POV-Ray : Newsgroups : povray.binaries.animations : Particle System Explosion Server Time
14 May 2026 22:48:47 EDT (-0400)
  Particle System Explosion (Message 1 to 10 of 27)
Subject: Particle System Explosion
Date: 13 Feb 2002 11:35:44
Message: <3c6a95e0@news.povray.org>
I've been working on a way to use my particle system to create explosions.
This is the result so far. It took a long while to tweak it to look like
this, and by now I think I've worked so much on it that I can't judge it
myself anymore; I need outside opinions. So what do you think?
The animation is 100 frames long and was rendered at 320x240 AA 0.3 on a
1GHz computer. Try to guess how long it took.
Rune
Rune's World:    http://rsj.mobilixnet.dk (updated Jan 20)
Download 'explode.mpg' (503 KB)
Subject: Re: Particle System Explosion
Date: 13 Feb 2002 12:10:52
Message: <3c6a9e1c$1@news.povray.org>
Hi Rune,
I think the actual explosion/flames/smoke look perfect, *except* for the way
that the building shows through the explosion as solid lines, similar to
what happens in many games (which I think looks terrible). Not sure how this
could be avoided though.
All the best,
Andy
"Rune" <run### [at] mobilixnetdk> wrote in message
news:3c6a95e0@news.povray.org...
> Rune
> 3D images and anims, include files, tutorials and more:
Date: 13 Feb 2002 15:29:04
Message: <3c6acc90@news.povray.org>
Looks quite nice, but I'd suggest using isosurfaces or dense media instead to
get a more 3D feel. At the moment it looks a lot like it's just flat polygons
facing the camera, which doesn't really suit pov's abilities, it's only the
early stages of the explosion that you can see the particles are actually media
(and even then I had to pause the animation to be sure).
I'd guess about 5 minutes per frame.... if it is pov...
Actually now I look closer I'm not convinced it is ray traced! Where's the
shadows? Is this just a real-time animation using a pov rendered explosion
texture on each particle?
(apologies if it isn't, but this is just how it looks to me)
Tek
http://www.evilsuperbrain.com
Date: 13 Feb 2002 16:15:33
Message: <3c6ad775@news.povray.org>
Thanks!
> *except* for the way that the building shows through the
> explosion as solid lines, similar to what happens in many
Hmm yes... :(
Rune
Date: 13 Feb 2002 16:15:36
Message: <3c6ad778@news.povray.org>
> dense media instead to get a more 3D feel.
Isosurfaces have sharp edges and are not easy to use to create flame and
smoke IMO.
> polygons facing the camera, which doesn't really
Heh, it looks like flat polygons facing the camera? :p
> it's only the early stages of the explosion that you
> can see the particles are actually media (and even
So it first looked like flat textured polygons, but after a closer
inspection you became sure that it was media after all?
> Where's the shadows?
Arg, you caught me!
> explosion texture on each particle?
No, it's POV-Ray all right. But it *is* textured discs facing the camera.
Ok, so it's not a replacement for good old media as your observations
reveal...
> > at 320x240 AA 0.3 on a 1GHz computer. Try to guess
> > how long it took.
But here's the positive side. It's only 9 seconds per frame, for a total of
15 minutes for the whole animation. Not exactly real-time as you thought,
but quite fast for a POV-Ray animation.
Rune
Date: 13 Feb 2002 17:11:21
Message: <3C6AE427.A8FF1A57@yahoo.com.au>
I like the fire after the explosion, but the way the mushroom cloud disperses
looks a bit odd to me. Maybe if the column of smoke from the fire was thicker
just after the explosion, and dwindled down, it may look better.
My guess is 1.5 - 2 hrs. It really depends on how many particles you have, and
whether you are using media or not. I suspect this is not media (discs perhaps?)
just because, if you make Al chew gum whilst walking, you would surely make
absorbing smoke which would leave a shadow :-)
MJL
light_source{9*(y#macro A(H,B,R,T)prism{0,1H+4,0u*9,9v*9,0#local I=1;#while(I<H)
#local V=asc(substr(B,I,1))-33;<div(V,10)mod(V,10)>#local I=I+1;#end pigment{rgb
y}rotate-<90,R>translate-T}#end-z)rgb 9}A(14",6;MWmhryXN3,"60<15,0,8>)box{-99(x+
z)*99pigment{rgb 1}}fog{distance 11}camera{location(y-z)*25look_at 0}A(8"6hiAG=6
"-60x*-10)A(16"/.@VZno=<PLA89/"0x*5) // MJL
Date: 13 Feb 2002 17:14:48
Message: <3c6ae558@news.povray.org>
> reveal...
Aha! I was consfused by that but now I see it.
That would be a very effective technique for distant explosions or previewing an
animation, but I'd like to see how good it would look with media!
BTW, if you want to get shadows you could get a second set of discs facing the
light source and use the no_image tag :)
Tek
Rune <run### [at] mobilixnetdk> wrote in message
news:3c6ad778@news.povray.org...
> smoke IMO.
> Arg, you caught me!
> reveal...
> > > how long it took.
> Rune
Date: 13 Feb 2002 17:29:05
Message: <3C6AE8A7.38991E0@gmx.de>
It does look really good, but by what I've seen your particle-system
do before, I was rather disappointed.
Thats just the case when you normally post animations that get
comments like "Jesus! I need to dig into POV a LOT more!" ;-)
As others have mentioned already, it looks 3D-Game-esque,
not POV-RAY. I mean, hey? What did you expect? We're
talking about the one, the only, the freeware raytracer
POV-Ray! Doh!  ;-)
Okay, I do like POV-Ray a lot...
And you post an animation just as I'm about to take the
next two non-computer weeks to work through a printed
version of my Particle-System, and finally get it finished,
now that my IRTC-Entry (my first!) has been sent in...
Hooya! (Starship Troopers Battle Cry)
See ya, and I'll just hope you'll post a media-version in a few
days (hey, you've got two weeks, then I'll be back!) ;-)
Tim Nikias
Date: 13 Feb 2002 17:30:12
Message: <3C6AE890.2D0B36D3@yahoo.com.au>
Just saw your reply to Tek; so they are discs. To make them cast shadows, you
could use a smart combination of light groups, discs and no_image / no_shadow to
make a shadow effect. Keep your camera oriented discs for visuals, and use
light_source oriented discs for shadows.
MJL
Date: 13 Feb 2002 17:31:59
Message: <3C6AE8FF.673EE066@yahoo.com.au>
I am too slow today... (see my 2nd reply to Rune)
