POV-Ray : Newsgroups : povray.binaries.animations : Sorry, I'm still obsessed with cloths (MPEG1) Server Time
16 Jul 2025 17:48:25 EDT (-0400)
  Sorry, I'm still obsessed with cloths (MPEG1) (Message 1 to 10 of 16)
Subject: Sorry, I'm still obsessed with cloths (MPEG1)
Date: 9 Feb 2002 11:50:43
Message: <3c655363@news.povray.org>
I've been still working on cloths, but only today I got decent results which
I could post.
I rewrote everything, and I'm again using forward Euler, as my attempts with
backward Euler were very frustrating. However, I implemented a
variable-timestep scheme, which adapts the timestep in function of the
amount of stress in the cloth. If there are very strong forces, then a
smaller step is taken. I still have to tweak this a little bit.
Another important change was the use of the mesh2 object, instead of the
ordinary mesh object. Thanks to this the parsing and render time is reduced,
and also I was able to implement uv mapping to the mesh.
I had several problems with the appearance of many completely black
triangles, and it took me a while to discover that radiosity eliminated that
problem. However, it now takes ages to produce the animation.
I turned off air resistance because I had some bizarre problems with it, but
I'll work on it very soon.
Well, I hope you like it and I'll be very happy to receive any comment or
suggestion,
Fernando.
Download 'newcloth21.m1v.mpg' (366 KB)
Subject: Re: Sorry, I'm still obsessed with cloths (MPEG1)
Date: 9 Feb 2002 12:51:23
Message: <3c65619b@news.povray.org>
It would be even more interesting if you dropped the cloth from higher up,
and it was already slightly crumpled before hitting the sphere. It's kinda
awkward when you see a flat cloth just hanging in the air like that. Anyway,
very nice work. Have you and Apache communicated? I think it would be best
to combine your efforts than to go your own separate ways...
Date: 9 Feb 2002 14:37:03
Message: <3c657a5f@news.povray.org>
Thanks Tony,
Yes, I was able to chat once with Apache by ICQ, but I had to reinstall
Windows again and I lost his ICQ number. Apache: can you give me your ICQ
number, please?
I'm glad you liked it. Please remember that this is just an experiment which
turned out to be decent enough to post it!
Thanks for your comments,
Fernando.
"Tony[B]" <ben### [at] catholicorg> wrote in message
news:3c65619b@news.povray.org...
Anyway,
Date: 9 Feb 2002 19:05:05
Message: <3C65B922.537B0D6D@gmx.de>
Looks really good!
Some things I that popped into my mind:
your problem with those black triangles may be
due to the lightsource positioned behind the triangle
(even it is not, I don't know if it could pop up during
tracing when POV thinks that the surface normal
of the triangle points the other direction, don't know,
only something that popped up). Perhaps try
double_illuminate on the cloth (as long as it really
is very thin).
Do you have cloth-cloth collision yet?
And how does your programm work: write
hundreds of files for POV-Ray to render,
or what?
I'm really curious!
Tim Nikias
Date: 9 Feb 2002 19:27:51
Message: <3c65be87@news.povray.org>
This looks better and better! :)
Have you considered using a second, third or fourth order Runge-Kutta
integration scheme? It is much more stable than Euler-integration (which is
intrisically unstable) and only requires a little more programming. Once
done, it's certainly worth the while...
http://mathworld.wolfram.com/Runge-KuttaMethod.html
Simen Kvaal.
news:3c655363@news.povray.org...
which
> I could post.
with
Date: 9 Feb 2002 22:14:38
Message: <3c65e59e@news.povray.org>
Hallo Tim,
I think I found the problem with the stupid black triangles!!! I just found
out that I had a typo in the code with an 'm' instead of a 'k' so no wonder
I was getting wrong effects. The funny thing is that I "checked" the code
several times and I never saw that big mistake.  I had already tried
double-illumination, but the black triangles still were there.
I still have not implemented cloth-cloth collision. That's definitely in the
to-do list.
Yes, my program (coded in C) writes a text file for each frame, where there
are the coordinates of each "node" as I call them (or "atoms" as Apache
calls them) the normal vectors for each node, and the face indices for each
triangle in the mesh2 object. As I said some time ago, I found this method
very good to parallelize the total effort: my brother's computer creates
this text files, and my computer renders the frames. (Well, when he lets me
use his computer!)
Then my POV script reads these files sequentially (with the built-in
animation features of POV) and generates the sequence of images.
I'm glad you liked it and "danke" for your comments,
Fernando.
"Tim Nikias" <tim### [at] gmxde> wrote in message
news:3C65B922.537B0D6D@gmx.de...
> Looks really good!
> is very thin).
> or what?
> I'm really curious!
> Tim Nikias
> Homepage: http://www.digitaltwilight.de/no_lights/index.html
Date: 9 Feb 2002 22:20:13
Message: <3c65e6ed@news.povray.org>
Hi Simen,
I have considered the idea, but I haven't been able to implement it. The
function to be integrated has lots of variables and I still have not found
an easy way to add it. Nevertheless, I'm not happy with Forward Euler so I
definitely will be trying to implement other more stable methods.
A few weeks ago I tried with Backward Euler, which is an implicit method,
(which in theory has excellent stability properties) but had terrible
results.
I'll let you know if I succeed in this stuff.
Thanks for your suggestions!
Fernando.
"Simen Kvaal" <sim### [at] remove_mestudentmatnatuiono> wrote in message
news:3c65be87@news.povray.org...
is
> Regards,
> Simen Kvaal.
Date: 10 Feb 2002 17:09:39
Message: <3C66EF3E.9419D143@amc.uva.nl>
When you drop a real cloth you would expect the cloth to not just stay
flat and drop. All sorts of non-linear behavour should occur.
Or are your problems of a different sort?
Date: 10 Feb 2002 22:25:12
Message: <3c673998$1@news.povray.org>
My ICQ crashed!
It seems that ICQ doesn't like terminal services and stuff like that.
At this moment, I'm running Miro$oft's MSN Messenger:
Tatlicisi-at-hotmail-dot-com
My e-mail address: apacheserver2000-at-yahoo-dot-com
Date: 10 Feb 2002 23:59:08
Message: <3c674f9c$1@news.povray.org>
"andrel linnenbank" <a.c### [at] amcuvanl> wrote in message
news:3C66EF3E.9419D143@amc.uva.nl...
but
Yes, I agree with you. However, my simulation is a very simplified model
from reality :) I strive to improve that realism, but my lack of knowledge
in physics is a big obstacle. It would be very nice to know more about fluid
dynamics...
Fernando.
