POV-Ray : Newsgroups : povray.binaries.animations : Collision /w moving object Server Time
12 Jun 2026 03:32:26 EDT (-0400)
  Collision /w moving object (Message 2 to 11 of 11)
<<< Previous 1 Messages Goto Initial 10 Messages
Subject: Re: Collision /w moving object
Date: 1 Dec 2001 22:13:22
Message: <3c099c52@news.povray.org>
There are a couple that are definitely going through the boxes, but by Jove
this is good! You deserve some rest, boy! This is some excellent work! :)
Date: 2 Dec 2001 01:43:33
Message: <3c09cd95$1@news.povray.org>
Shouldn't the paddles be spinning in the opposite direction?
Jim
"Rune" <run### [at] mobilixnetdk> wrote in message
news:3c099330@news.povray.org...
> Early test. Tired now. Explanation later. Must sleep. Goodnight!
> Rune
> 3D images and anims, include files, tutorials and more:
> Rune's World:    http://rsj.mobilixnet.dk (updated Nov 5)
> POV-Ray Users:   http://rsj.mobilixnet.dk/povrayusers/
> POV-Ray Webring: http://webring.povray.co.uk
Date: 2 Dec 2001 07:14:25
Message: <3c0a1b21@news.povray.org>
> through the boxes
Actually I don't think so. I can't spot any. I should mention though that
there are three simulations here and each simulation only tests against its
own box, not against the others' boxes, so the particles from one system may
go through the boxes of the other systems. Is that what you're referring to?
> excellent work! :)
Thanks! I've had a good night's rest now and am ready to go on... :D
Rune
Date: 2 Dec 2001 07:14:28
Message: <3c0a1b24$1@news.povray.org>
No, they're motor driven, not pushed by the water.
But it probably was a mistake to call the animation for mills.mpg as they're
not mills...
Rune
Date: 2 Dec 2001 10:07:39
Message: <3c0a43bb@news.povray.org>
its
may
to?
That's precisely what I'm talking about. The red ones go through the green
ones' box/plank.
Date: 2 Dec 2001 12:52:45
Message: <3c0a6a6d$1@news.povray.org>
Excellent work!!
PGP Public Key
Date: 2 Dec 2001 16:31:03
Message: <3C0A9A2A.B1FE4CEF@yahoo.com.au>
This looks really nice Rune. May I ask if your particles gain energy from the
collision with the box (especially if it is moving fast)? Can your algorithm
handle _really_ speedy rotations with the test environment? I had considered
putting this into my system, but could not come up with a suitable method for
handling the energy gains easily and accurately for the these high speed rotation
cases.
MJL
> Rune
>    mills.mpg    Type: MPLAYER2 File (video/mpeg)
>             Encoding: x-uuencode
light_source{12*(y-z)rgb 2fade_distance 9fade_power 2area_light x,z,5,5}#macro A
(H,B,R,T)prism{0,1H+4,0u*9,9v*9,0#local I=1;#while(I<H)#local V=asc(substr(B,I,1
))-33;<div(V,10)mod(V,10)>#local I=I+1;#end pigment{red 1}rotate-<90,R>translate
-T}#end A(16"/.@VZno=<PLA89/"0,5*x)A(14",6;MWmhryXN3,"60<15,0,8>)camera{location
25*(y-z)look_at 0}A(8"6hiAG=6"-60,-10*x)box{-99(x+z)*99 pigment{rgb 1}}   // MJL
Date: 2 Dec 2001 18:59:07
Message: <3c0ac04b$1@news.povray.org>
Thank you! :)
It does, but it's not particularly visible in this animation.
> Can your algorithm handle _really_ speedy rotations with
Yes. :)
Not one particle has escaped yet. And mind you - in this animation I used
very few calculation steps - only one per frame!
> I had considered putting this into my system, but could
> not come up with a suitable method for handling the energy
> rotation cases.
Well, it did take me quite a while to come up with the method. It only works
with transformations, and the transformation has to be separately specified.
That way I have access to the vtransform and vinv_transform functions. What
I basically do is to leave the object still and transform the ray inversely
instead. Then I find the intersection and then I transform the intersection
point etc. forward so it gets back in place.
So, it's not the spoon that is bending, but you! - err, I mean the
particles...
Rune
Date: 2 Dec 2001 18:59:08
Message: <3c0ac04c$1@news.povray.org>
"Rick [Kitty5]" wrote:
> Excellent work!!
Thank you! :)
Rune
Date: 3 Dec 2001 15:09:41
Message: <3c0bdc05@news.povray.org>
"Tony[B]" <ben### [at] catholicorg> wrote in message
news:3c0a43bb@news.povray.org...
> its
> may
> to?
> ones' box/plank.
<nit-pick mode>
And some of the green ones vanish as they strike the paddle for the blue
stream
</nit-pick mode>
But I like it, anyway :)
I was wondering if maybe the distance they spray depended on the speed of
the spinning paddle. If you spin it even faster, will they move off at a
higher speed?
