POV-Ray : Newsgroups : povray.binaries.animations : Liquid metal reaction... (352kb MPG1) Server Time
11 Jun 2026 15:52:32 EDT (-0400)
  Liquid metal reaction... (352kb MPG1) (Message 11 to 16 of 16)
Subject: Re: Liquid metal reaction Take 2 (396kb MPG1)
Date: 28 Mar 2003 08:41:01
Message: <3e8450ed$1@news.povray.org>
That not really stabilizing, is it? There's a wave
which pushes back and forth between the initial
corner and the first blocking box. Every time it
hits the corner, the higher it rises. This also
happens at the "nozzle", where one section
flows into the other. It would go on rising forever,
I guess, otherwise, it would have stabilized
much earlier.
Tim Nikias v2.0
Email: Tim### [at] gmxde
> So it stabilizes by growing upwards in the shape of the vessel. The last
six
> frames are intriguing.
> Regards
>         Stephen
Date: 28 Mar 2003 08:42:05
Message: <3e84512d@news.povray.org>
Thanks. I hope to get this system running by next
week, and then I'll probably start something like a
beta-phase or so.
Tim Nikias v2.0
> hey tim
> that's really cool. i like espescially the moment just when it reaches the
> clipping container, with only the "side walls" of the water visible. looks
> really nice.
> keep up the good work
> florian
Subject: Re: Liquid metal reaction... (352kb MPG1)
Date: 28 Mar 2003 08:43:42
Message: <3e84518e$1@news.povray.org>
I don't have any experience with liquid metal, and haven't
seen much aside the VFX shots of liquid metal, so thats
not really something to compare to, right?
And I'm only using reflection to make the surface more
visible, since reflecting looks nicer than gradient colors
for height...
Tim Nikias v2.0
> Very cool, but as for a liquid metal, per se,  the surface tension is
wrong.
Date: 28 Mar 2003 09:44:02
Message: <3e845f9d.92682059@news.povray.org>
On Fri, 28 Mar 2003 14:40:01 +0100, "Tim Nikias v2.0" <tim### [at] gmxde> wrote:
No, I guess not. What value do you normally use for damping? I have been playing
with the "water effect" and I've some peculiar results with different values.
Regards
Date: 28 Mar 2003 19:42:41
Message: <3e84ec01@news.povray.org>
Depends. Most of the time, I'm using .95 as a
dampener, though this error only happened with
1 (no dampening). With .99 it worked fine, though
very fluctuating.
How do these "peculiar" results look like?
Tim Nikias v2.0
playing
values.
> Regards
>         Stephen
Date: 29 Mar 2003 06:58:12
Message: <3e8588e3.72097480@news.povray.org>
On Sat, 29 Mar 2003 01:41:42 +0100, "Tim Nikias v2.0" <tim### [at] gmxde> wrote:
I did not keep them when I upgraded my PC, but I will start a new thread called
"Things that went wrong" with a mistake in a heightfield generating programme.
Regards
