POV-Ray : Newsgroups : povray.binaries.animations : Particle System Explosion 2 Server Time
3 Jul 2026 13:39:53 EDT (-0400)
  Particle System Explosion 2 (Message 11 to 16 of 16)
Subject: Re: Particle System Explosion 2
Date: 14 Feb 2002 20:13:02
Message: <3c6c609e@news.povray.org>
"Mark James Lewin" wrote:
> I cannot see too much difference between the two;
Honestly - I can't either...
Still, I gave the particles more of a 3d feel (don't know if that's really
visible), I made the colors more intense, and of course I added shadows.
> technical: 10
> realism:    7
Ok, that's fair enough. :)
> Explosions like this (if Hollywood is anything to go by :-)
> give blacker smoke, secondary fires, and debris.
I'll look into those!
> Computer game explosions in general don't have these
> things, which is why your explosion reminds people of them.
I think you're right.
> If all you were after was a demonstation of your system's
> capabilities though, you have achieved it.
Well, the point of my system is to create satisfactory results, so if the
demonstration doesn't show that properly, it has only partly succeeded at
most.
Rune
Rune's World:    http://rsj.mobilixnet.dk (updated Jan 20)
Date: 14 Feb 2002 20:13:03
Message: <3c6c609f@news.povray.org>
"Skip Talbot" wrote:
> How about making that media much more dense...
> so it loses its transparency until the smoke
> has well dissipated?
I'll try it out and see if it looks better.
Rune
Subject: Re: Particle System Explosion 2 (reply to Tim Nikias)
Date: 14 Feb 2002 20:13:04
Message: <3c6c60a0@news.povray.org>
"Tim Nikias" wrote:
> Well, you've used spheres and mapped the
> textures on them, right?
Ok, yes I do, but in a very special way. I use procuderal textures that
don't look the same from all angles, but rotate together with the particles
to give it a 3d feel. I think I managed to trick a few people to think that
it was media this time... ;)
> It does look better, but if you look closely
> at the shadows, you'll notice that there are
> "jumps": suddenly a spherical shadow disappears
> as the object (already totally transparent at
> the time) is taken out of the scene.
I hadn't noticed that but you're right! Looking at the code I can't see the
problem right now, but I'll try to find out why it happens.
> I know this kind of problem, I had it too sometimes.
> Perhaps your spheres don't end up 100% transparent,
> due to the image-map (as I think it is) you're using?
I don't use image_maps of any kinds.
> As suggested on the first animation, I think adding some
> twisting and swirling would look a lot better, but as
> also mentioned, using image-maps and not real 3D clouds
> makes that impossible...
I can easily do twisting and curling of the particles with the texturing
system I use, but I don't know in what way to do it. Real explosions and
smoke twists and curls due to complex air flows that I can't simulate. I
don't know around what axis each particle should be rotated, and even if *I*
knew, I'd still to find a way to make the *particle* know, which is not so
easy.
Rune
Date: 14 Feb 2002 23:10:54
Message: <3C6C89C2.2A15071D@yahoo.com.au>
> most.
If my systems ever get released, my demos will not be flashy. Rather, they will
show the capabilities, and maybe make those more artistic than myself think
"yeah, that's sort of what I want. I wonder whether I can make it do that, but
with more smoke and... and... and..." and anything else they can think of.
MJL
text{ttf"timrom.ttf"concat(#local O=1;#while(O<7)chr(val(substr(concat(#local Q=
1;#while(Q<7)str(asc(substr("???<?>",Q,1))-56,0,0),#local Q=Q+1;#end""),O,2))),#
local O=O+2;#end"").1,0pigment{rgb 9}translate-<1,.3,-2>} // MJL
Date: 15 Feb 2002 06:07:39
Message: <3C6CEBF9.4AC62DF5@gmx.de>
Rune wrote:
> > What's seriously missing is the interaction with the
> > environment, meaning how the path of the explosion is
> > influenced by the surrounding objects
> Uh, I wouldn't know where to start with that. Could you verbally give an
> example of how the path of an explosion could be affected by its
> surroundings?
If you for example have some wall near the explosion facing it, the
explosion will be kept away from the back side of it, it will somehow
spread across the facing surface, unless the wall is destroyed by the
explosion of course.
> > and also how the objects are damaged by the explosion.
> I'll leave that to Chris Colefax's object exploder for now. I might
> integrate something into my own particle system at one point, but not in the
> first version.
You could start making a hole with some stuff scattered around at the
explosion origin.  This would not need to be well animated since it is
covered by the explosion when it occurs.
Last updated 06 Feb. 2002 _____./\/^>_*_<^\/\.______
Date: 15 Feb 2002 06:49:15
Message: <3c6cf5bb@news.povray.org>
> Rather, they will show the capabilities, and maybe make those
> more artistic than myself think "yeah, that's sort of what I
> want. I wonder whether I can make it do that, but with more
That's sort of the case with my demos too, but I'd still like to make them
just a little flashy. And if it doesn't make the demos too complicated, it
doesn't hurt if they're very flashy.
There's a little marketing man hidden inside me. He wants to make things
look good and appealing to people's feelings rather than their common
sense... ;)
Rune
