POV-Ray : Newsgroups : povray.binaries.animations : Sim_POV: Hook Drop Server Time
10 Apr 2026 03:26:46 EDT (-0400)
  Sim_POV: Hook Drop (Message 1 to 10 of 12)
Subject: Sim_POV: Hook Drop
Date: 19 Dec 2002 05:28:57
Message: <3e019f69@news.povray.org>
Unfortunately, Sim_POV is crashing on me quite a lot now, which is annoying as it
usually
happens well into an animation. It always seems to occur during block-on-block
collisions.
Possibly a bad combination of settings.. I dunno.
Anyhow, here's my latest anim, right up until the point that it crashed.
All the best,
Andy Cocker
Download 'SimPOV_HookDrop.mpg' (389 KB)
Subject: Re: Sim_POV: Hook Drop
Date: 19 Dec 2002 10:49:05
Message: <3e01ea71$1@news.povray.org>
Looks good Andy.
I am having similar problems with cube collisions atm. I built a stack of
bricks with a slight gap between them all and then let things go. It crashes
as soon as the objects collide. If you have any joy in solving this problem
plz let me know.
Dave
"Andrew Cocker" <mai### [at] andrewcockercouk> wrote in message
news:3e019f69@news.povray.org...
> Hi,
annoying as it usually
block-on-block collisions.
> All the best,
> Andy Cocker
Date: 19 Dec 2002 11:20:29
Message: <3e01f1cd@news.povray.org>
"Dave Brickell" <kryten@*NOSPAM*totalise.co.uk> wrote in message
news:3e01ea71$1@news.povray.org...
> Looks good Andy.
Thanks
> plz let me know.
No, that's exactly the problem I'm having.... exactly the same kind of scene I tried
too. I
haven't actually informed Christoph of this bug, but as it stands, i can't really
continue
with my experiments, as they all involve block to block collisions.
Andy
Date: 19 Dec 2002 12:06:25
Message: <3e01fc91$1@news.povray.org>
Haven't tried simpov myself, but do you have any clue what kind of error
we're talking about here? Does your OS or SIMPOV tell anything?
Date: 19 Dec 2002 12:29:43
Message: <3E020205.B00858D0@gmx.de>
> > plz let me know.
too. I
continue
I of course can't say for sure without testing the code myself but this
almost certainly isn't a bug.  Your simulation simply got instable.  Your
animation shows you are using very stiff connections and therefore you
need quite small time steps to successfully simulate the movement.  Try
doubling the number of steps and if the problem vanishes this was the
reason.
The next version will contain a test function which tries to detect
instability and issue an Error.  It seems to work fairly well but of
course there is no guarantee that it always works.
Last updated 07 Dec. 2002 _____./\/^>_*_<^\/\.______
Date: 19 Dec 2002 14:11:18
Message: <3e0219d6@news.povray.org>
"Apache" <apa### [at] yahoocom> wrote in message
news:3e01fc91$1@news.povray.org...
I am running XP.... it just tells me that SimPOV has had to close. Sim-POV itself just
drops
me back to the prompt.
I am re-running the animation again right now, with much smaller time steps (more than
double)
to see if that fixes things.
All the best,
Andy Cocker
Date: 19 Dec 2002 18:45:47
Message: <3e025a2b$1@news.povray.org>
I agree with Christoph Hormann. Probably you have an overflow error (which
doesn't show apparently) caused by stiff equations. Does SimPOV use 4th
Runge Kutta? It's much more stable and requires less small time steps.
Date: 19 Dec 2002 19:33:08
Message: <3e026544$1@news.povray.org>
news:3e025a2b$1@news.povray.org...
No, it uses forward euler (the setting I'm using) and second order (heun)(which I
haven't yet
used). I too am expecting the problem to be my choice of settings... I already think I
may
have been using a much too small value for radius.
All the best,
Andy Cocker
Date: 19 Dec 2002 19:36:23
Message: <3e026607$1@news.povray.org>
I'd use Heun if I were you. And if possible even higher orders. The system
will be much more stable and allow larger timesteps.
Date: 19 Dec 2002 19:40:08
Message: <3e0266e8$1@news.povray.org>
news:3e026607$1@news.povray.org...
Ok, I will try that. It seems that it might not be an instability problem after all,
but
Christoph is looking at other possible causes.
All the best,
Andy Cocker
