POV-Ray : Newsgroups : povray.binaries.animations : Re: kaleidoscope Server Time
14 May 2026 05:11:07 EDT (-0400)
  Re: kaleidoscope (Message 1 to 5 of 5)
Subject: Re: kaleidoscope
Date: 2 Jan 2004 21:44:32
Message: <3ff62c90@news.povray.org>
Here's a different version, looks very cool when played at full screen :)
Tek
www.evilsuperbrain.com
"Tek" <tek### [at] evilsuperbraincom> wrote in message news:3ff60dad@news.povray.org...
> Here's an animated version of the lace pattern I posted on p.b.i
> The code for it is this:
> #declare fA = frame_number;
> pigment {
>   //choose some pretty colours
>   bozo scale .3
>   pigment_map {
>     [.3 bozo translate 7 colour_map { [.5 rgb x/2][.7 rgb .8] }]
>     [.7 rgb <.7,.5,.1>] }
>   //make it into a kaleidoscope
>   #local nCount = 0;
>   #while ( nCount < 10 )
>     rotate -fA*z
>     warp { repeat y flip y }
>     #local nCount = nCount + 1;
>   #end
> Tek
Download 'warprepeat4000.m1v.mpg' (539 KB)
Date: 4 Jan 2004 21:17:06
Message: <3FF8C8D6.D7634099@onwijs.com>
> Tek
Very cool!
 :o)
Date: 6 Jan 2004 05:41:55
Message: <3ffa90f3@news.povray.org>
Remco de Korte wrote:
> Very cool!
Very
Kitty5 NewMedia http://Kitty5.com
TEL : +44 (01270) 501101 - ICQ : 15776037
PGP Public Key
Date: 11 Jun 2004 20:06:42
Message: <40ca4912@news.povray.org>
Very cool :)
How did you compressed the video so much? Which program did you use?
news:3ff62c90@news.povray.org...
> Tek
> > pigment {
> >   bozo scale .3
> >   pigment_map {
> >   #local nCount = 0;
> >     rotate -fA*z
> >   #end
> > Tek
Date: 11 Jun 2004 23:46:43
Message: <40ca7ca3$1@news.povray.org>
"Nicolas Alvarez" <nic### [at] hotmailcom> wrote in message
news:40ca4912@news.povray.org...
The compression really isn't that good. The animation has a relatively small
amount of movement and lots of smooth gradients, so each frame looks very
similar to the next, which makes it compress well (i.e. I can use low quality
compression and it still looks good). Plus it's very low res.
I use Tmpgenc: http://www.tmpgenc.com/
It's got a lot of settings that can be tweaked to refine the compression, though
IIRC this animation was made with mostly default settings, I just tweaked the
"rate control mode" & quality.
Tek
> Very cool :)
> > Tek
> > > pigment {
> > >   bozo scale .3
> > >   pigment_map {
> > >   #local nCount = 0;
> > >     rotate -fA*z
> > >   #end
> > > Tek
