POV-Ray : Newsgroups : povray.binaries.animations : Pigment-mapped Bouncing Ball ... (DIVX5.02 AVI, 313KB) Server Time
29 Mar 2026 16:14:38 EDT (-0400)
  Pigment-mapped Bouncing Ball ... (DIVX5.02 AVI, 313KB) (Message 1 to 10 of 11)
Subject: Pigment-mapped Bouncing Ball ... (DIVX5.02 AVI, 313KB)
Date: 20 Feb 2003 04:43:29
Message: <3e54a341@news.povray.org>
Hi Folks,
As suggested, I wrote a transformation macro to align a pigment using
three points. Turned out to be very simple, the idea based on the
Point_At_Trans() macro.
It also uses radiosity and the Skylight dome generator by Philippe
Debar. I do need to make a modification of this to write the mesh out as
an include and just read it back in for each frame, rather than
rebuilding it each time :-/
Hope you like this one.
Bye for now,
	Mike Andrews.
Download 'bball.avi.dat' (313 KB)
Subject: Re: Pigment-mapped Bouncing Ball ... (DIVX5.02 AVI, 313KB)
Date: 20 Feb 2003 05:35:57
Message: <3e54af8d$4@news.povray.org>
Looks so much better with a Texture on the ball - reminds me of the old
Amiga ball demo
PGP Public Key
Date: 20 Feb 2003 05:37:02
Message: <3e54afce@news.povray.org>
"Michael Andrews" <m.c### [at] readingacuk> wrote in message
news:3e54a341@news.povray.org...
> Hi Folks,
I do.. I do! Top marks.. 100%. Really great work there. What's the sim time per frame?
All the best,
Andy Cocker
Date: 20 Feb 2003 05:55:19
Message: <3e54b417@news.povray.org>
I've got an include which could be suited for the job:
the IO-Macros, which you can find on my homepage.
They'll at least write an array (any 5-dimensional) to
disk and may load it. But they may not be what you want,
still you might want to have a look at those for input-output
"examples".
Regards,Tim
Tim Nikias
Email: Tim### [at] gmxde
> Hi Folks,
> Bye for now,
> Mike Andrews.
Date: 20 Feb 2003 08:06:29
Message: <3e54d2d5$1@news.povray.org>
> Amiga ball demo
Hi Rick,
Yes, the texturing adds a lot. I surprised myself with how easy the
orientation macro was to write:
#macro Three_Point_Trans(T1a, T1b, T1c, T2a, T2b, T2c)
   transform {
     #local Y = vnormalize(T1b - T1a);
     #local X = vnormalize(T1c - T1a);
     #local Z = vnormalize(vcross(X, Y));
     #local X = vcross(Z, Y);
     #local T = Shear_Trans(X, Y, Z)
     translate -T1a
     transform { T inverse }
     #local Y = vnormalize(T2b - T2a);
     #local X = vnormalize(T2c - T2a);
     translate T2a
The three points a,b,c define a triangle; a is the origin, b-a is the
primary orientation and abc gives a secondary orientation plane. The two
orientation axes b-a and c-a do not have to be orthogonal, just
independant so vcross(b-a,c-a) doesn't return a zero length vector.
So Three_Point_Trans(0,y,x, P0,P1,P2) gives a transform from the origin
to P0, aligns y with P1-P0 and puts the (x,y) plane in the plane of the
(P0,P1,P2) triangle.
I never actually had an Amiga; Atari 400, Acorn Electron, BBC B, various
PC types ... I wrote my first (spheres only) raytracer on my Electron,
16 colour error-diffusion dithered screen output only :-) The hardware
and software have improved immeasurably, it's a shame I still can't
produce anything artistic :-(
Bye for now,
	Mike Andrews.
Date: 20 Feb 2003 08:13:19
Message: <3e54d46f@news.povray.org>
Hi Andrew,
Quite quick; parsing time averaged 23.5 seconds per frame, but most of
that was building the skylight mesh. I didn't notice what the actual sim
time was.
The sim has 151 masses, 594 connections, 296 faces and 2500 steps.
Bye for now,
	Mike Andrews.
Date: 20 Feb 2003 08:20:01
Message: <3e54d601$1@news.povray.org>
Hi Tim,
> "examples".
Not really what I want, but thanks for the thought. For reusing things
like meshes in an animation I usually write the complete mesh to a file
on the first frame and then just #include "hull.msh" or whatever on
subsequent frames. It only takes a couple more #writes() and I don't
have to worry about parsing anything back in - just let PoV do the work
for me :-)
Bye for now,
	Mike Andrews.
Date: 24 Feb 2003 08:11:35
Message: <3E5A1A06.717F86C2@gmx.de>
> Hi Folks,
Nice. Is the mass distribution between rim masses and central mass correct
so you get a correct moment of inertia?  Maybe you should also try making
one side of the ball heavier. I think this would look interesting.
Last updated 31 Dec. 2002 _____./\/^>_*_<^\/\.______
Date: 24 Feb 2003 14:34:58
Message: <Xns932CD21C52BB5torolavk@204.213.191.226>
Michael Andrews <m.c### [at] readingacuk> wrote in
news:3e54d2d5$1@news.povray.org:
>    transform {
>      translate -T1a
>      translate T2a
> #end
> the primary orientation and abc gives a secondary orientation plane.
> The two orientation axes b-a and c-a do not have to be orthogonal,
> just independant so vcross(b-a,c-a) doesn't return a zero length
> vector.
> origin to P0, aligns y with P1-P0 and puts the (x,y) plane in the
> plane of the (P0,P1,P2) triangle.
Here is a slightly modified version of that macro:
#macro ThreePoint_Trans(pA1, pB1, pC1, pA2, pB2, pC2)
  #local vY1 = vnormalize(pB1 - pA1);
  #local vZ1 = vnormalize(vcross(pC1 - pA1, vY1));
  #local vX1 = vcross(vZ1, vY1);
  #local T1 = transform { Matrix_Trans(vX1, vY1, vZ1, pA1) inverse }
  #local vY2 = vnormalize(pB2 - pA2);
  #local vZ2 = vnormalize(vcross(pC2 - pA2, vY2));
  #local vX2 = vcross(vZ2, vY2);
  #local T2 = transform { Matrix_Trans(vX2, vY2, vZ2, pA2) }
  transform { T1 T2 }
#end // macro ThreePoint_Trans
Tor Olav
Date: 25 Feb 2003 07:07:00
Message: <3e5b5c64$1@news.povray.org>
Hi Tor Olav,
>   transform { T1 T2 }
> Tor Olav
Nice. I used the Shear_Trans() macro because that's what the
Point_At_Trans() macro used, I didn't think to use the Matrix_Trans() to
do the shear and translate in one go. Kudos to you :-)
Bye for now,
	Mike Andrews.
