POV-Ray : Newsgroups : povray.binaries.animations : Improved particle interaction (MPG1) Server Time
3 Jul 2026 16:46:43 EDT (-0400)
  Improved particle interaction (MPG1) (Message 2 to 11 of 11)
<<< Previous 1 Messages Goto Initial 10 Messages
Subject: Re: Improved particle interaction (MPG1)
Date: 24 Nov 2001 03:52:45
Message: <3BFF5FDD.DC431EA0@gmx.de>
> I've modified my particle interaction routine in which particles experiment
> a cohesive force, but cannot be too close either, so as to avoid having two
> distinct particles occupying the same space.
> This can be seen at the end of the sequence, in which the blobs settle down
> in the bottom of the "receptacle" and don't occupy the same space. This
> really improves the sense of the conservation of volume, which was evident
> in some past animations.
But there still seems to be a problem with the energy, the particles are
'vibrating' quite a lot in the end.  I suppose this is a general problem
of particle based simulations since they somehow behave like molecules and
this is exactly what the single molecules are doing in a liquid.
> I'll be happy to receive any feedback on this sample.
> Of course, I'm also fed up with this surface, so the next thing I'll try is
> to extend the algorithm to accept non-lathe surfaces.
That's the advantage of doing things in SDL or as a Povray-patch.  You
have access to the internal intersection routines.
Date: 24 Nov 2001 08:18:37
Message: <3bff9e2d$1@news.povray.org>
news:3bff3dde@news.povray.org...
experiment
two
    That works much better, doesn't it?
Date: 24 Nov 2001 08:40:31
Message: <3bffa34f@news.povray.org>
experiment
two
down
i think this is one case where more smaller particles will make a definate
improvement - very imporessive - especially the way they seem to behave more
like a fluid
PGP Public Key
Date: 24 Nov 2001 11:20:36
Message: <3bffc8d4@news.povray.org>
Looks like the thing were pulling in a few of them really fast toward the
end, not very realistic to me. But still, the general shape of it is quite
nice and swishy. :)
Date: 24 Nov 2001 13:19:44
Message: <3bffe4c0$1@news.povray.org>
Very good!
I like it a lot. :)
Best Regards
Date: 24 Nov 2001 17:31:08
Message: <3c001fac@news.povray.org>
"JPGargoyle" <jpg### [at] clixpt> wrote in message
news:3bffe4c0$1@news.povray.org...
> Very good!
> I like it a lot. :)
> Best Regards
Thanks!!
Fernando.
Date: 24 Nov 2001 17:34:14
Message: <3c002066@news.povray.org>
"Tony[B]" <ben### [at] catholicorg> wrote in message
news:3bffc8d4@news.povray.org...
> nice and swishy. :)
Thanks! I also see that speed a little bit odd, but I believe it may not be
too incorrect after all, as the potential energy of the particles has to be
transformed into kinetic energy when they are at the bottom of the "bowl"
and as the circular bottom is quite small, the angular velocity of the
particles has to be somewhat high.
Maybe a little more friction is needed to make it more realistic?
Thanks again,
Fernando.
Date: 24 Nov 2001 17:50:31
Message: <3c002437@news.povray.org>
news:3bffa34f@news.povray.org...
more
> like a fluid
Thanks! I've already modified the code to accept other types of surfaces,
but I think maybe I'll leave this addiction away from me for some time,
because I haven't done many other important things!!!! I mean, POV is
dangerous!!!! :)
Fernando.
Date: 24 Nov 2001 17:51:03
Message: <3c002457@news.povray.org>
Yes, I think so :)
Thanks,
Fernando.
Date: 24 Nov 2001 17:54:19
Message: <3c00251b@news.povray.org>
news:3BFF5FDD.DC431EA0@gmx.de...
experiment
two
down
evident
Yes, the way it is simulated causes that vibration. I don't like it either;
maybe a finer simulation will help reducing the magnitude of the vibration
and make it less evident.
is
One of the advantages of my algorithm is that it can be parallelized, that
is, I can use several machines to code several frames independently, because
the coordinates of the particles are given by my C program. Can it be done
similarly with SDL or POVRay-patch?
Thanks for the suggestions,
Fernando.
