POV-Ray : Newsgroups : povray.binaries.animations : Basic physic laws back to normality (apparently) (MPG1) Server Time
18 Sep 2025 23:00:05 EDT (-0400)
  Basic physic laws back to normality (apparently) (MPG1) (Message 1 to 10 of 11)
Subject: Basic physic laws back to normality (apparently) (MPG1)
Date: 22 Nov 2001 12:36:55
Message: <3bfd37b7@news.povray.org>
I wrote the code in C, and now it is much faster! I'm beginning to think
about adding particle interaction. That will slow the algorithm
considerably, but I think it may be worth the try.
I still don't like the appearance of the blobs... it's still too "chunky".
Even though they are 10,000 blob spheres, I can still spot lots of them.
I've tinkered with the threshold and strength parameters, but I haven't
reached any satisfactory values. Any suggestions?
Well, I hope you like it. And of course, your commentaries are welcomed.
Good luck,
Fernando.
Download 'liquid8.m1v.mpg' (262 KB)
Subject: Re: Basic physic laws back to normality (apparently) (MPG1)
Date: 22 Nov 2001 15:03:33
Message: <3bfd5a15$1@news.povray.org>
think
"chunky".
them.
haven't
That's much better.  Particle interaction may well be the way to go,
especially adding viscosity (particles sticking together) as this may
cure the problem of individual components being visible.  Also it would
make sure that particles didn't occupy the same space at the same time
(if that is not the case already).  Good work nonetheless.
Date: 22 Nov 2001 17:26:00
Message: <3bfd7b78@news.povray.org>
"Andrew" <ast### [at] hotmailcom> wrote in message
news:3bfd5a15$1@news.povray.org...
> think
> "chunky".
> them.
> haven't
Thank you! Yes, currently it is possible for two distinct particles to
occupy the same space. Actually, at the end, when most particles go to the
bottom of the surface, they occupy much less space than it should, because
they're all clustered.
Today in the morning I implemented a routine for particle interaction but
bizarre things began to appear, so I took it out. Maybe today I'll try to do
it again.
Thanks again,
Fernando.
Date: 22 Nov 2001 22:28:00
Message: <3BFDC294.84DA994C@simberon.com>
> it again.
What happened that was so bizarre?  Are you using Euler's method for the
simulation (i.e., add a little acceleration to the velocity and add a
little
velocity to the position)?  This may cause the system to gain energy. Is
that
what's happening?
David Buck
Simberon Inc.
Date: 23 Nov 2001 07:46:37
Message: <3BFE452A.712081F4@gmx.de>
I suppose you know about the megapov plus particle system patch, if not
you might want to have a look.
I already suggested to interpolate additional blob components between, but
i'm not sure if that would look good.
Date: 23 Nov 2001 11:08:09
Message: <3bfe7469@news.povray.org>
"David Buck" <dav### [at] simberoncom> wrote in message
news:3BFDC294.84DA994C@simberon.com...
but
to do
> > it again.
> little
> that
> what's happening?
Yes, I'm using that method. I didn't know it was Euler's! But the problem
with my interaction routing wasn't really that: I had mistaken the position
vector for the velocity vector!!! :)
I left 3 computers rendering the animation overnight, and it still hasn't
finished! Now I learn that adding reflection to an animation has its
price!!! :)
I hope I can post the result in a few hours.
Fernando.
Date: 23 Nov 2001 17:24:49
Message: <3bfeccb1@news.povray.org>
news:3BFE452A.712081F4@gmx.de...
Hi Christoph. Actually no, I've been using POVRay 3.1a and haven't had the
time to experiment with the new beta. Does it have the same feature you're
talking about?
"chunky".
> Christoph
Mmh... don't know... maybe it might help, but I still have to figure out how
to implement it. Now I'm experimenting a bit with of particle interaction.
Actually I'm going to post in a moment my latest experiment. I hope you like
it.
Thanks for the suggestions.
Fernando.
Date: 23 Nov 2001 17:59:50
Message: <3BFED4E6.BE5BDE52@gmx.de>
> talking about?
No, the particle system patch is not included in 3.5, you can get it at:
http://homepage.mac.com/chrishuff/povpatch.html
Date: 23 Nov 2001 18:52:58
Message: <3bfee15a@news.povray.org>
news:3bfd37b7@news.povray.org...
> Good luck,
> Fernando.
Definately shaping up well. Though if you think of water molecules, even a
million blobs would be skimping ;)
Date: 23 Nov 2001 22:06:26
Message: <3bff0eb2@news.povray.org>
"Data" <not@all> wrote in message news:3bfee15a@news.povray.org...
"chunky".
> > Good luck,
> > Fernando.
Thanks! I agree with that, but for example, I've seen JRG's animations that
use 10,000 particles (as far as I remember) and it looks much more fluid
than mine, which uses the same number of blob components. But I'm still
experimenting... :)
Fernando.
