POV-Ray : Newsgroups : povray.binaries.animations : More gum chewing Server Time
11 Jun 2026 18:37:48 EDT (-0400)
  More gum chewing (Message 11 to 15 of 15)
Subject: Re: More gum chewing (305 kbbu)
Date: 2 Nov 2002 06:42:48
Message: <3DC3B9DB.106C7AD1@onwijs.com>
"Greg M. Johnson" wrote:
> > To be honest I like the previous one better
> > (pose329sun.mpg)
> WAAAAAAAAAAAAAAAAAAAAAAAHHHHHHHHHHHHHHHHH!
I couldn't see it...
> > but that might also be because
> > it's smaller. The ridges on the
> > lower jaw look too artificial.
> Good point that I should find another way to get a pointy chin.
You might try a flat sperical blob element.
Perhaps with the amount of elements you're using it isn't really
a problem but I found that cylinders in blobs can slow down the
rendering dramatically.
Remco
Date: 4 Nov 2002 22:46:27
Message: <3dc73f13@news.povray.org>
Download 'pose330drawn5mon2.mpg' (282 KB)
Date: 4 Nov 2002 22:54:35
Message: <3DC740E0.58E069D7@pacbell.net>
His teeth need gums and fuller lips would really help.
Ken Tyler
Date: 5 Nov 2002 00:51:00
Message: <3dc75c44@news.povray.org>
Yep... jaw looks much better!... now all you have to do is bring the top lip
down and the bottom lip up... so they meet in the middle... :)  Also as the
other post says... fill the lips out a bit too.
Otherwise fantastic work!
Date: 5 Nov 2002 08:25:17
Message: <3dc7c6bd$2@news.povray.org>
Ultimately, the mouth will be made from cutout shapes to match the mouth
openings in:
http://www.comet-cartoons.com/toons/3ddocs/lipsync/Phon-Typical.jpg
Making actual lips is doable, but I cannot figure out a way to have lips AND
my programmable lip-sync capabilities. That is, without having a
40-component mouth hole, and my interest is not in that degree of mouth
realism.
Ken couldn't see the existing gums because as I later discovered, the teeth
are actually too far back into the mouth, and the "hole" for the "mouth
interior" actually cuts through the lower jaw.
I'll try to have a great step forward before I post more of this dribble
ware....
"Aaron" <aar### [at] ihugconz> wrote in message
news:3dc75c44@news.povray.org...
lip
the
