POV-Ray : Newsgroups : povray.binaries.animations : My next fluid experiment (MPEG1) Server Time
10 Apr 2026 17:57:23 EDT (-0400)
  My next fluid experiment (MPEG1) (Message 1 to 9 of 9)
Subject: My next fluid experiment (MPEG1)
Date: 17 Nov 2001 00:31:16
Message: <3bf5f624@news.povray.org>
Not actually what I had in mind, but it is at least a step forward in the
development of my liquid simulation theory :)
It may not be very clear what type of surface I'm using. It is a paraboloid,
and the camera is looking towards somewhere near the focus of the
paraboloid.
I know it is still far from Rune's or JRG's beautiful liquid animations, but
I feel like I'm making progress.
One of my most difficult problems was the calculation of the distance from
the particle to the surface, to know if the particle has to bounce. I had to
implement a Newton-like algorithm to know such distance for each particle.
For this paraboloid I know it works ok, but for more complex surfaces (such
as those I have in mind!), specially nonconvex surfaces, I don't know if it
would work.
I've programmed the simulation program in Matlab6, because it is so easy to
work with vectors and matrices in Matlab! But I was surprised to see that it
took much more time to simulate the motion than rendering the scenes!!!
I also have some problems setting the values of the blobs... I've tinkered
with lots of values and I just don't feel like I've reach the "sweet" point.
I'm eager to read your comments.
Fernando.
ps. Probably I will leave the computer overnight rendering a similar
environment but with much more blobs!
Download 'liquid5.mpg' (378 KB)
Subject: Re: My next fluid experiment (MPEG1)
Date: 17 Nov 2001 03:30:34
Message: <3BF62027.961FBEC0@gmx.de>
> would work.
In Povray you could use 'trace' to accomplish this - of course this is not
perfect for highly curved surfaces either.  Is there interaction between
the single particles BTW?
I think Matlab isn't exactly what you would call fast, a separate compiled
program might improve speed.
It does not really look like fluid of course, but otherwise it looks
really interesting.  Both animations only show paricles direcly on the
surface, do they also leave it when speed and curvature are sufficient?
Maybe it would improve the fluid-like look if you interpolate additional
blob components for the render.
Date: 17 Nov 2001 07:21:16
Message: <3bf6563c@news.povray.org>
Nice anim, but I think you're right about the blobs. It looks a bit like
watery cream cheese <g>
Keep up the good work tho.
//Mahalis
camera{location<0,0.25,-2> look_at 0.5*y} #declare T=texture{pigment{crackle
scale 0.5 rotate 90 turbulence 0.75 color_map{[0 rgb 1][0.05 rgb 1][0.1
rgb<1,0.25,1>][0.25 rgbf 1][1 rgbf 1]}} finish{ambient 1}} #declare
c=difference{torus{0.5,0.1 rotate -90*x}box{<0.7,0,0.2>,<-0.7,-0.7,-0.2>}}
merge{object{c translate<0.5,0.5,0>} object{c translate<-0.5,0.5,0>}
cylinder{<1,0.5,0>,<1,0,0>,0.1} cylinder{<-1,0.5,0>,<-1,0,0>,0.1}
cylinder{0.5*y,0,0.1} texture{T}}
point.
Date: 17 Nov 2001 08:00:43
Message: <3bf65f7b$1@news.povray.org>
looking good so far.
perhaps the best soloution for blobs would be to vary the settings depending
on the blobs proximity to other blobs. ie to see if you can get 'joined
blobs' to appear stickier
PGP Public Key
Date: 20 Nov 2001 02:30:59
Message: <3bfa06b3@news.povray.org>
What I've noticed is that the messages with attachments usually are much
larger than the attachment itself... mmmh. :/
news:3bf5f624@news.povray.org...
paraboloid,
> paraboloid.
but
to
(such
it
> would work.
to
it
point.
> Fernando.
Date: 20 Nov 2001 07:30:40
Message: <3bfa4cf0@news.povray.org>
news:3bfa06b3@news.povray.org...
A little while ago someone mentioned it's about 3:2
-tgq
Date: 20 Nov 2001 07:46:57
Message: <3bfa50c1$1@news.povray.org>
that's the joy of text encoding :)
PGP Public Key
Date: 20 Nov 2001 10:36:22
Message: <3bfa7876$1@news.povray.org>
it should only be 8:7 if I'm right ...
8 bits are converted to 7 bits ...
(.. or are they only using 6bits? (hence the Base64-encoding) ... But then
I'm wrong ...)
Jan Walzer <jan### [at] lzernet>
Date: 20 Nov 2001 12:05:22
Message: <3bfa8d52@news.povray.org>
I had an increase of about 37.83 percent... That's not very efficient!!! :/
Good luck,
Fernando.
"Trevor Quayle" <Tin### [at] hotmailcom> wrote in message
news:3bfa4cf0@news.povray.org...
> -tgq
