POV-Ray : Newsgroups : povray.binaries.animations : Four Dimensional Noise Server Time
10 Apr 2026 07:20:57 EDT (-0400)
  Four Dimensional Noise (Message 1 to 3 of 3)
Subject: Four Dimensional Noise
Date: 6 Oct 2002 18:45:58
Message: <3da0bd26@news.povray.org>
I'm fiddling with the POV-Ray source code and working on creating a 4D noise
generator (noise_generator 4). This should help a lot during animations
where you want to change a function that's based on noise but you can't
simply translate it along a 3D vector, since it wouldn't look quite right.
(Those who have tried animating textures probably know what I'm talking
about.)
The example I provided (attached) is on a sphere. The noise generation is
based on noise_generator 3, since that was the easiest to work with.
Unfortunately, it takes a little over twice as long to calculate, which is
still acceptable, but undesireable for animations. Win some, lose some.
*shrug*
At the moment, I'm using the syntax
  bozo
  color_map {[.1 rgb x][.9 rgb z]}
  noise_generator 4
  slice clock * 10 - 5 // amount through the 4th dimension
  scale .2
but I'm probably going to work towards a syntax more like
noise_generator {
 4
 slice 10
and, eventually, i hope to add a "repeat" keyword so that it can be used for
cyclic animations.
 - Slime
[ http://www.slimeland.com/ ]
Download 'noise4dtest.mpg' (168 KB)
Subject: Re: Four Dimensional Noise
Date: 7 Oct 2002 05:47:23
Message: <3da1582b@news.povray.org>
Waheeeey! Nice one! Been wanting this feature for a while now...
Andrew.
Date: 15 Oct 2002 05:05:08
Message: <web.3dabda08c21c43cf11b82ee40@news.povray.org>
Nice! =)
I'm looking forward to f_noise4d(x,y,z,t).
4D-noise in functions.
