POV-Ray : Newsgroups : povray.binaries.animations : Re: An AVI light box (DixX AVI 884K) Server Time
29 Mar 2026 14:22:49 EDT (-0400)
  Re: An AVI light box (DixX AVI 884K) (Message 1 to 1 of 1)
Subject: Re: An AVI light box (DixX AVI 884K)
Date: 23 Apr 2003 19:22:17
Message: <3ea72029$1@news.povray.org>
Ooh, I'd forgetten just how bad that theme music is! (normally I'm at work when
the show's on)
It's a very cool effect, though it's not much like watching a TV in the dark
since TV's don't cast sharp images. If you draw the texture high ambience, and
then rendered the whole scene with radiosity you'll get more of a TV effect, as
well as a really slow render time.
Still a very impressive technique. I like it :)
Tek
http://www.evilsuperbrain.com
"BillyB" <pov### [at] highlifedemoncouk> wrote in message
news:3ea71718@news.povray.org...
> Hi all,
> This is my first post on here so sorry if I get things wrong.
> This is an experiment in using an AVI as "projector" like thingy.
> What I ended up with is a Cube shape that looks a little like one of those
> paper lamp shades.
> The original AVI is a the opening sequence from a kiddies show.(not my work)
>  I used VirualDub to pull the original AVI to bits. Then put the pov output
> back together using this too.
> I rendered it without AA for speed. This worked quite well as the fast
> moving analogue AVI looked quite smooth.
> I sized the output AVI down by factor of two for the news group so the post
> is AAed from doing this.
> I also trashed the sound to bring the post size down. You will have to
> imagine it not sounding like a tranny radio.
> The "floor" is "white" and there is a light in the "box" shining out.
> I ended up with the front of the "box" being less transparent and added a
> light in front.
> Several things I got wrong...
> Its too dark and the sudden cuts in the original AVI make the whole rendered
> scene jump.
> Its very like watching TV in total darkness. Could do with some ambient
> light.
> Could do with some more objects around to reflect the light off. The floor
> is too flat and distorted.
> The sound is not edited to fit the camera pan.
> I think I dropped a frame.Its 12fps and I think the first frame is missing.
> The first cuts are out I think by a 12th of a second compared to the sound.
> All feedback very welcome.
> Ta BB.
