POV-Ray : Newsgroups : povray.binaries.animations : povray rocks baby (473 kbbu) Server Time
3 Jul 2026 05:34:38 EDT (-0400)
  povray rocks baby (473 kbbu) (Message 11 to 12 of 12)
Subject: Re: That'd be too bad, I'd be so sad, I might get mad, I'd call my Dad. (473 kbbu)
Date: 23 Nov 2002 10:32:15
Message: <3DDF9F53.6921D3F3@onwijs.com>
"Greg M. Johnson" wrote:
> "Greg M. Johnson" <gregj:-)56590@ao:-)l.com> wrote in message
> news:3dd9a09a@news.povray.org...
> I think there may be a lip solution on the horizon some day but not yet.  It
> would involve the trace function and a 60-sphere blob; declaring the face,
> tracing it and redeclaring it with the lip components added.  Maybe I'll
> wait 'till I get a 2.53 GHz box before implementing that one...
> I've at least fixed the head.  The solution is that the front of the face &
> jaw head are a stack of pancakes, flattened spheres, where the position and
> scale are determined by splines.  I'll try to have a more substantial
> improvement before posting again.
>    rock15friday2.mpg    Type: WMPLAYER File (video/x-mpeg2a)
>                     Encoding: x-uuencode
I'm not sure about the pancakes but it occurred to me that with
the ridges he might apply for a role on Star Trek.
About the lips: perhaps some lipstick would work. I'm serious
here: a bit of colour might be enough.
Another idea might be to add a cylinder component to the blob
slightly larger then the cylinder you cut out for his mouth.
I also realized that these test animations give a slightly
distorted view, or actually, an undistorted view that stresses
certain things I otherwise wouldn't notice. If for instance, he
would move his head a bit while talking you would get a better
'impression' (as opposed to an exact image).
Remco
Date: 25 Nov 2002 10:27:47
Message: <3de24173$1@news.povray.org>
"Remco de Korte" <rem### [at] onwijscom> wrote in message
news:3DDF9F53.6921D3F3@onwijs.com...
Imagine an entire galaxy filled with bipedal Caucasians, varying only in the
amount of latex on their noses.... Dr. Who did better with
low-budget-plausibility on this one....
But seriously, that was actually my chin pancake stack butting through the
side of the head.  I fixed it later.
> I'm serious here: a bit of colour might be enough.
Aha. I could do this with the object function a slightly larger object than
the object used to cut the mouth hole, then just make it pink.
> to the blob slightly larger then the cylinder you cut
> out for his mouth.
I considered a solution like this that worked perfectly in being true to the
jaw rotation but it wouldn't have worked with a mouth changing shape in the
'x' as it made lip-sync shapes.
> Remco
yeah, cool.  Thanks for the consideration..........
Now I have 'writer's block' as far as a storyline involving 'speed' and this
character.
