POV-Ray : Newsgroups : povray.binaries.animations : Underground Tunnel ( mpg 520 kbu ) Server Time
11 Jun 2026 12:51:52 EDT (-0400)
  Underground Tunnel ( mpg 520 kbu ) (Message 11 to 16 of 16)
Subject: Re: Underground Tunnel ( mpg 520 kbu )
Date: 14 Aug 2003 06:01:19
Message: <3f3b5def@news.povray.org>
Hugo Asm wrote:
> Triangles, I see! Btw, how did you make the tunnel
> loop perfectly? A granite pattern never repeats.
Hehe, I hoped you'd ask that question!
If the tunnel was a torus, it'd make perfect sense, right? But the
tunnel is not a torus. However, the mapping is taken from a torus.
The displacement of the tunnel is UV-mapped (and so are the textures).
But instead of taking the mapping from a square in the xy-plane, I took
it from a torus. Well, technically, I made a function which mapped the
pattern on the surface of a torus onto a square in the xy-plane, and
like all uv-mapping, this square was then mapped onto the tunnel. I then
just placed two copies of the tunnel in the scene, one in extension of
the other.
A side effect is that the granite pattern in the tunnel is slightly more
squeezed together in the left side than in the right, but it's so little
that it's not noticeable.
> Oh, well... What about attaching the glows to the
> rocks? That might look less confusing.. I don't
> know about the wow's though.
It's an interesting idea.
Rune
rune|vision:  http://runevision.com **updated Jul 25**
POV-Ray Ring: http://webring.povray.co.uk
Date: 14 Aug 2003 23:12:39
Message: <3f3c4fa7$1@news.povray.org>
"Sir Charles W. Shults III" <aic### [at] cflrrcom> wrote in message
news:3f3a48a3$1@news.povray.org...
>     It's Ronald Reagan's colon!
> Cheers!
> Chip Shults
> My robotics, space and CGI web page - http://home.cfl.rr.com/aichip
That's weird... that's exactly what I thought... Not
necessarily Ronald Reagan's, but anyway...
Scary indeed...
Best,
    S.
Steven Pigeon, Ph. D.
pig### [at] iroumontrealca
Date: 15 Aug 2003 03:34:30
Message: <3f3c8d06@news.povray.org>
> > I'd like to see a tunnel that was not undergound.
> Well, that would be a completely different animation...
> But out of curiosity, what are you thinking of specifically?
I was just kidding.  It's hard to picture a tunnel that's not underground.
Date: 15 Aug 2003 07:24:13
Message: <3f3cc2dd$1@news.povray.org>
How about a tunnel through a swirly mist, a tunnel through space-time (a
worm hole), or a tornado?
Date: 23 Aug 2003 21:52:52
Message: <3f481a74@news.povray.org>
Is the movement a spline or is it artificial intelligence navigating the
interior?
Why don't you put up some more images at zazzle if you're bored?
Date: 24 Aug 2003 05:40:28
Message: <3f48880c@news.povray.org>
> intelligence navigating the interior?
It's a spline.
My existing images are not good enough in my opinion, except one, which
will require quite some reworking before it will look good at a higher
resolution. And creating new images requires inspiration...
Rune
