformation matrix out of those four vectors.
That's all really.
Rune
Date: 11 Feb 2004 20:40:10
Message: <402ad97a@news.povray.org>
> That's all really.
Hm, now that you've described it, I can actually build a visual
representation in my mind. You see, as long as I can't actually tell via
diagramm (even if its a complicated one that only fits into the mind, not on
paper) I don't really grasp the formula. I've read the doc, but I got
confused somewhere with that Last_Y and the actual Y etc. Now I can picture
it and understand it.
Now that I've understood it, I'll try to implement it, shouldn't be too much
of a problem. Once the tunnel is properly constructed, I'll get to the
actual tricky part: water simulation. I'm still wondering if I should make
something half-artistic and half-simulation, so that I can actually control
the effects, but still have some degree of realism... Ah well, I'll come to
that later. Maybe I'll ponder about it for a few days and tackle some other
stuff first.
Tim
"Tim Nikias v2.0"
Date: 12 Feb 2004 06:12:29
Message: <402b5f9d$1@news.povray.org>
> build a visual representation in my mind. You see, as
> long as I can't actually tell via diagramm (even if
> not on paper) I don't really grasp the formula.
My mind works the same way... :)
> the actual tricky part: water simulation.
I'm looking forward to see what you'll come up with!
Rune
