POV-Ray : Newsgroups : povray.binaries.animations : Liquid animation Server Time
9 Jun 2026 18:32:56 EDT (-0400)
  Liquid animation (Message 11 to 20 of 20)
Subject: Re: Liquid animation
Date: 12 Nov 2003 20:45:25
Message: <3fb2e235$1@news.povray.org>
> Very, very impressive. I'd be interested in some more information about the
> algorithm used. Is it similar to the one used in
> http://graphics.stanford.edu/~fedkiw/papers/stanford2001-02.pdf?
No ; ) the approach they used is semi-lagrangian (particles + level set method,
they combined a lagrangian approch with a eulerian approch).
Smoothed Particle Hydrodynamics, used (with some changes) in the program
I wrote, is a pure lagrangian method. Fluid evolution is tracked following
the movements of many pseudo-particles during the simulation. Have a look at the
links I've posted in the previous message, you'll find a good description
of the technique there. ; )
Feel free to ask if you need more details.
Date: 13 Nov 2003 00:40:58
Message: <3fb3196a$1@news.povray.org>
Very very nice. We want to see more :)
Fernando
Date: 13 Nov 2003 04:42:01
Message: <ktvb81-2i7.ln1@triton.imagico.de>
Claudio Pozzoli wrote:
>>It looks very good.  If you wrote the simulation engine yourself i guess
>>a lot of people here would be interested in it.
> The simulation is based over Smoothed Particles Hydrodynamics, a
> pure lagrangian method introduced in late '70 by Gingold and
> Monaghan and originally used to model compressible flows in
> astrophysical simulations. Successively it has been adapted to the
> simulation of quasi-incompressible - incompressible flows.
> The liquid is approximated by a finite number of particles, each carrying
> physical informations like density, pressure, speed, viscosity...
Thanks for the explanation, i was more referring to the actual program
though.  The nice thing about particle based fluid simulation is that
the fluid can move in large areas without excessive memory requirements
that would occur with grid based methods.  It could even be worth
considering integrating such a system into POV since for interaction
with the environment you could rely on the raytracing functions.
>>Note that you don't need to generate a mesh from the scalar field,
>>POV-Ray can directly render isosurfaces.  I did renders of fluid
>>simulations before by generating a density file from the simulation data
>>and using it in an isosurface.
> How could I do this? I mean: once I've generated a density file, following
> the examples in pov documentation, I have to use it as a pattern (media,
> pigment-normal) and associate it with a primitive. Do you use an isosurface
> as object? densityfile as a media pattern? I would like to test it out! : )
You can use the density file in an isosurface shape just like any other
pattern:
#declare Fn_Density=
   function { pattern { density_file df3 "file" interpolate 2 } }
isosurface {
   function { Fn_Density(x, y, z) - 0.5 }
This will show the isosurface with density=0.5.
Last updated 25 Oct. 2003 _____./\/^>_*_<^\/\.______
Date: 13 Nov 2003 07:47:06
Message: <3fb37d4a@news.povray.org>
> What do you think?
That is very very impressive!!
Kitty5 NewMedia http://Kitty5.com
TEL : +44 (01270) 501101 - ICQ : 15776037
PGP Public Key
Date: 13 Nov 2003 23:28:00
Message: <Xns9433377F137C9raf256com@204.213.191.226>
cla### [at] liberoit news:3fb29804@news.povray.org
>> Can You please recompress it with some "standard" codec like mpeg-1,
>> divx, vxid?
> http://digilander.libero.it/stajaame/index.html
> Uploaded a mpeg-1 compressed video ; )
wooow
*realy* nice :) I quess it's nices water I had even seen in pov :)
Date: 14 Nov 2003 10:29:10
Message: <3fb4f4c6@news.povray.org>
In short, there are two different computational phases:
1) Compute change rates for every particle involved in the simulation. In detail:
    -) fluid-fluid particles interactions (every particle within a fixed distance from
        the particle being updated has to be considered in the process. Check
        the papers for more details about the equations... you have to update
        accel. and density. ~30-40 neighbours / particle).
    -) external forces (gravity... simply add them to the accel. vector of the
particle).
    -) boundary-fluid particles interactions (for the moment boundary is
        modelled introducing fixed particles in correspondence of the solid
        surface and adopting a pure repulsive Lennar-Jones interaction force.
        Fixed particles are placed really close in order to form a strong
        barrier to the penetration of the fluid). It should be easy to replace
        particles and to manage directly particles-solid collisions.
Note: 1a) In order to speed up computations, as the interpolating kernel
          presents a compact support (only particles within a fixed distance
          interact), it could be used (well, it's obligatory ;) ) a suitable
neighbours
          finding algorithm. I've used a simple uniform grid: all the
          neighbours of the particle being updated are located checking only
          few adiacent cells (you can take advantage of the simmetry in
          particle-particle interactions to reduce computations).
          1b) Current time-step is determined checking the physical properties
          associated to every particle (simply check accel. and speed of sound).
2) Update particles position-density-speed (leapfrog scheme, prediction - correction
     formulation) using change rates and timestep found in the previous step.
The first one is the more complex and time consuming phase by far...
1661s computation -> 1558s phase 1 vs 102s phase 2... ;)
> pattern:
> isosurface {
Gotta try it but I have to rerun simulation to collect data once again, though.
I'll do it in the weekend.
Date: 14 Nov 2003 12:25:01
Message: <web.3fb50eed16bb28727c8049c20@news.povray.org>
>I've wrote and external program responsible for the physical simulation of the
>liquid. Every time step (user defined) it saves in a file the surface of the liquid
>in mesh2 format (around 12000 vertex and 22000 triangles for the simulation
>posted). All those file are then processed by PovRay for final rendering
>(Pov is used only for that purpose). Rendering times are a problem, though:
>8 min / frame with radiosity and photons on (~360 frames in the animation
>you've seen). Maybe an advanced user could optimize
>some parameters and speed up rendering without a loss in quality... :)
Very convincing, and good luck with your thesis. A bit of flash always goes
down well!
I can understand that the photons are giving you some very nice caustics,
but I'm not sure radiosity is contributing much. Do you save much time with
it off?
Date: 14 Nov 2003 15:33:43
Message: <3fb53c27$1@news.povray.org>
OK, so that's downright cool!
*sigh* Makes me wish I could do stuff like that... but last time I read a
paper on the subject, it was totally over my head. (I'm still trying to
figure out how on Earth cubic Bezier splines work... heh)
Thanks.
Andrew.
Date: 18 Nov 2003 07:50:35
Message: <tfm7ucng4gjk.1fptfpdprq5mx$.dlg@40tude.net>
> it off?
I'll post some screenshots with and without photons/radiosity as soon as
possible (I've formatted my hd... I've got to reinstall everything :P).
Claudio
Date: 14 Jan 2004 21:23:42
Message: <4005f9ae$1@news.povray.org>
Beautiful !
I always were a liquids freak so this is really nice to watch ! I wished I
had time to study this furthermore !
/~\nne
