POV-Ray : Newsgroups : povray.binaries.animations : PartixGen - Inertia, second attempt (MPG 340kb) Server Time
22 Mar 2026 19:21:50 EDT (-0400)
  PartixGen - Inertia, second attempt (MPG 340kb) (Message 1 to 10 of 11)
Subject: PartixGen - Inertia, second attempt (MPG 340kb)
Date: 30 Oct 2002 18:31:47
Message: <3dc06be3$1@news.povray.org>
This is a new attempt, which can be downloaded
from my homepage. The camera moves less, the
emitter is visible and I think it looks better and
more obvious than the former version.
Here's the link:
http://www.digitaltwilight.de/no_lights/partixgen/animations/inertia.mpg
Those interested in the description itself just head to:
http://www.digitaltwilight.de/no_lights/partixgen/index.html
Tim Nikias
Email: Tim### [at] gmxde
Subject: Re: PartixGen - Inertia, second attempt (MPG 340kb)
Date: 30 Oct 2002 19:03:09
Message: <3dc0733d@news.povray.org>
This looks very nice! :)
I'm not sure though if I like this version or the previous version
better.
Rune
rune|vision:  http://runevision.com (updated Oct 19)
POV-Ray Ring: http://webring.povray.co.uk
Date: 30 Oct 2002 19:19:53
Message: <3dc07729$1@news.povray.org>
You really need to take that system out of that rectangular room and put it
in more interesting environments. =)
 - Slime
[ http://www.slimeland.com/ ]
Date: 31 Oct 2002 02:07:26
Message: <3dc0d6ae$1@news.povray.org>
That's the only environment my system may interact
with! Look on my website for details on the system,
you'll notice that its non I/O and cannot handle
any environment after all.
Tim Nikias
it
>  - Slime
Date: 31 Oct 2002 02:26:43
Message: <3dc0db33$1@news.povray.org>
> *Rune hammered something like*
Thanks!
> *And went on rambling...*
> better.
Then let me tell you, its this version you like
better. The camera moves more smoothly,
its very obvious that the particles are
moved by inertia...
Come on, you like this one better! ;-)
Tim Nikias
Date: 31 Oct 2002 07:54:56
Message: <3dc12820$1@news.povray.org>
It's nice that we have a source object.
Did you say there is also some interaction with a field (besides gravity)?
I'm not nitpicking, but if your algo is that sophisticated, then a
demonstration scene should make this more apparent, say with a "fan" giving
the viewer a visual expectation of the field....
______________
Greg M. Johnson
lone, resentful person
Date: 31 Oct 2002 09:25:03
Message: <web.3dc13d08221d6207dc7e5c90@news.povray.org>
I'm answering using the beta-posting of the
newsgroups, as I'm at my university...
I don't know where you got that "interactive
field" idea from. The physical simulation, which
only covers bouncing off of an unrotated box (or
the required planes, as single walls/ceiling/floor
may be turned off), only interacts with gravity.
Then there is a simple simulation, which adds
gravitational effects and some sort of wind, though
this is a more artistic than realistic approach.
Finally, you yourself can supply a macro which
has parameters that you can use to define the
path a particle takes.
In all cases, bounding-box and/or -sphere may be
used to keep particles in a confined space.
I have been thinking about trying to make the
physical simulation use wind into account, and
this might even be possible, given the recent
changes I've made to the system's algorithm. But
I'll look into that. But interacting with fields,
like a blowing fan, is definetely a no-no.
I know, thats sad, and after all, I think my
system won't gain much attention apart the
initial "checking-it", but it may become a
nice source for learning, its written and commented
very thoroughly and understandable. I tried not
to be too obfuscated... :-)
Well then, gotta leave!
Tim
Date: 31 Oct 2002 12:21:53
Message: <3dc166b1$1@news.povray.org>
"Nikias" <tim### [at] gmxde> wrote in message
news:web.3dc13d08221d6207dc7e5c90@news.povray.org...
> field" idea from.
Okay, I'm saying your code has an added functionality--  "some sort of
wind"-- as you say.   To show off this bell and whistle, put an object that
will give the viewer a reference point for the wind, such as a fan.  Then
the viewer will be more impressed as he or she may understand and expect a
certain effect, rather than simply getting "more confused" if  a force other
than a fall downward is perceived.
______________
Greg M. Johnson
lone resentful person
Date: 31 Oct 2002 13:02:25
Message: <3dc17031@news.povray.org>
that
other
Eh?
There are no external forces present in this animation. The emitter
moves along the specified railway. Particles are born on the surface
and move with the emitter the instant they are born, but then
have no contact with the emitter in any way.
So. Imagine yourself in a rollercoaster, holding a glass of
water. You know what happens when you're tossed around
in curves, right? That's inertia.
Its not an actual external field in the algorithmic sense of things.
Its the movement the emitter inhibits at the moment the particle
is born. Other than giving some velocity to the particle,
only gravity is applied. Everything else is then just calculated
from then on.
IF you're talking about making an NEW animation, showing off
other aspects than gravity and bouncing off of the boundary-
box, THEN I can only say: Yes, those animations are to come
as well. I'm creating one demonstration of a specific feature at
a time. Rainbow was for custom particles, Drops as a plain
simulation of gravity and rebounce, Inertia shows off the effect
moving emitters may have on particles.
And if I'm still not understanding you, then I don't know what
to think of my brain. ;-)
Apologies if I don't get it, had a hard week so far!
Tim
Tim Nikias
that
other
Date: 31 Oct 2002 15:05:03
Message: <web.3dc18c51221d62040d56c170@news.povray.org>
>>> adds gravitational effects and some sort
>>> of wind,
>Eh?
> animation.
Okay, sorry thought there was some sort of wind.  Just an idea for the time
that you do implement some sort of wind.  Nice work once again....
