POV-Ray : Newsgroups : povray.binaries.animations : Particle System Explosion Server Time
3 Jul 2026 15:18:01 EDT (-0400)
  Particle System Explosion (Message 21 to 27 of 27)
Subject: Re: Particle System Explosion
Date: 14 Feb 2002 20:12:56
Message: <3c6c6098$1@news.povray.org>
"Tek" wrote:
> Well the thing that really makes them look computer
> game-y is the fact that you can see lots of seperate
> identical textures.
I'm not sure what you mean by that. Of course all the textures are made from
the same pattern, but unique turbulence is added for each particle, so
they're not identical. Maybe I should also vary the colors a bit?
> Plus their motion is such that it gives away where the
> seperate particles are. i.e. all the fire is either
> following one motion or another, none of it is inbetween.
I don't understand this either. I don't have a set of predefined paths, all
the particles react the same way on (inverse) gravity and wind, and besides
that some randomness is added.
I tried using more particles, but it just made the fire and smoke much more
blurred, because more textures were averaged...
Rune
Rune's World:    http://rsj.mobilixnet.dk (updated Jan 20)
Date: 14 Feb 2002 20:13:00
Message: <3c6c609c@news.povray.org>
"Tony[B]" wrote:
> Nice! Reminds me of Mechwarrior 2, only this looks better.
Thanks! Never tried Mechwarrior 2 though...
> Hope you can figure out the shadow-casting soon. :)
Should be ready in the next animation!
Rune
Date: 15 Feb 2002 07:06:19
Message: <3C6CF9B0.228C2AE9@namtar.qub.ac.uk>
Mark Hanford wrote:
> I suppose your next trick, Rune, will be Al walking along, chewing a fat
> smoking joke exploding-cigar...
...whilst doing the Dirty Bird[tm]...
signature{
Date: 15 Feb 2002 15:52:58
Message: <3c6d752a@news.povray.org>
> > identical textures.
Are they? Oh, I must be wrong about that!
Okay, well looking at it paused it's harder to spot the individual particles
than I thought, the only hint is that each texture has fairly uniform density
across it, so where they overlap that density is doubled and you can spot the
individual bits. If the texture was more transparent towards the edges then it
would hide this effect better.
I don't mean a pre-defined path, I just mean each particle moves seperately, so
where two particles move relative to each other you can see that they're
seperate. You see a parallax effect that immediately gives away the fact that
they're seperate.
That sounds like it would probably make the individual particles harder to see
BTW, it's still a very nice effect, and anything better would take many times
the render time.
Tek
http://www.evilsuperbrain.com
Date: 16 Feb 2002 16:19:20
Message: <3C6ECCD6.8015B90C@gmx.de>
> BTW, I'd never be able to work with code in printed form...
Why not? It's like reading a book... Well, okay, like reading ten
related books alongside each other - but hey, we're all up
to multi-tasking, or not? ;)
> > Aha. So we're approacing a particle rush?
> Not a rush, I've just decided not to implement too many new things and
> consentrate on getting the first version ready for release instead.
Well, then you'll also have to keep backward-compability in mind... Not
that I'd think you'd forget that, but just in case you need a reminder...
> > If you post yours, and it gets popular, mine won't
> > have a chance... Ah, well.
> Well, I for one would probably use it if it's flexible enough. Does it allow
> me to get access to a particular particle's location at any time? For
> example I'd like to know particle X's location at clock=0.6 even though the
> clock of the scene is currently only at 0.3. That's not possible with my
> system but I imagine it could be possible with yours because of the way it
> works.
> You see, if that's possible, i could use each particle in your system as an
> emitter in my own system and that way get some truely interesting effects.
> :D
You know, another interesting thingy about the way my system works:
I can calculate one set of particles, save their data, reload it as
emitters for another set of particles... But since my system can't keep
track of existant particles constantly (it would be very parsing and
calculating intensive, to know for each particle, which particle has caused
it, and when...), yours and mine could make a very good combination...
Perhaps when yours is out, we can have a combined look at how we can
make them fit together well and easy?
Tim Nikias
Date: 16 Feb 2002 18:31:39
Message: <3c6eebdb@news.povray.org>
One things is reading it - making changes to it is a different matter. I
wouldn't be able to keep track on lots of small changes without coding them
little by little and testing that they work on the way.
> in mind...
Only if I want to... I think it'll cause too many problems to really ensure
backwards compatibility.
> my system works: I can calculate one set of particles,
> save their data
One time for every frame, or once and for all for the entire animation?
> how we can make them fit together well and easy?
We'll see - I'm pretty sure the interfaces are completely different from
each other.
Rune
Date: 16 Feb 2002 19:59:18
Message: <3C6F0065.7644A36A@gmx.de>
I wasn't really thinking about making major changes, just some
simplifications on certain algorithms, or variable-usage (there are
tons of them right now, and I probably don't need THAT many)
to save some RAM. And testing afterwards is of course a must.
I could go both ways, either for every frame, or once and for all,
though the emitting-objects wouldn't move then (I can only save
a certain time-frame, not actual animations, at least not yet)
> each other.
I agree to that, but nontheless I could look at your system in order
to make my macros fit yours, and perhaps vice versa? Just that
someone could put your system in a macro of mine, and my
system in a macro of yours (in case your actually supporting
that many macros, I've made it possible for EVERYTHING to
be user-defined with a macro... but I'm not sure if that was
a good idea...)
When I'm back from my civil service course, I'll probably work
on some images and the particle system (docs, algorithms, examples),
so expect some funky (and crappy) ideas when I'm back... ;-)
Tim Nikias
