POV-Ray : Newsgroups : povray.binaries.animations : Gravity fun! (510 kbbu) Server Time
12 Jun 2026 03:31:38 EDT (-0400)
  Gravity fun! (510 kbbu) (Message 11 to 20 of 46)
Subject: Re: Gravity fun! (510 kbbu)
Date: 5 Dec 2001 12:16:46
Message: <MPG.1678753f4c64ddce9896c5@news.povray.org>
In article <3c0e39ec@news.povray.org>, run### [at] mobilixnetdk
says...
> Of course I haven't tried it, but I think most (maybe all) will impact a
> planet but some might leave the system (that happened in some other tests).
Then you have a problem. They should't be able to do this (unless they
have a high initial speed) because of energy-conservation.
I tried a similar thing (in C, but 2D), and had the problem that some
partices that passed the gravity-source in small dinstance tend to gain a
lot of speed, because the gravity force varies very much in a very small
area, so the simulation gets unaccurate.
Or maybe some kind of "adaptive iteration step length" could help here.
Lutz-Peter
Date: 5 Dec 2001 12:26:58
Message: <3c0e58e2$1@news.povray.org>
    Um... I am probably the last person to challenge this, but "evaporation"
of an orbital system is pretty common. Energy is conserved, as it is taken
from other objects. Some things slow down and other things speed up.
Date: 5 Dec 2001 12:32:58
Message: <3c0e5a4a@news.povray.org>
> do this (unless they have a high initial speed)
Sure, but what's considered high initial speed? I think the particles have
high initial speed...
> problem that some partices that passed the
> much in a very small area, so the simulation gets
> unaccurate.
My particles collide with the planet before that happens.
> could help here.
Haha, that's completely out of the question with my system. Having each
particle have differently spaced interation steps - that sure would be a
mess, and practically impossible to code into my system...
Rune
Rune's World:    http://rsj.mobilixnet.dk (updated Nov 5)
Date: 5 Dec 2001 12:35:19
Message: <MPG.16787994d47543659896c6@news.povray.org>
In article <3c0e58e2$1@news.povray.org>, bde### [at] cflrrcom says...
Yep, in reality, but this can't be the case here, because in this
particle system, the particles themselves doesn't influence each
other....
Date: 5 Dec 2001 12:35:30
Message: <3c0e5ae2@news.povray.org>
Of course that only applies to this animation, not my system in general.
Because the system is so flexible, it's up to the user to make sure unwanted
effects don't take place.
Rune
Date: 5 Dec 2001 12:39:28
Message: <MPG.16787a87e74296799896c7@news.povray.org>
In article <3c0e5a4a@news.povray.org>, run### [at] mobilixnetdk
says...
I think, they would escape the system immediately if they had sufficient
energy. I maybe wrong though.
Perhaps the effect isn't visible at once, but accumulates?
Yes, it was just an idea, and probably anyway overkill unless you want to
accurately simulate a solar system :-)
Lutz-Peter
Date: 5 Dec 2001 12:44:53
Message: <3c0e5d15@news.povray.org>
"Lutz-Peter Hooge" <lpv### [at] gmxde> wrote in message
news:MPG.16787994d47543659896c6@news.povray.org...
> other....
    Ah, I didn't read that in the previous posts. I assumed that they did
inter-react. If not, you are correct, they either have too high an initial
velocity or he has a problem.
Date: 5 Dec 2001 12:48:49
Message: <3C0E5E2A.C0112E46@gmx.de>
Rune wrote:
> I'm not sure I like what I hear. Are you implying that my particle system
> may not be good enough for NASA to use?
It might interest you that NASA once had serious problems with exactly
this problem, but i don't know the precise details, i just heard it
somewhere.
'drift' of the results is a common problem with simulation of such systems
so no need to feel bad about it. ;-)
Date: 5 Dec 2001 12:53:56
Message: <3C0E5F60.E0C56986@gmx.de>
Not necessarily, in a 3 body system they can collide with one of the
masses even if the speed is very high.
Date: 5 Dec 2001 13:01:00
Message: <MPG.16787f9dc94c6d669896c8@news.povray.org>
In article <3C0E5F60.E0C56986@gmx.de>, chr### [at] gmxde says...
Thats even possible with a two-body-system:
o---> <-O
