POV-Ray : Newsgroups : povray.binaries.animations : Booster test (245k mpeg 1) Server Time
11 Jun 2026 15:53:41 EDT (-0400)
  Booster test (245k mpeg 1) (Message 10 to 19 of 19)
<<< Previous 9 Messages Goto Initial 10 Messages
Subject: Re: Booster test (245k mpeg 1)
Date: 12 Mar 2003 17:55:28
Message: <3e6fbae0@news.povray.org>
> That would be good. Any idea how I can play a sound effect in response to
> something happening in povray?
> For that matter, has anyone got any tips on how to add general sound
effects
> to an animation?
Foley artist?  :)
Unless you know the timing of each even and can program that into your video
editing software?
Shouldn't be too hard to list what event happens at what frame/s and insert
the sound at that frame/s.
Version: 6.0.459 / Virus Database: 258 - Release Date: 25/02/03
Date: 13 Mar 2003 04:11:53
Message: <3e704b59@news.povray.org>
"Kitsune_e" <kit### [at] hotmailcom> wrote:
> The animation looks very good, and I like the way your media looks.  There
> is one issue I can see though.  The thrusters fire in response to the
> spline.  This makes it seem that they are firing in response to the change
> in direction, not causing it.  It is fairly simple to fix though, just
pass
> the thrusters spline values shifted toward one.
> i.e.
> thrust_time = my_spline[clock]+.1
Well actually they fire according to the acceleration at a given point in
time, which is correct. There's no lag between the ship moving and the
thrusters firing, and there shouldn't be because as soon as a thruster fires
it imparts acceleration to the ship.
Though I may add a short warm up period before they fire, so it seems less
like they can just switch on and off instantly.
Tek
http://www.evilsuperbrain.com
Date: 13 Mar 2003 04:14:29
Message: <3e704bf5@news.povray.org>
"Aaron" <aar### [at] ihugconz> wrote:
> Teleportation through worm holes generated by the ship?
> I hope its not completely random and the "universe" is pretty well mapped
or
> you might run into something completely unexpected...  :)
Well I'm going to have one of those lovely sci-fi justifications for using
artistic license. In this case I'll say it teleports you to locations with
similar gravity, or something, so you never end up in deep space or inside a
star! Of course that's just an excuse for me to teleport it ot lots of
interesting locations :)
Tek
Date: 13 Mar 2003 04:16:29
Message: <3e704c6d@news.povray.org>
"Aaron" <aar### [at] ihugconz> wrote in message:
insert
Yeah, I was thinking of resorting to just noting down all the timings then
sequencing the sounds in a music program to produce a file I could attach to
the video. But I was kind of hoping there was an easier way...
Tek
Date: 13 Mar 2003 05:22:52
Message: <3e705bfc@news.povray.org>
Hmm I never do POV anims.  But surely an output to a text file could be
through the script?
to
Version: 6.0.461 / Virus Database: 260 - Release Date: 10/03/03
Date: 13 Mar 2003 11:43:25
Message: <Xns933D773554FD0tomatimporg@204.213.191.226>
"Tek" <tek### [at] evilsuperbraincom> wrote in news:3e6f5ecc$1@news.povray.org:
> effects to an animation?
I use http://audacity.sourceforge.net/ to create soundtracks. It is a very
nice cross platform, open source, multi track, sound/music editor.  Then I
just point my encoder http://www.tmpgenc.net/ to the wave file and the
series of PNG files created by POV-Ray.
Tom
Date: 13 Mar 2003 12:57:44
Message: <3e70c698@news.povray.org>
news:3e705bfc@news.povray.org...
> through the script?
Hmm... that's a good idea.
In fact it should be possible to use such a file to produce the sound track,
though that would need some programming and I don't have time for it before
the deadline. But in any case I can get pov to output a file that I can then
work from by hand.
Tek
Date: 13 Mar 2003 13:00:19
Message: <3e70c733@news.povray.org>
That looks really useful, thanks!
I'll download it tonight :)
Tek
Date: 23 Mar 2003 16:48:05
Message: <3e7e2b95$1@news.povray.org>
I love the hull detail.
The boosters look nice, although I'm not quite 'sure' that the ship motion
is proper given the booster firing, but I think that's because the motion is
so complicated.  If I watch one booster (i.e. the front) it looks perfect.
I take it from your description it's correct.
Some of the boosters seem to 'overlap' (the side / wing boosters) some which
would impact a net upward motion, and the tail booster is going too, but I
assume the camera is locked on the center of the ship.  Maybe if there were
starts / something to gauge movement against it would be more obvious.
Anyway, nits, again I just love the hull detail.  They seem to be different
plates.  How did you do it?
     == John ==
news:3e6e6c04@news.povray.org...
> This is an animated version of the still I posted on p.b.i
Date: 24 Mar 2003 13:37:22
Message: <3e7f5062@news.povray.org>
The ship motion is right apart from the amount of thrust and the size of the
boosters. i.e. boosters light up according to their position and direction
only. The way I see it that's accurate enough to fool most people.
The camera isn't moving, the ship is rotating on the spot in zero-G. It's a
very unusual movement so that's why it's so hard to figure out what's
happening! :) The ship should gain a net motion when the rear boosters fire
because of how much bigger they are, but like I said above I don't model
that.
The plates that make the hull use a normal map, like the one I used on my
winter entry to the irtc. I've improved it a little since then, but for this
animation I actually don't use a normal map. That sounds like a
contradiction, but bear with me: I render the ships texture to a seperate
image, with all the panel bumps, dirt, colour, logos, and windows on it. So
when you map that texture on it looks lumpy, even though it's flat and
doesn't have a normal map! This makes it render much faster than a normal
map, which is in turn much faster than actually modelling the panels.
But in answer to your question: the panels are based loosely on a normal map
that's kind of like this: normal { cells }. I've modified and scaled it, but
that's the basic effect.
Tek
"John D. Gwinner" <joh### [at] cornelledu> wrote in message
news:3e7e2b95$1@news.povray.org...
is
which
were
different
>      == John ==
> "Tek" <tek### [at] evilsuperbraincom> wrote in message
