POV-Ray : Newsgroups : povray.binaries.animations : Cyclical cloud movement Server Time
3 Jul 2026 08:33:13 EDT (-0400)
  Cyclical cloud movement (Message 11 to 13 of 13)
Subject: Re: Cyclical cloud movement
Date: 27 Aug 2002 17:46:59
Message: <3d6bf353@news.povray.org>
"Thies Heidecke" <h3i### [at] gmxnet> wrote in message
news:3d6bf04a@news.povray.org...
> "Pandora" <pan### [at] pandora-softwarecom> schrieb im Newsbeitrag
> news:3d6bee5e@news.povray.org...
> >     Is it DivX'd ?
> >     What version ?
> It's encoded with the free Version of DivX 5.0
    Huh ? Like what-the... Well I dunno where I was looking b4 - I go to
www.divx.com and bingo there it is DivX 5.0!
    How long's it been out ? hmm... v.5.0 released 04-03-2002 - it can't
have been that long since I checked, can it ??? Guess it must have been...
Freaky... It feels, like, just yesterday...
(I must be getting old, or something.)
Pandora/Scott Hill/[::O:M:C::]Scorpion
Software Engineer.
http://www.pandora-software.com
Date: 27 Aug 2002 20:17:40
Message: <3d6c16a4@news.povray.org>
Thanks, Thies! That looks great! I was using a sine function applied to the
turbulence (lambda) of a pigment, and had a little success. The problem was
that the clouds would change really quickly between 0 and about 60 degrees,
then not change much at all between 60 and 120 degrees, then start moving
really fast again. It looked awkward. I tried to compensate by using four
different pigments each offset by a few degrees so some were changing
quickly while others weren't, and that helped some. But your solution (and
Greg Johnson must have been suggesting a similar solution) is much better.
And it's a heck of a lot simpler, too.
Dave
news:3d6bde35@news.povray.org...
> Hi again,
> I made an example-scene which shows the basic use of it.
> Sorry for the pseudo-code in my last post, was a bit lazy..
> To get the formula to work within POV one has to use
> a pattern-function. The cyclic-animation Trick works
> by making a Linear-Interpolation between two instances
> of the cloud-pattern. The Trick is to translate the second
> pattern in such a way that it is identical to the first
> pattern when the loop is finished. Thats actually what the
> formula does.
> feel free to ask if something's still unclear.
> Greetings,
> Thies
Date: 28 Aug 2002 07:26:29
Message: <3d6cb365$1@news.povray.org>
news:3d6bea12@news.povray.org...
> Sorry, here the same anim as mpeg.
Wild, and thanks greatly for posting MPG-1.
