POV-Ray : Newsgroups : povray.binaries.animations : AL walking, stopping and turning - Final Server Time
9 Jun 2026 02:09:40 EDT (-0400)
  AL walking, stopping and turning - Final (Message 18 to 27 of 37)
Subject: Re: AL walking, stopping and turning - Final
Date: 2 Jan 2002 15:35:18
Message: <3c336f06$1@news.povray.org>
"Rune" <run### [at] mobilixnetdk> wrote :
>  If so I've already updated the animation with a
> workaround for that.
    Ah! I was finally able to see this one, thanks to a complete destruction
of my QuickTime installation... again...
    Very nice, I see a little extra bounce in the tips of the toes, and he
seems a little heavy, but otherwise -very- nice.
Date: 2 Jan 2002 16:51:27
Message: <3c3380df@news.povray.org>
> tips of the toes
Well spotted. It's a side effect of using cubic splines for the movement.
They always want to go a bit too far and then back before they stop. Using
more control points may or may not reduce/solve the problem - I never can
remember.
> and he seems a little heavy
Heavy in what way? He's supposed to look a little heavy, like many toons do.
Does it look wrong somehow?
Thanks! :)
Rune
Rune's World:    http://rsj.mobilixnet.dk (updated Jan 2)
Date: 2 Jan 2002 17:36:19
Message: <3c338b63@news.povray.org>
"Rune" <run### [at] mobilixnetdk> wrote in :
> Heavy in what way?
    The feet seem to hit hard.
    No, probably fixing the feet will fix it, if it really needs to be
fixed.
Date: 2 Jan 2002 18:09:39
Message: <3c339333$1@news.povray.org>
Wow ... extremely nice ... missing words ...
but now: Nitpicking ! *g
have you seen closely the feets in the frames 160-170 ?
when he turns, it seems, that the inner foot moves into the outer one ...
at least it seemes so ...
Jan Walzer <jan### [at] lzernet>
Subject: Re: AL walking, stopping and turning - Final 2
Date: 2 Jan 2002 22:16:55
Message: <3c33cd27@news.povray.org>
He seems to have a purposeful, but casual, step about him. I can easily imagine
him carrying a padd and stopping to check on some equipment, starting to move on
to the next checkpoint, then spotting someone he would like to get better
acquainted with <wink> and changing direction to pursue.
Very well done.
light_source{0,1}#macro c(J,a)sphere{0,1pigment{rgb z}scale a translate J+O}
#end#macro B(R,V,O)c(0,4)intersection{c(V,R)difference{c(-z*4x+10)c(-z*4.1x+
10)c(0<7.5,45,5>)}}#end B(12,0z*25)B(8y*4<0,12,50>)          // Batronyx ^"^
Date: 3 Jan 2002 12:24:33
Message: <3C3494D4.262F30E8@hotmail.com>
Rune wrote:
> "John VanSickle" wrote:
> > Very good.
> Thanks!
> > Don't use checker as the pigment for your plane, at
> > least not in the final rendering.  My first IRTC
> > entry was much smaller (and looked less like a newby
> > effort) when I replaced the checker pattern with a
> > granite pattern.
(I'd like to mention here that I did use a checker pattern for
my entry-winth-an-entry in the Robots round, but that was a
deliberate effort at being lame.)
> Thanks for the tip! I presume it's the checker pattern seen at a
> distance that's the problem? If so I've already updated the animation
> with a workaround for that.
If the anti-aliasing is good, the distance is usually a mix of the two
colors, and isn't really a problem.
The problem with checkered patterns in MPG files is the sharp edges
between the squares in the foreground.  Either you get a lot of
artifacts or you have a huge file.
John
ICQ: 46085459
Date: 5 Jan 2002 06:06:04
Message: <3c36de1c$1@news.povray.org>
"Dave Blandston" <gra### [at] earthlinknet> wrote in message
news:3c32941d$1@news.povray.org...
> How about chew gum?
It looks like he is. Watch very closely when he's stopped or turning and
you'll see his jaw moving up and down, up and down.
Date: 5 Jan 2002 17:07:16
Message: <3c377914$1@news.povray.org>
> I've improved the algorithm in my walking system a lot and have made a new
> version of the animation that I think is much better than the previous.
> I have also rendered it in 320x240 with AA, and the camera angle is a bit
> more interesting.
Awesome!!!   :o)   This is the best character animation I've seen in Pov and
maybe because I never see such modern toons, it's so smooth like I can't
even imagine.
Hugo
Date: 5 Jan 2002 19:30:10
Message: <3c379a92@news.povray.org>
> I've seen in Pov and maybe because I never see such modern
> toons, it's so smooth like I can't even imagine.
Gee, thank you! :)
Rune
Date: 5 Jan 2002 19:30:19
Message: <3c379a9b@news.povray.org>
> stopped or turning and you'll see his jaw moving up
Because I implemented Dave's suggestion! :)
(I updated the animation after Dave sent his message.)
Rune
