POV-Ray : Newsgroups : povray.binaries.animations : Dancing Flames of Fire (128 kb mpg) Server Time
11 Jun 2026 20:29:40 EDT (-0400)
  Dancing Flames of Fire (128 kb mpg) (Message 15 to 24 of 24)
Subject: Re: Dancing Flames of Fire (128 kb mpg)
Date: 8 Sep 2002 12:56:03
Message: <3d7b8123@news.povray.org>
Rick [Kitty5] wrote:
> Thats some of the best pov fire I have seen, nice work
Thank you Rick! :)
Rune
rune|vision:  http://runevision.com (updated July 12)
POV-Ray Ring: http://webring.povray.co.uk
Date: 8 Sep 2002 19:06:03
Message: <3d7bd7db@news.povray.org>
What?! No smoke? No burnt hair? ;-)
My campfires usually turn out to be small bonfires. It's very good anyway.
Date: 8 Sep 2002 23:01:46
Message: <3d7c0f1a@news.povray.org>
This is very impressive! Much better than the one from a year-ago, and it wasn't
bad. :)
How well will this scale in size? Larger fires tend to have more swirling
turbulence at their periphery from all of the micro convection currents. I see
some of this in your animation (briefly on the upper right side) and was
wondering how controllable is this parameter?
light_source{0,1}#macro c(J,a)sphere{0,1pigment{rgb z}scale a translate J+O}
#end#macro B(R,V,O)c(0,4)intersection{c(V,R)difference{c(-z*4x+10)c(-z*4.1x+
10)c(0<7.5,45,5>)}}#end B(12,0z*25)B(8y*4<0,12,50>)          // Batronyx ^"^
Date: 9 Sep 2002 06:27:33
Message: <20020909155614.1e9af909.kedarDELETE_THIS@patilkedar.com>
> <lots of text deleted>
> So please comment. :)
I once tried doing fire using particle systems in OpenGL and I
must admit that your version looks a lot better than mine.
<pov-praise-mood> Maybe partly it is due to the fact that yours
is done in POV.  POV simply ROCKS!</pov-praise-mood>  But good
work on your part too.
> I think it can be released within a few months.
Polish the code and release it ASAP.  I am getting impatient
to try it :)
-Kedar
Date: 9 Sep 2002 12:53:38
Message: <3d7cd212@news.povray.org>
Thank you. :)
I may try something bigger to see if I can make it look ok...
Rune
rune|vision:  http://runevision.com (updated Sep 8)
Date: 9 Sep 2002 12:53:39
Message: <3d7cd213@news.povray.org>
Thank you! :)
> to have more swirling turbulence at their periphery
> from all of the micro convection currents. I see some
> side) and was wondering how controllable is this
> parameter?
Not very controllable I think, but some air turbulence might help.
I'll try to see if I can make a bigger fire and make it look ok.
Rune
Date: 9 Sep 2002 12:53:40
Message: <3d7cd214@news.povray.org>
> OpenGL and I must admit that your version looks a
I don't think OpenGL and POV-Ray can be compared very well when it comes
to rendering quality. Can OpenGL even simulate volumetric effects
similar to media? Or how did you render the fire? Textured polygons
facing the camera?
> impatient to try it :)
I'll do my best. :)
Rune
Subject: New version
Date: 9 Sep 2002 12:53:41
Message: <3d7cd215@news.povray.org>
I've uploaded a new version of the fire to my web site. There are no
significant improvements, the light source is just not quite as white. I
also had to change the way that the media for the fire works, and I hope
it doesn't degrade the look of the fire.
http://runevision.com/3d/anims/
The reason I had to change it is that I discovered that the nice-looking
fire was caused by a too low amount of media samples. With increased
samples, the fire began to look very bland and boring. So I had to come
up with a different method that would look good both when few and many
samples are used.
Rune
Date: 10 Sep 2002 19:45:24
Message: <B9A441CF.4840%fidel.viegas@artrecognition.co.uk>
in article 3d7a641d@news.povray.org, Run### [at] runejohansen@mobilixnet.dk
wrote on 7/9/02 9:37 pm:
> More than one year ago I attempted to create a nice camp fire using my
> particle system. The result was not too bad, but not very good either I
> think.
> Now I've tried again to make that camp fire, and the result is better
> this time I think. The animation is attached here. As I see it, it has
> more of that fire-like quality, which made me come up with the subject
> line.
I have seen you previous one and I think this one is a good improvement.
> But as always, working on a project for a while makes you somewhat
> blind, and thus, other people are best at spotting the possible flaws
> and errors there are. So please comment. :)
> By the way, I haven't been working on the particle system for some
> months, but now I'm on it again, and I think it can be released within a
> few months.
That should be cool.
Fidel.
Date: 11 Sep 2002 08:00:24
Message: <20020911172846.02cb4cdb.kedarDELETE_THIS@patilkedar.com>
> it comes to rendering quality. Can OpenGL even simulate
> volumetric effects similar to media?
I agree with you.  OpenGL has a polygons-and-textures type of
rendering engine.
I think I should have expressed myself more clearly.  I
wasn't comparing the rendering quality, but the behaviour of the
fire as a particle system.  What I had done was a kind of quick
hack to learn OpenGL and C++.  Your system seems to be more
"real" -- most probably it is based on more accurate physics
than what I used.
> Or how did you render the fire? Textured polygons facing the
> camera?
Yes, that's what I used :)  The rendering quality was not that
bad.  But, as you said, OpenGL is not to be compared with
POV-Ray.
-Kedar
