POV-Ray : Newsgroups : povray.binaries.animations : Yet another Media Sky [WIP] Server Time
11 Jun 2026 20:29:41 EDT (-0400)
  Yet another Media Sky [WIP] (Message 7 to 16 of 16)
<<< Previous 6 Messages Goto Initial 10 Messages
Subject: Re: Yet another Media Sky [WIP] - DivX [541 kb]
Date: 18 Aug 2002 15:43:25
Message: <3d5ff8dd$1@news.povray.org>
"Hugo" <hua### [at] post3teledk> wrote in news:3d5ff28e$1@news.povray.org...
> The clouds look convincing from a distance.
Thanks!
> But flying through the plane makes them appear too thin..
Yes, you're right. I made the clouds so thin firstly because of render-time
and secondly i had problems with thicker clouds getting too greyish like
some rainclouds.. Perhaps i can get the look right with different extinction-
values..
> I would also be interested in a direct
> fly-through a dense cloud, which is not possible with planes.. Anyway, the
> render time is very reasonable and that matters a lot!
Yep, i'll try to make a flythrough in the next animation.
> The DivX version looks almost like mpeg1 so try compressing it to 80 kB next
> time.  ;o)  DivX is SO good..
> Regards,
> Hugo
Greetings,
Thies
Subject: Re: Yet another Media Sky [WIP] - MPEG [503 kb]
Date: 20 Aug 2002 08:05:57
Message: <3d6230a5$1@news.povray.org>
Very cool.  It's even neater that it's animatable.
Date: 20 Aug 2002 13:43:32
Message: <3d627fc4$1@news.povray.org>
Very impressive, good render time too.
I was thinking of doing a 'from orbit' picture of a skyhook descending to
it's docking station - your picture reminded me of the final stages of that
descent.
What are you going to do with it?
                  == John ==
"Thies Heidecke" <h3i### [at] gmxnet> wrote in message
news:3d5f5df6$1@news.povray.org...
> Hi,
> This is my first try to make (more or less) realistic
> media-clouds. The cloud-media is contained by two
> parallel planes which form the cloud-layer. At ground-
> level i've placed a reflective plane for now. Additionally
> there is an atmospheric media to blend the horizon smoothly
> into a white color. The cam's location moves along a straight
> line, starting above the clouds and ending nearer to the ground
> (I know, it's not very spectacular :)
> I am not satisfied with the cloud-shape yet and the horizon-effect
> is a bit too strong, too.
> Rendertime was about 2 - 3 minutes per frame at 256x192 on my
> 700MHz-machine
> Comments and Criticism are welcome :)
> Thies
> P.S.: video-files are appended in replies
Date: 20 Aug 2002 13:59:45
Message: <3d628391@news.povray.org>
"Greg M. Johnson" <gregj:-)565### [at] aolcom> schrieb im Newsbeitrag
news:3d6230a5$1@news.povray.org...
Thanks! I'm already rendering the next animation =)
Greetings,
Thies
Date: 20 Aug 2002 14:21:14
Message: <3d62889a$1@news.povray.org>
"John D. Gwinner" <jgw### [at] dazsicom> schrieb im Newsbeitrag
news:3d627fc4$1@news.povray.org...
Thanks! though i fear that the rendertime increases as the clouds get more
detailed
and higher res.
> descent.
Yeah, that would be a possible use of it, but for greater distances, e.g from
space, one probably had to blend into an other method, i think.
I plan to make the clouds look more realistic and detailed and to write a
macro around it for easier handling (like in Jaime Vives Piqueres' stsky.inc),
more different cloud-types (cirrus, stratus, cumulus) for simultaneous use,
improved atmosphere (best would be with physically correct color-gradients
for sunsets and such..) and support for sphere-shaped atmospheres for planets
(currently it's an endless plane).
Quite some work before me =) (This could take some time...)
At the moment the media-density pattern for the clouds and the right
absorbtion
and lighting gives me headaches.. hopefully i'll get it right soon.
>                   == John ==
Greetings,
Thies
Date: 20 Aug 2002 17:00:53
Message: <3d62ae05@news.povray.org>
If you do all that :-) I can wrap it up into a plug in for Moray.
                  == John ==
news:3d62889a$1@news.povray.org...
> detailed
> and higher res.
to
that
> > descent.
from
stsky.inc),
use,
planets
> absorbtion
> >                   == John ==
> Greetings,
> Thies
Date: 21 Aug 2002 21:31:18
Message: <3d643ee6@news.povray.org>
Grrr... Another DivX anim I can't view...
Pandora/Scott Hill/[::O:M:C::]Scorpion
Software Engineer.
http://www.pandora-software.com
Date: 22 Aug 2002 05:56:28
Message: <3d64b54c$1@news.povray.org>
"Pandora" <pan### [at] pandora-softwarecom> schrieb im Newsbeitrag
news:3d643ee6@news.povray.org...
Thats the reason why I posted the animation as mpeg, too.
Their content is equal.
> Software Engineer.
Greetings,
Thies
Date: 4 Sep 2002 01:48:42
Message: <3d759eba$1@news.povray.org>
Could you post your latest code, please?
Grim
Date: 4 Sep 2002 07:06:38
Message: <3d75e93e@news.povray.org>
"GrimDude" <gri### [at] cox-internetcom> schrieb im Newsbeitrag
news:3d759eba$1@news.povray.org...
Sure, i had planned to post it, but i first wanted to clear it up
a bit first and do some more research to make them more realistic.
But if you are interested i'll post the current version. i have to
add though, that my current Version doesn't look as good as the
anim in this post imho.
I'll post the source in p.b.s-f and my latest anim in p.b.a
> Grim
Greetings,
Thies
