POV-Ray : Newsgroups : povray.binaries.animations : AL walking, stopping and turning - Final Server Time
3 Jul 2026 18:20:53 EDT (-0400)
  AL walking, stopping and turning - Final (Message 8 to 17 of 37)
<<< Previous 7 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: AL walking, stopping and turning - Final
Date: 2 Jan 2002 01:33:08
Message: <3c32a9a4@news.povray.org>
Amazing. The start after the stop was a bit jerky, though. I suspect because
you placed the next footstep so close. Still, this is much better than
anything I could ever do. Great job.
Date: 2 Jan 2002 03:43:25
Message: <3c32c82d@news.povray.org>
"Tony[B]" wrote:
> Amazing.
Thanks!
It's not because I don't want criticism, but I truly can't see this. It
looks pretty smooth to me. Could you explain more detailed what you're
referring to?
Rune
Rune's World:    http://rsj.mobilixnet.dk (updated Nov 5)
Date: 2 Jan 2002 03:43:28
Message: <3c32c830@news.povray.org>
"Dave Blandston" wrote:
> Amazing, Rune! The animation looks very realistic,
> and the attention to detail is very impressive.
Thank you! :)
> The way the eyes and head rotate before Al turns is
> great. Now, can Al walk and talk at the same time?
> How about chew gum?
That should not be too difficult.
But some other things like waving the arm are more difficult as it would
require some way to interpolate between the automatic arm movement and
custom arm movement, which is something I have yet not figured out how to
do.
Rune
Date: 2 Jan 2002 05:02:43
Message: <3c32dac3@news.povray.org>
Rune schrieb in Nachricht <3c32c82d@news.povray.org>...
I wouldn't call it jerky, but the first step after the stop is indeed only
half a footlength wide (long?). I think that's not that realistic, 'cause
it's a waste of kinetic energy.
Nevertheless it's a great piece of work!
Marc-Hendrik
Date: 2 Jan 2002 10:00:38
Message: <3c332096@news.povray.org>
"Rune" <run### [at] mobilixnetdk> wrote :
> Rune
> 3D images and anims, include files, tutorials and more:
________________________________________^^^^^^^^^^
    When are you going to update your sig?
Date: 2 Jan 2002 10:39:24
Message: <3c3329ac@news.povray.org>
Thanks for reminding me! :)
Rune
Rune's World:    http://rsj.mobilixnet.dk (updated Jan 2)
Date: 2 Jan 2002 13:03:56
Message: <3C334C8B.41E1A720@hotmail.com>
Very good.
Here's a tip that helps make MPGs smaller:
Don't use checker as the pigment for your plane, at least not in the
final rendering.  My first IRTC entry was much smaller (and looked
less like a newby effort) when I replaced the checker pattern with
a granite pattern.
If need be, you can have an if-else-end block to switch between test
renders (because the checker pattern is quite useful for eyeballing
measurements).
John
ICQ: 46085459
Date: 2 Jan 2002 14:03:49
Message: <3c335995@news.povray.org>
> the stop is indeed only half a footlength wide (long?).
> I think that's not that realistic, 'cause it's a waste
> of kinetic energy.
I think in reality the first step is indeed often a bit shorter because it
takes the body a little while to get in momentum. However, probably not as
much as this animation. I'll try to figure out why my algorithm places that
step so close to the previous one.
Thank you!
Rune
Subject: Re: AL walking, stopping and turning - Final 2
Date: 2 Jan 2002 14:03:53
Message: <3c335999@news.povray.org>
I've slightly changed the animation. Nothing big - I haven't yet been able
to make that short step longer - but a few minor changes.
I've made AL chew a gum as Dave suggested, I've made a slight breathing
motion for him which isn't really noticeably, but which nonetheless makes
him seem slightly less stiff, and I've modified the ground texture to avoid
The new version has replaced the old one on my website, so it's available
from the same place.
Rune
Date: 2 Jan 2002 14:18:09
Message: <3c335cf1@news.povray.org>
"John VanSickle" wrote:
> Very good.
Thanks!
> least not in the final rendering.  My first IRTC
> entry was much smaller (and looked less like a newby
> effort) when I replaced the checker pattern with a
> granite pattern.
Thanks for the tip! I presume it's the checker pattern seen at a distance
that's the problem? If so I've already updated the animation with a
workaround for that.
Rune
