POV-Ray : Newsgroups : povray.binaries.animations : Particle System Explosion 3 Server Time
12 Jun 2026 00:49:41 EDT (-0400)
  Particle System Explosion 3 (Message 3 to 12 of 12)
<<< Previous 2 Messages Goto Initial 10 Messages
Subject: Re: Particle System Explosion 3
Date: 15 Feb 2002 16:46:55
Message: <3c6d81cf@news.povray.org>
Wow! That's awesome!!
It looks so solid, just like real explosions. The column of fire/smoke after the
main explosion is loads better than the earlier ones. And the main explosion is
just amazing.
What's the render time like?
Tek
http://www.evilsuperbrain.com
Rune <run### [at] mobilixnetdk> wrote in message
news:3c6d4c7a@news.povray.org...
> I wonder how many will bother to have a look at this one, knowing that the
> first two were so similar...
> But I think this one is a greater improvement than version 2 was. I have
> made the smoke darker and made it last longer, I have made the column wider
> in the start, and I've added dust near the ground, which I think is a nice
> touch (well, it's more than just a "touch" with the amount I added).
> Now I can see how the first version looked video-game-like, but I couldn't
> tell back then... :)
> One things I've wondered about is if the explosion is too big compared to
> the building. Should I make it slightly smaller?
> I've decided not to go with the debris after all, as it will make the
> animation too advanced for a demo scene. I've made a big hole in the
> building though, but that's not very easy to see.
> Comments much appreciated!
> Rune
> 3D images and anims, include files, tutorials and more:
> Rune's World:    http://rsj.mobilixnet.dk (updated Jan 20)
> POV-Ray Users:   http://rsj.mobilixnet.dk/povrayusers/
> POV-Ray Webring: http://webring.povray.co.uk
Date: 15 Feb 2002 18:13:25
Message: <3c6d9615@news.povray.org>
> > at this one, knowing that the first two were so similar...
> Me!  :o)  I'm impressed.
Thanks! :)
> Actually I thought about explosions in Pov too just
> a few days ago ... and here you're working on it...
> Good you didn't have to start from scratch as I would
> have needed...
Well, I had my particle system, but besides that I had to start from
scratch. That doesn't mean though that a particle system is required to
create explosions, it's just one out of many ways, but one I haven't seen
investigated much in POV-Ray.
> Well, I haven't read all the comments so far but I'd
> like to say 2 things: Third version is the best.
I think so too.
> For further improvement, the fire shouldn't immediately
> go up in the air, as it does now.
I'm not sure I agree with that but again it comes down to reference
material. I'm always interested in good reference animations, though file
sizes shouldn't be too big...
> A third thing to mention: How would it look if the camera
> doesn't move? I like the circlulation of the smoke but it's
> caused by the camera only.
I'm not sure what you mean. The smoke itself doesn't rotate, only the camera
rotates around the smoke. However, I think sometimes myself that it looks
like the smoke rotates. I think it's related to the fact that I'm using a
texture trick instead of real media. Each fire ball is mapped onto a sphere
with a slightly larger radius than the apparent radius of the fireball, thus
the depth is actually too big.
> That's enough for now.. I'm looking forward to anim 4.
Actually I think this one was the final one. (But of course you never
know...)
Rune
Date: 15 Feb 2002 18:13:30
Message: <3c6d961a@news.povray.org>
I'm very glad you think this version is better than the previous! :)
About half an hour for the entire animation on a 1 GHz machine.
What would it have been using media instead. 5 times as long? 10 times as
long? ...
Rune
Date: 15 Feb 2002 19:06:58
Message: <3c6da2a2$1@news.povray.org>
Well, I don't think I have proper material around, but I was referring to
the stiff movement in the Y direction. There's no acceleration, it just
"turns on" at the moment it explodes, which looks computer generated.
camera
Yeah .. ehm, I know the smoke doesn't rotate.. Only the camera does.. I was
interested in knowing if the whole thing would look worse, if the camera
didn't move.. In other words, if you added the movement to enhance the look
(would be a bad trick).  ;o)  And I think about, that maybe it wouldn't hurt
if the smoke itself rotated a bit.. I'm not sure that's realistic though,
but it seems to add "life" to the fire/smoke.
Regards
Hugo
Date: 16 Feb 2002 02:40:34
Message: <3c6e0cf2$1@news.povray.org>
Cool!
But shouldn't there be a mushroom-like cloud formation? The outside of the
smoke column cools down faster and has more air friction than the inner
side.
Maybe the info at
http://www-imagis.imag.fr/Membres/Fabrice.Neyret/clouds/index-eng.html can
be of any help.
Keep up the good work.
Date: 16 Feb 2002 05:25:03
Message: <3c6e337f$1@news.povray.org>
better and better - don't know about the smoke that falls away tho
PGP Public Key
Date: 16 Feb 2002 18:31:42
Message: <3c6eebde@news.povray.org>
"Apache" wrote:
> Cool!
Thanks!
> The outside of the smoke column cools down faster and
> has more air friction than the inner side.
Yes, but my system can't simulate such things as temperature and air flows
so I'm afraid there's a limit to the physical accurancy that I can obtain.
> Maybe the info at
> can be of any help.
Thanks, I'll have a look.
Rune
Rune's World:    http://rsj.mobilixnet.dk (updated Feb 16)
Date: 16 Feb 2002 18:31:44
Message: <3c6eebe0@news.povray.org>
> that falls away tho
Do you mean that on the ground that doesn't rise in the air? It's supposed
to simulate dust and particles from the building actually, which unlike the
fire and smoke would slowly fall to the ground.
Rune
Date: 17 Feb 2002 10:13:41
Message: <3c6fc8a5@news.povray.org>
I like it very much Rune! I was wondering... can I have the code for this?
I'd like to render it with slightly different timing to see if that helps...
Date: 17 Feb 2002 16:39:08
Message: <3C70228E.A728B735@yahoo.com.au>
probably more than you might think :-)
Despite this, the changes you have made make a difference. Explosions are so
complicated that achieving anything close to the real thing is an effort. It
looks like you have made the effort here.
MJL
text{ttf"timrom.ttf"concat(#local O=1;#while(O<7)chr(val(substr(concat(#local Q=
1;#while(Q<7)str(asc(substr("???<?>",Q,1))-56,0,0),#local Q=Q+1;#end""),O,2))),#
local O=O+2;#end"").1,0pigment{rgb 9}translate-<1,.3,-2>} // MJL
