POV-Ray : Newsgroups : povray.binaries.animations : MechSim Bouncing Ball ... (Divx 5 AVI, 470K) Server Time
11 Jun 2026 14:27:04 EDT (-0400)
  MechSim Bouncing Ball ... (Divx 5 AVI, 470K) (Message 1 to 10 of 11)
Subject: MechSim Bouncing Ball ... (Divx 5 AVI, 470K)
Date: 13 Feb 2003 02:53:20
Message: <3e4b4ef0@news.povray.org>
Hi Folks,
A simple little animation of a bouncing ball. The ball is 100 points on
a sphere, nearest neighbours connected and triangulated with my convex
hull macro. To provide ridgidity I also put a mass at the center and
connected all other points to it.
Comments would be appreciated.
Bye for now,
	Mike Andrews.
Download 'bball.avi.dat' (470 KB)
Subject: Re: MechSim Bouncing Ball ... (Divx 5 AVI, 470K)
Date: 13 Feb 2003 06:03:57
Message: <3e4b7b9d$1@news.povray.org>
Incredible - you're too early - I was going to do this!  ;o)  I'm currently
learning how to code an icosahedron, and I want to use it in mechsim's too..
I want to go a step further, but maybe we can both try this:  Make the ball
jelly-like.
Hugo
Date: 13 Feb 2003 06:16:31
Message: <cgvm4vg85if3o091li0uuv259ndre81t31@4ax.com>
Nice, slow, bounce
How does it stop ? Does it bahave like a ball,
or does the movement become "jerky" because
the ball comes to rest on a single traingle ?
WdW
On Thu, 13 Feb 2003 07:56:56 +0000, Michael Andrews
<m.c### [at] rdgacuk> wrote:
>Hi Folks,
>Bye for now,
>	Mike Andrews.
Date: 13 Feb 2003 06:44:53
Message: <3e4b8535$1@news.povray.org>
"Michael Andrews" <m.c### [at] rdgacuk> wrote in message
news:3e4b4ef0@news.povray.org...
Very nice. Not sure about the camera following every slight movement (look_at central
mass?)
though.
All the best,
Andy Cocker
Date: 13 Feb 2003 11:51:55
Message: <3E4BCD2B.92E9F14D@gmx.de>
Michael Andrews wrote:
> Hi Folks,
Nice.  I already considered adding a macro for such a shape to mechsim.inc
but i did not have the time yet.  It would probably look better if you
only display a sphere with large radius at the position of the center
mass...
Last updated 31 Dec. 2002 _____./\/^>_*_<^\/\.______
Date: 13 Feb 2003 13:03:18
Message: <3e4bdde6@news.povray.org>
Christoph Hormann wrote:
> It would probably look better if you only display
> center mass...
Provided that the sphere is textured - and rotated to match the movement
of the shape. Because the rotation is half the beauty of this
simulation. :)
Rune
rune|vision:  http://runevision.com (updated Oct 19)
POV-Ray Ring: http://webring.povray.co.uk
Date: 14 Feb 2003 10:33:08
Message: <3e4d0c34$1@news.povray.org>
> mass...
Hi Christoph,
The first attempts at this had much lower stiffness, so the ball
distorted considerably when it bounced. This animation was done close to
the edge of instability with the highest stiffness I could get away with
for a reasonable time step.
While I have you on the line (well, sort of :-) could you clarify
something for me. I originally created the scene with all the object
sizes ten times bigger. When I reduced the sizes (to give a one meter
diameter ball) I had to reduce the stiffness as well to get a stable
system. Is this an expected behaviour, that connection and environmental
stiffness and damping are size related? Are there any rules-of-thumb
that can help determine what values will give stable systems at
different scales? Just curious more than anything, a little
experimentation gets me reasonable deformations.
Bye for now,
	Mike.
Date: 14 Feb 2003 11:06:42
Message: <3E4D1411.C8349A81@gmx.de>
Stiffness and damping are of course size related.  If a connection with a
stiffness of 1000 N/m and a relaxed length of 1 meter is compressed to
half the length it exhibits a larger force on the masses it connects than
if a connection of the same stiffness of only 10 centimeter is compressed
to half the length.  Same applies for the damping.  Apart from that if you
have the masses defined with 'density' you have to remember that their
mass is proportional to the third power of the radius.
You can't easily measure the tendency of a complicated system to get
instable in simulation.  Instability is usually caused by 'stiff' systems
but stiffness in this case in not the same as the stiffness of a
connection or an environment.  Damping also has a strong influence on
stability - it can both avoid and support it.
It usually helps not to think in masses, stiffness and damping but in
combined values.  For example for a single mass oscillator (mass and
connection) without damping you can define an eigen angular frequency (i
hope this is the right word, 'Eigenkreisfrequenz' in german):
w = sqrt(k/m)
where k is the stiffness (N/m) and m is the mass (kg).  Large frequencies
usually require small timesteps.
Another number is the damping ratio:
t = d/(2*sqrt(k*m))
where d is the damping (kg/s) of the connection.  d<1 is considered as low
damping meaning in a single mass system the mass will oscillate.
Both values do not depend on the size of the system but of course they
only can be given in a single mass system in fact.
Date: 14 Feb 2003 12:24:55
Message: <3e4d2667$1@news.povray.org>
> simulation. :)
Hi Rune,
Yes, this is what I like most as well; the frictive effects of the
rotation when it bounces. Changing the amount of initial rotation can
completely change the trajectory of the ball.
I'm going to see if I can uv-map a pigment onto the mesh next.
Bye for now,
	Mike.
Date: 14 Feb 2003 12:45:46
Message: <3e4d2b4a$1@news.povray.org>
Ok, I see this. You have to apply more 'work' to compress a one meter
length by half than you do for a ten centimeter length. Makes sense now :-)
Simple harmonic motion perhaps?
> w = sqrt(k/m)
> t = d/(2*sqrt(k*m))
> Christoph
Thanks for this Christoph. It's been a loooong time since I've looked at
the math for oscillating bodies and this refresher has helped me a lot.
Mike.
